I need more powerfull tubes for my head
Discussion in 'Marshall Amps' started by bigbadorange, Oct 22, 2019.
  1. bigbadorange
    bigbadorange Active Member
    Oct 23, 2013
    230
    235
    las vegas
    Think these will do it? (KR Audio T1610) I can cut holes in the top of the head so they can stick out.
  2. MarshallDog
    Nov 28, 2010
    12,563
    12,207
    Taintville
    Nice...like a blower sticking up out of the hood on a hot rod!!!
  3. Axis39
    Axis39 Member
    Nov 28, 2012
    30
    83
    Beaumont, CA
    There really is no replacement for displacement!
  4. Gunner64
    Nov 16, 2013
    5,190
    6,141
    Midwest, USA
    ff5d5bc9b13e9ce997f05d201deacdb2.jpg oh yeah....I want this.
  5. Gunner64
    Nov 16, 2013
    5,190
    6,141
    Midwest, USA
    Only about $1000 a tube.
    Mitchell Pearrow and jstich like this.
  6. ampmadscientist
    14,833
    8,695
    Is there a price break for 6?
    Mitchell Pearrow and MarshallDog like this.
  7. MarshallDog
    Nov 28, 2010
    12,563
    12,207
    Taintville
    You could heat your house with them!
  8. MarshallDog
    Nov 28, 2010
    12,563
    12,207
    Taintville
  9. MarshallDog
    Nov 28, 2010
    12,563
    12,207
    Taintville
    I read it takes 20 minutes for them to heat up to proper operating temperature :wow:
  10. Micky
    Apr 29, 2010
    20,440
    16,688
    Vermont
  11. Micky
    Apr 29, 2010
    20,440
    16,688
    Vermont
  12. Gunner64
    Nov 16, 2013
    5,190
    6,141
    Midwest, USA
    Pricey, but man that's a pretty tube.
    MarshallDog and jstich like this.
  13. Jeff Hudson
    Jeff Hudson Active Member
    Jul 10, 2016
    228
    205
    Levelland Texas
    Industrial art!
  14. jstich
    jstich Well-Known Member
    Dec 18, 2016
    435
    291
    Thanks for the vids Micky.
    Micky likes this.
  15. junk notes
    junk notes Active Member
    Dec 10, 2018
    206
    189
    Let me guess... Your head is 1.21 gigawatts? :scratch:
    Bluesrock and MarshallDog like this.
  16. scozz
    scozz Well-Known Member
    Jul 20, 2008
    2,184
    4,753
    That’s exactly what I was thinking Dog!!
    1969 Chevelle SS 396! :lol:
  17. Matthews Guitars
    855
    1,145
    Look up Tung-Sol KT-150 tubes and get back to me. Audio Research uses them in some of their tube amps and they seem to be gaining popularity among the tube audiophole market. A pair of these tubes will put out 150 watts. The nice thing about them is that if you really wanted to build an amp with them, it's not hard to get the transformers you'd need for them.
    There are some audiophile amps running 845 transmitter tubes.
    SOME designer out there will try to make a production run of boutique amps that uses any type of tubes that he thinks are interesting and that there is an adequate supply of. In some cases that designer then attempts to corner the market on spares and then jack the price up to infinity and beyond.
  18. Matthews Guitars
    855
    1,145
    Oh, KR audio...aka Kron, I think. The company that gained no small degree of notoriety for having an amplifier reviewed by Stereophile Magazine and when the bench tests came back "Utterly bizarre, WTH is wrong with this amp design?", the reviewer withheld a recommendation and instead the very eccentric and egotistical designer of the amps started accusing the technical evaluating engineer (John Atkinson) of using bench testing methods that had nothing to do with real music. Well...John was using the same industry standard testing protocol for audio equipment that every test facility uses. And NO other amplifier ever tested by John would go into such bizarre oscillatory behavior as the Kron amps under test.
    I don't know which was worse for the company....the really whacked test results indicating flat out bad design work, or the designer/company owner fighing so hard to justify his bad design work by attacking the test methodology instead of owning up to the fact that his amps would go into ultrasonic oscillations if a fly farted in the next room.
  19. bigbadorange
    Oct 23, 2013
    230
    235
    las vegas
    You say bug, I say feature! (In thick eastern Europe accent)
  20. mickeydg5
    23,197
    10,297
    I think four 6550/KT88 would be better and cheaper.
