I need a clean boost pedal and a wireless... any recommendations?
Discussion in 'The Tone Zone' started by GuitarIV, Jul 30, 2019.
  1. fifteenohms
    fifteenohms Well-Known Member
    Sep 30, 2010
    1,071
    537
    Los Angeles, CA
    If you dont feel worthy of better, than I guess theres no issue.
  2. Fender
    Fender Active Member
    Nov 14, 2017
    278
    210
    Nobody mentioned using an eq-pedal for clean boost ? I'll do it then ;)
  3. Filipe Soares
    Mar 8, 2019
    384
    542
    I don't need to spend too much money on pedals to feel special, I already know who I am and better: what I need to kickass.
    Most of people who needs expensive stuff have their sense of self worth in outside things, and if you take away their little toys they loose completely their own sense of worthiness.
    I don't know much about you, but by the amount of times you keep repeating these kind of stuff around the forum (maybe to convince yourself) I suggest you to find a shrink to solve your issues.
  4. Jethro Rocker
    7,083
    6,965
    Line 6 G30 here too. Put in a small camera pouch on straps. I only get maybe 10 - 12 shows a year but have had for a few years and they hold up. Rechargeable batteries a must. Only makes sense
    fifteenohms and WellBurnTheSky like this.
  5. fifteenohms
    Sep 30, 2010
    1,071
    537
    Los Angeles, CA
    I wouldnt call the tools "toys" per se.
    But I would consider the songwriter-performer's work a "craft."
    Therefore. I like the better tools for better work output. Psychologist is unnecessary.
  6. Filipe Soares
    Mar 8, 2019
    384
    542
    please share your art with us.
  7. fifteenohms
    Sep 30, 2010
    1,071
    537
    Los Angeles, CA
    Im happy to share about tools in a tools forum.
  8. Filipe Soares
    Mar 8, 2019
    384
    542
  9. fifteenohms
    Sep 30, 2010
    1,071
    537
    Los Angeles, CA
    Some here just fooling around call them "toys" is understandable.
    Throwing memes just shows a not subtle lack of sincerity.
  10. Filipe Soares
    Mar 8, 2019
    384
    542
    I'm being sincerely while I'm saying you talk too much, too much arrogance and no visible results.
    if you want to act like the boss, you have to be the boss. or else, you're just like this little guy the great poet Joey Demaio wrote about.
    "There they wait in fear
    With swords in feeble hands
    With dreams to be a king
    First - one should be a man"
    so, if you wanted plain and simple it's here. no memes.
  11. Ivanock
    Ivanock Member
    Apr 1, 2015
    61
    61
    Shure GLXD16 and you are done! [​IMG]
    Cadorman likes this.
  12. Im247frogs
    Im247frogs Well-Known Member
    Jan 31, 2012
    299
    300
    Brooklyn, Joey!
    I said "SHOULD I BRING MY TOOLBOX?"
  13. 67Mopar
    67Mopar Well-Known Member
    Jun 14, 2011
    1,917
    2,386
    1. Use a cord.
    2. Crowther Hot Cake. Set the drive level low.
  14. chromeboy
    chromeboy Active Member
    Jan 25, 2010
    527
    210
    San Bruno,CA
    Any mini overdrive can be used as a clean boost. Just turn the drive all the way down and the level all the way up. Eq's are also good in the loop for dB boost. As far as wireless, I've.been using the sure glx6 which is a pedalboard unit and has a rechargeable battery pack. I believe I can use up to 6 guitars with it although I never have. It also has a built in tuner and true bypass. And switching out guitars is easy and doesn't really need more battery packs. I use one strap for all my guitars so when I need to switch out I just turn off the battery pack, unplug my guitar and strap and pop in another guitar plug in and go. I mean unless you are on a major tour you really don't need so much especially for club gigs and or castle gigs.
  15. tce63
    tce63 Well-Known Member
    Aug 6, 2018
    821
    1,941
    Sweden
    I use the same :)
  16. herbvis
    herbvis Active Member
    Jul 8, 2010
    135
    122
    I have used a catalinbred super chili picoso in my loop for years. It works as a nice pure volume only boost when used in a loop. its perfect
    tce63 likes this.
  17. PDC1
    PDC1 Member
    Apr 25, 2018
    28
    29
    Spark mini. I found the ep boost always did something a little odd with the upper mids at stage volume. The spark Mini really leaves your tone completely alone and just pushes the signal.
    tce63 likes this.
  18. Kim Lucky Day
    Kim Lucky Day Active Member
    Aug 22, 2018
    105
    214
    +1... This pedal is a great boost for the $
    tce63 likes this.
