I have a Problem with certain Marshall Amps. JCM2000 DSL and TSL.
Discussion in 'Marshall Amps' started by custom53, Jan 15, 2020.
Thread Status:
Not open for further replies.
  1. custom53
    custom53 Well-Known Member
    Sep 29, 2009
    1,883
    934
    Ohio
    Both of those amps blew out the Main Fuse's. And I don't play them that much and only at home in practice. I don't know why the fuses blew. They blew when the amps were not being played. I have never had any of my other Marshalls blow a fuse. Just these two. They only take a 4 or 5 amp main fuse. I replaced them both. The DSL is back to normal and plays fine. The TSL keeps blowing the fuses. THe TSL blew the 5 amps fuse as soon as I replaced it and powered it back on. THen I put a 10amp fuse in and it blew that one. I finally put a 20 amp fuse in it and it didn't blow. But I'm too nervous to play it with going that much over the normal amperage. I don't know why it is acting like that. Or even why they both blew the main fuses when they weren't turned on. But the DSL is okay again. Not sure why the TSL is still acting like that..
    stringtree and Mitchell Pearrow like this.
  2. Dogs of Doom
    19,818
    20,005
    can you check R6 & R9?
    AmpMad has the typical pull the tubes & test the sockets, I'll go find one of his posts...
  3. JacksonCharvelAddict
    Mar 4, 2016
    1,619
    1,599
    Were they plugged in to power but turned off?
  4. Dogs of Doom
    19,818
    20,005
    here, I found it...
  5. Dogs of Doom
    19,818
    20,005
    also C46...
  6. Lance Chambers
    Jun 23, 2019
    811
    1,149
    The Land That Time Forgot
    Throw them in the dumpster! :erk:
    MarshallDog and mcblink like this.
  7. Gunner64
    Nov 16, 2013
    5,197
    6,154
    Midwest, USA
    And I'll pick them out of the dumpster. ..and fix them. A properly functioning 2k dsl rips. I used to dog them too..until I got one cheap enough to make right. Night and day from the fizzy pos an amp in need of service is. Bias drift and Under $300? Shit I'll buy as many as I can find. imo an easy repair. I ain't afraid of no bias drift.
    And to the op that's maybe what you have going on and didn't realize it. Follow the mad ampers posts on the subject. He explains the testing proceedure pretty good.
    DonP, GIBSON67, Adrian R and 9 others like this.
  8. Ken Underwood
    Oct 16, 2013
    373
    1,030
    What a totally stupid thing to do replace a 5amp fuse with a 10amp fuse and then as it blew replace it with a 20amp fuse.
    I think that this must be a total wind up as no one would be that stupid
    DonP, Nik Henville, scozz and 9 others like this.
  9. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    1,301
    1,264
    Mains fuse not HT fuse??
    Hmm wasn't bias drift an HT fuse thing, usually? Correct me if I'm wrong
    Perhaps you need a surge protector or something? DSL and TSL are closely related circuits, it'd be unsurprising if they reacted the same way to being plugged into an outlet with unstable voltage
  10. Gunner64
    Nov 16, 2013
    5,197
    6,154
    Midwest, USA
    I Missed that part in my quick read at work ... yes pretty stupid. Why does he think they're in there for in the first place?. Yea..he needs to find a tech quick before he burns his house down.
    LCW, DonP, MarshallDog and 5 others like this.
  11. ampmadscientist
    14,866
    8,725
    "I finally put a 20 amp fuse in it and it didn't blow."
    :nono:
    Is this guitar playing, or arc welding?
    "I have a Problem with certain Marshall Amps."
    Sounds like a lot more than just Marshall Amps...
  12. Matthews Guitars
    863
    1,161
    You NEVER replace a blown fuse with a fuse of larger amperage! Congratulations, you probably just turned a minor problem into a major one.
    DUMB.
    Hell, stick a drywall screw in the fuse socket and don't forget to wrap it in aluminum foil while you're at it! That isn't likely to blow, and your amp may make sound again. Not sure you'll LIKE the sound of a power transformer bursting into flame, but it'll be a sound, anyway.
    The fuse is there to protect the expensive components. Putting in a bigger fuse ensures that they're NOT protected.
    You may have just had a shorted power tube. Now you probably have bad power tubes and a bad transformer, too.
  13. Jethro Rocker
    7,347
    7,641
    Agree with all above. Also, they had to have power on to blow a fuse. Nothing can blow a fuse with no power. Take to a tech. A TSL is a killer toned amp. It's obvious it's beyond your tech level. Why does it have a 5 Amp fuse to begin with? To replace with a 20?
    Crazy, man.
    Replace the breakers in your house with 60 amp ones. Watch it burn!!
  14. Michael Roe
    Michael Roe Well-Known Member
    Mar 25, 2017
    1,447
    3,485
    Springfield, Ohio
    Take it to an amp tech before you hurt yourself!
  15. Matthews Guitars
    863
    1,161
    And put the original fuse back in it! If the tech sees a blown 20 amp fuse in the amp he's going to have a conniption. He'll probably figure it out anyway, if the damage is as bad as I suspect it must be.
  16. soundboy57
    soundboy57 Well-Known Member
    Dec 27, 2009
    2,699
    2,257
    Oregon
    Funny as hell, right here.
  17. ricksdisconnected
    Aug 11, 2019
    1,012
    1,560
    stupid is a very harsh word here. i can think of many other proper words to use rather than stupid.
  18. Jethro Rocker
    7,347
    7,641
    To put a 20 amp fuse in a 5 amp circuit?
    Interesting?
    Clever?
    I dunno, man...
  19. ricksdisconnected
    Aug 11, 2019
    1,012
    1,560
    uneducated on the topic is where i would start.
    RCM 800, acevh00 and scozz like this.
  20. Jethro Rocker
    7,347
    7,641
    Fair enough.
    neikeel and ricksdisconnected like this.
Thread Status:
