I Can't Remember Where I Read It But.....
Discussion in 'Marshall Amps' started by purpleplexi, Jan 11, 2019.
  1. purpleplexi
    purpleplexi Well-Known Member
    Feb 14, 2011
    600
    806
    Someone in a recent thread said that instead of jumpering channels they used a Y cable. So I bought one and gave it a try. I never thought my plexi clone had a muddled sound but suddenly I can hear the bass, mids and treble so much more clearly - it's like the eq works better. I'm currently floating on a little cloud in tone heaven - this could be the missing link. Whoever it was that posted that thank you Sir!
    2203xman, Trelwheen, J Saw and 3 others like this.
  2. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    449
    420
    http://www.marshallforum.com/threads/1987x-or-1959.105432/#post-1780831
    PP, I have been incorporating that Y cable the past decade. You start getting ideas of good usable and tweakable sounds, then you start coming up with creative ways to tweak your 4 holer. You start thinking what if I throw a pedal inbetween that Y cable & Vol 2. - Delay/echo, reverb, EQ, OD or boost / YMMV... ;-)
  3. purpleplexi
    Feb 14, 2011
    600
    806
    Marshallmellowed I thank you.
  4. JacksonCharvelAddict
    Mar 4, 2016
    1,694
    1,710
    i have never had the pleasure of playing an old 4 holer. It is still fun reading about all the tricks that players have been using with them.
  5. marshallmellowed
    Jun 26, 2009
    3,453
    3,912
    Sure thing, just passing on useful information. I picked it up from a video on Youtube. I like going into the upper left and lower right inputs with the "Y" cable.
    Mitchell Pearrow and Trelwheen like this.
  6. purpleplexi
    Feb 14, 2011
    600
    806
    Yep. That's my preference too. Just to give it a little body.
  7. Coronado
    Coronado Well-Known Member
    Jan 2, 2013
    4,101
    3,562
    Dallas
    Interesting! I have to give this a try!! A "Y" cable, huh? Cool!
  8. Trelwheen
    Trelwheen Well-Known Member
    Nov 18, 2017
    1,797
    2,916
    Texas
    Crap....now I gotta go buy another four holer to try the Y cable solution.
    You guys are expensive. :jam:
  9. coyote
    coyote Active Member
    Sep 20, 2015
    79
    105
    I used to do that with my Major. Sounded fantastic.
  10. purpleplexi
    Feb 14, 2011
    600
    806
    Yep. I reckon internet forums (fora?) drive the economy more than anything.
  11. dro
    dro Well-Known Member
    Aug 1, 2015
    365
    509
    Blue Springs Mo
    Made a little short Jumper out of George L's cable go from lo input 1 to high input 2
  12. marshallmellowed
    Jun 26, 2009
    3,453
    3,912
    That's one approach, the typical channel jump method. The "Y" cable approach retains slightly more of the signal and sounds a little better (IMO).
  13. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    1,407
    1,360
    So how do you use it? Plug guitar into 2 inputs? Or jump 3 unused holes together?
  14. junk notes
    Dec 10, 2018
    449
    420
    Plug one end of your "Y" cable into Vol I Ch 1 (preferably the high input), and the other into either Ch 1, or Ch 2 of Vol II. Set your Vol I as you normally would, then blend in Vol II's channel volume to taste.
    Tweak you Bass knob. You'll need to decide if you prefer the cab on the floor or on its casters, as it will lend to Bass frequencies that can either muddy, or fatten up your hard earned tone. YMMV
  15. marshallmellowed
    Jun 26, 2009
    3,453
    3,912
    Yes. Using a "Y" cable, I've gotten the best results from all of my 4-holers by going into the top left, lower right inputs. This provides a good strong signal to the "Treble" channel, and the "Normal" channel seems to stay more focused at higher settings. Just my experience, of course.
  16. Wolvieberzerker
    Wolvieberzerker Well-Known Member
    Jun 19, 2016
    377
    465
    Interesting. Wonder what would happen if you did the Y cable thing on a vertical input 2204 style head. One way to find out I guess
  17. marshallmellowed
    Jun 26, 2009
    3,453
    3,912
    I think I tried that on my 2203x, but don't remember the result. Must have sucked in some way, as I've never done it since.
  18. Marshallhead
    Marshallhead Well-Known Member
    Jun 3, 2009
    1,419
    584
    You can’t run both inputs on a Master Volume Marshall - only the low input signal will get through, because the extra gain stage of the high input is disconnected as soon as you put a jack in the Low socket.
  19. junk notes
    Dec 10, 2018
    449
    420
    Without getting into the particulars, here is a little help in visually understanding why.
    They are internally shared and are wired together.
  20. 2203xman
    2203xman Well-Known Member
    Jan 30, 2012
    2,959
    2,790
    Hillbilly Heaven USA
    I just got around to trying this.The "Y' cord changes the tone of the amp,and I'm really not sure why,but it is pretty cool.It's not really blending channels like a jumper,but the amp is more alive than ever.Beautiful harmonic tone,very balanced.This is truly the most simple thing you can do to really hear your plexi's true voice.It also seems to cut out some side FX fizz caused by the attenuator.A huge thanks Marshallmellowed!
