How to fix Jubilee reissue power rocker switch?
Discussion in 'The Workbench' started by Ross1231, Jan 13, 2020.
  1. Ross1231
    Ross1231 New Member
    Jan 3, 2020
    2
    Hey guys - I have a 2555x reissue head, about a year old. Just turned it on last night and noticed the red power switch does not light up but the amp plays as normal and the tubes all light up. I’ve never had a power switch light go on me. Just wondering if someone could let me know how to access the light to repair it. Thanks!
  2. mickeydg5
    23,255
    10,331
    The lighted rocker switch gets replaced.
    Has anyone ever tried to take one apart to repair?
  3. Ross1231
    Ross1231 New Member
    Jan 3, 2020
    2
    Sorry I should have been more specific - I mean how would I go about opening up the amp head to swap one out? I have another rocker switch here and can solder I just don’t know if it pops out from the front faceplate or do I open up the entire amp? Thanks
  4. mickeydg5
    23,255
    10,331
    I do not know exactly what that one looks like but they usually have prongs or something that need release from the inside.
  5. South Park
    1,232
    927
    If the amp still works leave it . You can fix it when you bias the amp for new power tubes
  6. Gunner64
    Nov 16, 2013
    5,197
    6,154
    Midwest, USA
    Yes, there's prongs on the top and bottom of the swtch. You have to push them in and push the switch out at the same time. It's Connected with spade connectors. You do have to remove the chassis from the headshell of course. Be careful not to let the faceplate and rear panel snag on the tolex on the way out or you could mangle them.
    And fwiw, You don't have to take the 2555x out of the headshell for retubing. It has a cool external bias system.
  7. charlysays
    charlysays Member
    Oct 24, 2019
    46
    54
    Mine started flickering and going dim on my 2525h. I've so far ignored it and it appears to have fixed itself as of late. I'll continue ignoring it forever I think. If the amp ever needs to come out/ apart for something else, that will be when the switch gets replaced, unless the switch develops a second fault and isn't able to run the amp.
  8. Ken Underwood
    Oct 16, 2013
    373
    1,030
    Standard mains switch fitting, as others have said you need to be inside the amp to access the switch to squeeze together the plastic spring clips top and bottom and push it forward out of the front panel
    What ever you do dont take off all of the connectors at once, just take one off at a time whilst putting it back on the same terminal on the new switch.
    I take it it is exactly the same switch that you have, a direct replacement, any old switch is not good enough.
    As others have said wait until you need to take out the chassis for something major as the amp is OK as it is until then.
  9. Gunner64
    Nov 16, 2013
    5,197
    6,154
    Midwest, USA
    And if it's only a year old isn't it still under warranty? I'd check and see if it's covered, and if your working on it would void that warranty in case something else may happen in the future.
