How Much Are You Lovin’ Your Studio Series Marshall?SC, SV, JUB
Discussion in 'Marshall Amps' started by scozz, May 16, 2019.
  1. tce63
    tce63 Well-Known Member
    Aug 6, 2018
    821
    1,941
    Sweden
    So i got my Weber Mini Mass a few days ago, and i must say it is great.
    Now i can use the SV20h at home and still play on bedroom volume, treble boost works great at low volume
    Thanks @scozz
  2. scozz
    scozz Well-Known Member
    Jul 20, 2008
    1,687
    3,402
    I’m happy that you’re happy tce!
    Yup, the Weber MiniMass 50 is a perfect accessory for Marshalls Studio Series, especially being 20 watt amps,...and it’s only $136.
    It works great for low volume and also higher volumes. I’m glad you’re enjoying yours tce! :thumb:
    I play pretty loud most of the time and I’m really enjoying what this amp has to offer when the power tubes are cooking a little. :cool:
    Before I had Weber attenuator I couldn’t really explore what this amp is capable of,......because the volume needed to get there would be deafening.
    I’m enjoying my Jcm800 Studio amp even more now, if that’s even possible?! :D
  3. scozz
    Jul 20, 2008
    1,687
    3,402
    Hey @tce63, have you used the 3 and 6db treble boost when you attenuate to a very low volume?
    I’m really happy the way they work and the 3 different choices.
    tce63 likes this.
  4. tce63
    Aug 6, 2018
    821
    1,941
    Sweden
    Yes sir, I think 3db is perfect in TV volume.
  5. Kim Lucky Day
    Kim Lucky Day Active Member
    Aug 22, 2018
    105
    214
    I just got the Mini Mass for my SV20H and it does the trick well. I usually use the 3db treble boost, 6db is a bit much. I can fine tune by adjusting my tone knobs on my LP. This is an awesome sounding amp that had unfortunately sat idle for some time because it was just too loud for my practice room. But now with the Mini Mass, I'm starting to explore it and am really liking it. Great AC/DC tones with volumes set around 6-7 and my EH LPB-1 boost in the effects loop gives me the perfect volume boost with a little more hair, perfect for solos.
    tce63, Mitchell Pearrow and scozz like this.
  6. scozz
    Jul 20, 2008
    1,687
    3,402
    Best $136 I’ve spent in a long time,..(actually less than that, I emailed Weber to see if they had any discount codes I could use at check out), they gave me a 10% off code to use.
    Here’s a setting I’m exploring now on my Jcm800 Studio,....higher master volume, lower preamp volume. Getting some great sounding power tube overdrive at this setting, while turning down the preamp overdrive. Some really great tones here!
    The response and articulation of this amp when cranked is very impressive!
  7. scozz
    Jul 20, 2008
    1,687
    3,402
    Glad to hear you’re happy with the Weber MiniMass 50 @Kim Lucky Day! Your experiences mirror mine.
  8. scozz
    Jul 20, 2008
    1,687
    3,402
    tce63 likes this.
  9. Amanda Carter
    Amanda Carter New Member
    Jul 28, 2019
    6
    Just received my SC20H. Very happy so far!
    tce63 likes this.
  10. sellen
    sellen Active Member
    Nov 15, 2010
    291
    199
    Getting mine next week
    Wonder if i can crank this without that "turn down" from the soundman, or the vocalist complains he is not hearing himself at practice. We got a decent PA . Been using 4*12 and Jmp 2204 50w with attenuator. Alot of gear to lug around for those medium /small gigs we do for more or less free just for fun.
    Got a 2*12 Cabinet or might even butcher my old DSL401 combo into a 1*12 cabinet.
    If this works i'm very happy :)
