How Loud Is A 2203x (compared To 2555x Or Sl-x)?
Discussion in 'Marshall Amps' started by SGFA, Jan 10, 2019.
  1. SGFA
    SGFA Member
    Mar 10, 2018
    98
    97
    Italy
    Lately I'm considering a JCM800 2203X head and was wondering how loud is this head compared to the Silver Jubilee 2555X or to a JCM900 SL-X?
    I'm reading that the JCM800 is loud as hell, but as it is a master volume amp like the above amps, is it really different or what?
    The Silver Jubilee 2555X and a JCM900 2100 SL-X and I usually play with master volume at12 o'clock and its' just fine. The band is pretty loud, and I use a 2x12" V30 cabinet.
    slide222 and Mitchell Pearrow like this.
  2. ampmadscientist
    11,981
    5,944
    Left Coast
    It depends on the speakers. The wattage does not make the amp loud but the speakers do...
    2203 is loud as shit. You will be evicted, good luck w/ that.
    For example: louder than a 747 taking off the runway...and permanent hearing loss.
  3. SGFA
    SGFA Member
    Mar 10, 2018
    98
    97
    Italy
    :D
    Yes but why differes from a 2555X or a SL-X? I mean, they are all master volume amps... or the JCM800 is of a different kind?
    With my other amps I use the MV at 12 o'clock and no attenuator and its fine, I need a lot of volume.
  4. riffpowers
    riffpowers New Member
    Oct 19, 2014
    13
    19
    I've had a few 2203 and 2204's and I honestly think tey are about the loudest amps ever.
    They have most of their volume before they reach halfway, I find the jubilee's are the opposite.
    I've never EVER had one up much past 3 !!
  5. Gunner64
    Gunner64 Well-Known Member
    Nov 16, 2013
    4,399
    4,646
    Midwest, USA
    I've had all 3. They all get holy fuck loud, but the 2203x does it quicker, and it's brightness ect.. makes it seem much, much louder overall.
  6. JacksonCharvelAddict
    Mar 4, 2016
    1,384
    1,253
    At Max volume both the 2555x and the 2203x should be skull crushing loud. The difference between them is the taper on the mast er as someone above mentioned. The 2555x you can run comfortably at about half way on the master but on the 2203x you would probably have the master on 3 instead. But both on 10 they should be about the same.
  7. marshallmellowed
    Jun 26, 2009
    2,921
    2,527
    Yes, I 2nd that. They are all loud when turned up, just different designs, with different levels of volume control sensitivity. The volume level of the Jubilee on 6, is comparable to the 2203 on 1 - 2.
  8. JacksonCharvelAddict
    Mar 4, 2016
    1,384
    1,253
    Both will get you a smile on your face and a warrant for your arrest for destroying the entire county..lol
    GuitarIV, SGFA, Gunner64 and 2 others like this.
  9. Jethro Rocker
    6,794
    6,348
    Yep I think these numbers are pretty close. 2 on a 2203 equals like 5+ on the Jube due to volume pot taper. As mentioned the rawness and openess of a 2203 would make it seem louder too.
    I agree with all.
    Mitchell Pearrow and SGFA like this.
  10. SGFA
    SGFA Member
    Mar 10, 2018
    98
    97
    Italy
    Thanks so much everybody for your answers! Pretty clear now!
  11. Chris-in-LA
    Chris-in-LA Active Member
    Jul 19, 2018
    507
    237
    Yeah, but volume at <1 on my 2203 is living room volume at my house. Between 1 and 2 if you want to piss off the neighbors. 2 to 3 for gigs and you might need earplugs. BTW I also play mine through a 2X12 loaded with V30’s.
  12. SGFA
    SGFA Member
    Mar 10, 2018
    98
    97
    Italy
    Actually i agree that the 2555x SJ has a very progressive volume knob. I have been playing a TSL 100w for years, and it went crazy loud well before then the SJ, in the scale of the knob.
  13. ampmadscientist
    11,981
    5,944
    Left Coast
    "I need a lot of volume..."
    Then you should buy a Verellen. Verellen is the loudest guitar amp on the planet.
    At least 2X 4X12 cabinets or 4 cabinets should do it.
    After you are arrested, the forum will pitch in and bail you out of jail.
  14. Mitchell Pearrow
    6,080
    7,926
    Never heard of it, what’s it sound like?
  15. ampmadscientist
    11,981
    5,944
    Left Coast
    Pretty clear now!
    Hearing aids will be the next stop on the journey.
  16. ampmadscientist
    11,981
    5,944
    Left Coast
    It's so loud, it will disable your hearing permanently.
    (it will pop the phone plug out of the speaker cabinet from the air pressure, no I am not joking)
    Is that good enough?
  17. Gunner64
    Nov 16, 2013
    4,399
    4,646
    Midwest, USA
    Verellen Meatsmoke ( no shit ) 300 watts. Sextet of 6550's.....good lord... sound guys are gonna be killing guitar players.
  18. Gunner64
    Nov 16, 2013
    4,399
    4,646
    Midwest, USA
    Simultaneous posts.:)
  19. Jethro Rocker
    6,794
    6,348
    Like an SVT for guitar.
  20. Gunner64
    Nov 16, 2013
    4,399
    4,646
    Midwest, USA
    2 ohm capable too.
