How do you setup 2 amps together?
Discussion in 'The Tone Zone' started by dinkyguitar, Nov 17, 2019.
  1. dinkyguitar
    dinkyguitar Active Member
    Jan 24, 2011
    174
    33
    Hi All,
    I've read about setting up 2 amps and I have a Boss Chorus & Reverb pedal.
    I see they have dual outputs, but from the articles I've read they say to plug into the input of each pedal, then use the outputs to each amp.
    Well, that's great and all but the articles don't cover the fact that these pedals go into the FX loop and plugging them into the front on my 5150 and 6505+ combo sound like $hit for lack of better terms.
    Do I have to run multiple cables into the FX loops of each amp?
    Or is there a better way of using these 2 pedals in the FX loop of both amps?
    dinky
  2. Lance Chambers
    Jun 23, 2019
    811
    1,149
    The Land That Time Forgot
    Zakk Wylde stated he pushes two amps with a stereo chorus straight in the front. Guitar World interview done many moons ago.:shred:
    El Gringo and Mitchell Pearrow like this.
  3. paul hancher
    paul hancher Well-Known Member
    Jan 25, 2019
    272
    475
    if your pedal has stereo inputs then yes you would have to run sends and returns for both amps to run thru the loops, which would also necessitate running a y-cord from your guitar to each amp input. i do not know of any other way of doing it.
    also are you aware that to run two amps together both amps must be in phase electrically and acoustically (speaker phase) for best results. if both amps are modern with 3 phase plugs electrical phase should not be a problem but you usually have to physically confirm that the speakers are in phase.
    Lance Chambers and tce63 like this.
  4. Lance Chambers
    Jun 23, 2019
    811
    1,149
    BTW! If you're mixing amps (different brands) be sure to ground lift one of them.
    WellBurnTheSky likes this.
  5. dinkyguitar
    Jan 24, 2011
    174
    33
    He's actually the one who gave me the idea since I'm starting to play some of his work again....
    And I saw his setup and got the chorus pedal for that reason, among other things. Haven't tried running through the chorus yet.
    But since I added a 5150 to my collection, I figured I'd try a 2 amp setup, pairing it either with the 6505+ combo, or EVH 5150 III.
    I did read about the speaker phase as well as the ground loop...but so far the ground loop isn't an issue, and flipping the ground lift on the 6505+ combo doesn't have any effect and I'm not getting any unusual noises.
    I'm just learning how to set all this up, and again, since I have multiple amps, I'd figure I'd give it a try but had questions.
    dinky
  6. Trelwheen
    Trelwheen Well-Known Member
    Nov 18, 2017
    1,504
    2,179
    Texas
    I use a Radial Switchbone when using two amps. It has a lot of nice features including a phase switch.
  7. SkyMonkey
    1,393
    1,536
    England
    Assuming CHORUS>REVERB and chorus has only 1 input.
    Depends if you want to keep the individual tones of the 2 amps.
    If not, then in the loop will give you the option of which to slave to the other. Place the pedals in the loop of one amp and run the 2nd out from the reverb to the return of the slave.
    That is how I run a VS65R slaved to my DSL40CR.
  8. Lance Chambers
    Jun 23, 2019
    811
    1,149
    The Radial Bigshot AB/Y is another great option also.:cheers:
  9. mirrorman
    mirrorman Well-Known Member
    Mar 30, 2014
    765
    949
    Canada
    A Radial Engineering Twinline is designed specifically to toggle one pedal board between the effects loops of two different amps.
    More info here: https://www.radialeng.com/product/twinline
    It might be what you're looking for.
  10. wakjob
    wakjob Well-Known Member
    Dec 29, 2011
    5,137
    3,361
    C-137
    This is the simplest and most affordable one I've used.
  11. Mitchell Pearrow
    8,798
    13,419
    In this clip I am running 3 amps.
    2 are the Origin 50H’s and a 3210
    Lead 100 mosfet.
    My means for doing so is an MXR10 band eq into the front of both Origin’s, they are connected to the A cabs, the mosfet is paired up with the 2 B cabs, to run the mosfet I am going fx send on the Origin with the white cab into the front instrument in on the mosfets clean channel.
    El Gringo likes this.
  12. mickeydg5
    23,255
    10,329
    I would think with all that distortion, 5150 and 6505+, at hand the chorus and reverb would be placed in the effects loop(s).
  13. Rudy v
    Rudy v Active Member
    Dec 12, 2018
    140
    152
    I use something different
  14. Rudy v
    Dec 12, 2018
    140
    152
  15. mickeydg5
    23,255
    10,329
    That term is already used. I do not like it. :)
  16. Rudy v
    Dec 12, 2018
    140
    152
  17. Rudy v
    Dec 12, 2018
    140
    152
  18. mickeydg5
    23,255
    10,329
    @Rudy v , you got too many rigs. :D
  19. Rudy v
    Dec 12, 2018
    140
    152
  20. Rudy v
    Dec 12, 2018
    140
    152
