Hi, I'm Bazza From Deepest Suffolk.
Discussion in 'Introduce Yourself' started by Bazza, Sep 5, 2018.
  1. Bazza
    Bazza New Member
    Aug 30, 2018
    7
    I’ve joined the forum today. Following a very long break from playing (around 35 years!) I picked up where I left off in 1973 and have recently joined a new functions type band. This means playing all sorts of music most of which I completely missed first time round so most songs are completely new to me. I use a Les Paul and a Strat (my preferred) and a recently acquired Marshall JCM 900 combo, the 4502 model with 2 x 12 Celestion speakers and have been building up my selection of effects pedals. The question I have regarding the amp refers to the very thin sound it has (on either clean or gain channels), it’s as though the amp is passing through a graphic equaliser with all low frequencies removed. Before I got the amp it was given a major service with new EL34 output valves, pots and some sockets / wiring and the bias was set however it really doesn’t kick as I’m sure it should, or maybe this is normal. In all honesty get a fuller frequency sound from my other Marshall, an MG100 solid state amp. I would prefer to use the JCM for upcoming gigs so does anyone have any suggestions, apart from using the MG? I looked on-line for any ideas and found this forum so I’m relying on you.
  2. Micky
    Apr 29, 2010
    19,629
    15,452
    Vermont
    Greetings!
  3. GIBSON67
    GIBSON67 Well-Known Member
    Sep 8, 2008
    8,352
    3,937
    Lakeland, TN
    Welcome to the forum, MFer!
    What speakers are in your combo? Does it sound better cranked? I've never owned a Dual Reverb so I have no real experience.
  4. Bazza
    Bazza New Member
    Aug 30, 2018
    7
    Hi there, thanks for the welcome. The combo has two 12 inch Celestion G12t-75 speakers which I believe is the usual spec for this amp. I noticed another correspondent has complained about too much bass on his amp, I have exactly the opposite problem. Any suggestions appreciated, thanks.
    Bazza
  5. Bazza
    Bazza New Member
    Aug 30, 2018
    7
    Forgot to mention that although it does sound better with lead tones when cranked there is still a lack of low frequencies which make the sound thin and lacking in ooomp if you know what I| mean.
    Bazza
  6. Dogs of Doom
    17,176
    15,066
    :welcome:to the forum...
    could the speakers be wired wrong?
    :cheers:
  7. Bazza
    Bazza New Member
    Aug 30, 2018
    7
    This would make the speakers out of phase which I agree could effect the bass response but the amp was professionally serviced before I got it and the speaker wires were renewed. Reversing one speaker connection however may be worth trying and I will give this a go and report back. Thanks
  8. Trident
    Trident Well-Known Member
    Mar 8, 2018
    600
    524
    Paradise in FLORIDA
    :welcome:.....
    Even a pro can have a bad day, it might be worth checking into....
    Enjoy the forum, alot of really good info here....
  9. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    9,381
    6,567
    Taintville
    Welcome to the forum!
  10. LRT#1
    LRT#1 Well-Known Member
    555
    616
    Hi and welcome to the forum
    I have a jcm 900 4100 half stack it came with 5881 pv that I had changed for el34s but have found that the tech had not changed the screen resistors to proper value
    Hope that's a start to help
  11. Nik Henville
    Jul 18, 2018
    364
    335
    Wotcher squire - welcome aboard.
    Now I am not the noob from Blighty any more :cheers:
  12. Mitchell Pearrow
    3,953
    4,011
    Welcome to the forum, if you’re talking about the 900, try a patch cable in the efx loop, and play with the level knob on the back, my buddy John ‘s amp woke up with this simple trick, his is a DR 50 head, but the same should apply to your amp as well. !!
    LRT#1 likes this.
  13. Mitchell Pearrow
    3,953
    4,011
    :welcome: To the best forum ever, new MF’r
  14. LRT#1
    555
    616
    The patch cable made a big difference on my 900 but better yet was the 7 band boss eq that I started running
  15. Mitchell Pearrow
    3,953
    4,011
    I do not have a 900of my own, but I was able to preform this test on my buddy’s amp and it worked, I am sure an eq in the loop would be awesome
    LRT#1 likes this.
  16. ampmadscientist
    10,271
    4,506
    In the rain.
    Bazza......wat's up? :cheers:
    https://drtube.com/schematics/marshall/cd0189-iss7.pdf
    What you can do to a 900 for more lows is:
  17. Coronado
    Coronado Well-Known Member
    Jan 2, 2013
    4,098
    3,529
    Dallas
    Dang, 35 years! That's one long break from playing! Welcome! :D
  18. ampmadscientist
    10,271
    4,506
    In the rain.
    Suffolk Virginia?
  19. Bazza
    Bazza New Member
    Aug 30, 2018
    7
    Hi guys, thanks for your various comments. Just to get a couple of responses out of the way its Suffolk, East Anglia UK. You're right 35 years is a long break, other stuff just got in the way until that mid-life moment and I didn't want to buy a Harley so got myself a Les Paul.
    I've tried reversing the connections on a speaker and it sounded dreadful so I guess the servicing guy did it right. Could you explain a bit more about the 'patch cable in the efx loop'. What should I do and what effect could I expect? Also thanks to amadscientist for the suggested modification, I'm not up to doing this myself but if all else fails could talk to local amp tech who may know how to do this. Its great to have contact with everyone and see your responses. Cheers.
  20. Bazza
    Bazza New Member
    Aug 30, 2018
    7
    Hi Herbert, Thanks for your suggestion. I've tried a cable connected from Send to Return in the Effects Loop and it makes absolutely no difference, and adjusting the level control (operated with a screw driver) also has no effect. I do have a simple pre amp booster pedal with treble and bass and volume controls and this improves the sound when connected into the loop but I don't think there's any difference in connecting this pedal via the loop or running it from my pedal board (without the need for a battery) straight into the main input. To my mind it should be unnecessary to do this but I guess I'll continue to do so, or change amps! Regards
    Bazza
