Help please - EL34 Red plate on 1 tube
Discussion in 'The Workbench' started by Deepstone, Aug 12, 2012.
  1. plexifier
    plexifier Active Member
    Aug 13, 2011
    515
    186
    Iowa
    Good call. We may not have the correct schem yet.
    Ricky: Got any schems that match the pictures?
    (Also note the "paper caps" that look like resistors, just to add to any confusion here. ;) )
    Deepstone:
    Which power tube red-plates (V4 with green wire to pin 5, or V5 with orange wire)? Did you try swapping the power tubes (V4 to V5 and vice-versa)? Since you've had the same problem with two sets of tubes, it's probably in the same socket but let us know.
    It may help if you post some voltage readings from both power tube sockets if you're comfortable doing so. Remove the power tubes first, power on and exit standby. Post voltages for pins 3, 4, 5 and 6. All are DC and can be measured at your meter's highest DCV setting (the yellow "500"). Be careful and ask if you're not sure about anything.
  2. Deepstone
    Deepstone New Member
    Aug 1, 2012
    26
    2
    California
    here is a link to a new pic with the circuit board number for rickylee...thanks
    click here
  3. mickeydg5
    21,227
    8,907
    That is a "C" board and I have not been able fo find a schematic that matches the board numbering.
  4. RickyLee
    May 22, 2010
    9,341
    2,816
    Riverside CA U.S.A.
  5. Deepstone
    Aug 1, 2012
    26
    2
    California
    Finally got the amp going tonight ..It was a bias resistor that had a crack that was hard to see...the one picture I had that showed the resistor jumpered on top of R48 was someones attempt at fixing it i guess? anyway put in a 220 resistor on R48 and it is working great now...thanks again for all the tips...Deepstone
  6. Deepstone
    Aug 1, 2012
    26
    2
    California
    :slash:
  7. mickeydg5
    21,227
    8,907
    Have fun. :thumb:
