Help me understand Ohms
Discussion in 'Cabinets & Speakers' started by Kolanti, Feb 23, 2020.
  1. Kolanti
    Kolanti Active Member
    Dec 9, 2019
    118
    151
    So I want to switch my two g12t75 speakers from my Marshall 1936 2x12 cab to Creamback 65.
    They are two versions one is 8ohms and the other 16ohms.
    The t75 now are 16ohms.
    What should I buy? Is there any difference in sound?
    Pretty much I don't understand what the impedance is lol.
    What do you suggest?
    SkyMonkey likes this.
  2. SkyMonkey
    1,763
    2,105
    Indoors
    A deeper explanation of Ohms is probably best left to someone other than me.
    For amps you need to know the range of the speaker jacks of your amp.
    A single jack is usually 16 Ohm.
    Then they can range from 16 Ohm down to 4 Ohm.
    The jacks may be switchable between Ohm ratings, or dedicated, like the newer DSL and JVMs.
    Speakers are usually single, paired or quads in a cabinet. Single or pairs in a combo.
    How you wire pairs and quads will determine the total load of the cab or combo.
    Single speaker cabs are solely determined by the speaker Ohms.
    Pairs can be wired in series or parallel.
    Series wiring adds the Ohms of each speaker together for a total load.
    e.g. 8 Ohm + 8 Ohm = 16 Ohm cab.
    You can't wire two 16 Ohm speakers in series because no guitar amp has a 32 Ohm speaker jack.
    The disadvantage of series is if one speaker blows, the open circuit leaves no load on the amp.
    Parallel wiring equals Ohms of the speakers (2x16 Ohm is just 16)/number of speakers.
    e.g. 16 Ohm/2 = 8 Ohms, for 16 Ohm pair of speakers in parallel.
    You can't wire two 4 Ohm speakers in parallel because no guitar amp has a 2 Ohm speaker jack.
    Parallel pairs are safer as if one speaker blows, the signal still runs through the remaining speaker(s).
    Quad are usually wired in a combination of series and parallel to bring the total impedance to the same as each individual speaker (normally 16 Ohms).
    A second switchable option is sometimes all 4 in parallel for a 4 Ohm load.
    So for your 1936 cab I would recommend getting two 16 Ohm Creambacks and using the original parallel wiring in the cab for an 8 Ohm load.
    KraftyBob, tce63 and Kolanti like this.
  3. pedecamp
    14,179
    10,861
    If you want plug and play and not have to rewire your cab get a pair of 16 ohm creambacks and pop them in. I dont believe there is any sound difference between 8 and 16 ohm speakers.
    MarshallDog, neikeel and tce63 like this.
  4. South Park
    1,752
    1,376
    Take the time to understand this stuff. Does your amp have a ohm switch. Two 16 ohm in Parallel comes out to 8 ohms. The ohms divide
    tce63 likes this.
  5. Nik Henville
    Jul 18, 2018
    1,361
    2,308
    Ohms is where the 'art is...
    SkyMonkey and tce63 like this.
  6. JTM1963
    JTM1963 Active Member
    Mar 6, 2018
    87
    101
    The G12G75's in your cab are 8 ohms and you want 8 ohms to replace them if you want the info on the back to match.
    The inputs at the back of cab are labeled 16 ohm in mono and 2 x 8 ohm in stereo.
    Two 8 ohm speakers in series equal 16 ohm.
    If you were to put two 16 ohm speakers in your cab and wire them the same you would get 32 ohm in series (mono) and 2 x 16 ohm in stereo. 32 ohm is out of bounds for your amp.
    tce63 and RLW59 like this.
  7. Lance Chambers
    Jun 23, 2019
    1,206
    1,820
    The Land That Time Forgot
    Basic survival guide: Never connect a lower Ohm rated cab to a higher Ohm rated amp output.:agreed:
    General guideline: As long as the cabinet Ohms are higher than your amp output you will not damage anything.:fingersx:
    Mauro and tce63 like this.
  8. Michael Roe
    Michael Roe Well-Known Member
    Mar 25, 2017
    1,663
    3,933
    Springfield, Ohio
    Simple...…..replace with the same 16 Ohm.
    FracStrat and tce63 like this.
  9. Valvelust
    Valvelust Well-Known Member
    Feb 9, 2010
    508
    270
    In the midst of trees
    tce63 likes this.
  10. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    637
    502
    Everyone else ran with the initial claim that the G12T75's in the cab are 16 ohms each. But that claim came from someone who says he doesn't understand ohms at all.
    If a 2x12 cab is 16 ohms, the speakers can not be 16 ohms each. If the cab is stock with a stereo/mono switching jackplate, 16 ohm mono and 8 ohm each side in stereo, then each speaker is 8 ohms.
    Kolanti, please clarify what you've got. Is the cab stock, and does the label say "mono 16 ohms"? If so, then you need 8 ohm replacement speakers.
    neikeel likes this.
  11. ampmadscientist
    16,805
    10,708
    This is my ohmland, the place I was born in.
    No matter where I ohm, it's in my soul.
    My feet may wander, a thousand places.
    My heart will lead me back ohm, to my Donegal.
    Nik Henville likes this.
  12. Kolanti
    Dec 9, 2019
    118
    151
    I’m even more confused now haha xD
    Musicmaniac likes this.
  13. Musicmaniac
    Musicmaniac Active Member
    Apr 10, 2013
    144
    171
    :lalala: Me too!
    tce63 likes this.
  14. South Park
    1,752
    1,376
    A parallel circuit the ohms divide a series circuit the ohms add. If un sure measure the jack for ohms.
    Sustainium likes this.
  15. MickeyJ
    MickeyJ Well-Known Member
    Nov 11, 2019
    1,062
    578
    cant any of you amp dogs explain this?
    ohm was named after georg ohm.
    an ohm is just a unit of resistance.
    think of it as one litre of milk.
    think of it as 1000 meters
    it's just a unit of measurement.
    Someone had to call it something, ohm is perfect because it's just three letters.
    Electricity doesn't pass through conductive things at the same rate.
    The quickness or slowness that electricity passes through whatever it is had to have a unit of measurement labeling it because without that anyone trying to copy a design/design a circuit/ create a thing like a speaker would be screwed.
    For example, the two terminals on your speaker are actually just one wire ( inside the speaker) wrapped around and around something. one speaker which is 16 ohms has that wire as having 16ohms of resistance, another speaker which is rated at 8 ohms only has 8 ohms resistance on that one wire. ( one wire, two terminals , one at each end of the wire.)
    mAx___ and tce63 like this.
  16. MickeyJ
    Nov 11, 2019
    1,062
    578
    do otherwise identical speakers with different resistance ratings sound different if set up with the the correct jack on the back of the amp?
    the answer to this is not clear. Some say yes, some say B.S
    Back your question, you need to buy 2 x 16 ohm speakers for your amp.
  17. MickeyJ
    Nov 11, 2019
    1,062
    578
    imagine two straws, one is harder to blow through than the other, one has more resistance, now imagine the air as electricity, and the straw as a wire.
    mAx___ and Kolanti like this.
  18. RLW59
    Nov 30, 2017
    637
    502
    Sorry I 'm a dumbass and misunderstood. I thought all 1936 cabs were 16 ohm. If this is an 8 ohm 1936 then yes it has two 16 ohm speakers.
    What amp and what impedance outputs does it have? Do you ever want to add another cab, running both from the same amp?[/QUOTE]
  19. Valvelust
    Feb 9, 2010
    508
    270
    What is it you're actually wanting to know?
    One way to look at it to help confusion.
    The larger the number the "more resistance" the lower the number the "less resistance" (one's mind would think it should be the opposite) A 4 gauge wire is bigger in diameter than a 16 gauge wire. (Big round straw vs Small round straw)
    Like flow of water per say, if a hole was the size of a large 4 gauge wire it would have less resistance and flow more water than a smaller 16 gauge hole would flow.
    A sewer line pipe will have less resistance and flow more water than a water line pipe.
    Weird analogy but principle somewhat the same
    Lance Chambers likes this.
  20. FracStrat
    FracStrat Well-Known Member
    Jan 22, 2020
    278
    724
    Water Side of WA State
    “ohms” is not a real word
