Help me date this Combo Shell
Discussion in 'Let's Talk Vintage' started by 69ChevyP/U, Nov 5, 2019.
  1. 69ChevyP/U
    69ChevyP/U Member
    Oct 6, 2013
    78
    36
    Hello,
    I recently acquired an older Marshall Combo shell. It has the basketweave or salt and pepper grill cloth. My best guess is 1970. Most I see have checkerboard cloth in the 71 & up range.
    The speakers are from a different cab.
    The cab measures 9” deep.
    I may flip, or just use as a 2x12 cab. No immediate plans to build an amp for it, but a person sure could..
    Just like to know what I have-
  2. GIBSON67
    GIBSON67 Well-Known Member
    Sep 8, 2008
    8,724
    4,469
    Lakeland, TN
    Late 70's elephant tolex, grill cloth was probably replaced. Pics are small but those look like Blackbacks.
    Trapland likes this.
  3. metromutt
    metromutt Well-Known Member
    Jul 15, 2009
    683
    274
    England
    70's combo shell, grill has been replaced. Back end of the 70's into the 80's they stopped putting the gold piping on. I had two 80's shells I struggled to sell (in the end I sold both for £60, they were a bit battered!).
  4. 69ChevyP/U
    69ChevyP/U Member
    Oct 6, 2013
    78
    36
    Yes, I sourced the speakers separately, they are Blackbacks.
    Not positive on the grill cloth. It does not look new at all. It is significantly faded.
    Is it possible that it’s more like 74’ with original grill?
  5. mcblink
    mcblink Well-Known Member
    Feb 25, 2013
    4,040
    4,889
    Have you tried bringing it flowers and asking it out?
    Peter McAteer and Micky like this.
  6. Micky
    Apr 29, 2010
    20,440
    16,688
    Vermont
    Sometimes chocolate works too. Also - Get in good with her parents.
    Peter McAteer and mcblink like this.
  7. GIBSON67
    Sep 8, 2008
    8,724
    4,469
    Lakeland, TN
    Salt & Pepper cloth stopped in the 60's, and it would be vertical not horizontal.
    69ChevyP/U likes this.
  8. 69ChevyP/U
    69ChevyP/U Member
    Oct 6, 2013
    78
    36
    It is vertical, not horizontal.
    GIBSON67 likes this.
  9. GIBSON67
    Sep 8, 2008
    8,724
    4,469
    Lakeland, TN
    Yes, you are right! The picture is turned 90 degrees. Elephant would have black or basketweave.
    Let's see the insides and the grill cloth overlap, that's usually how you tell.
  10. Obi Plexi-nobi
    Obi Plexi-nobi Well-Known Member
    Nov 22, 2016
    258
    305
    Looks exactly like my 1976 combo, except yours has had replacement grille & the later JCM (1981?) handle (possible replacement as well?). I think the gold piping stopped in the late 1970's, so I'm guessing 1976 with newer handle & grille.
  11. Obi Plexi-nobi
    Nov 22, 2016
    258
    305
  12. 69ChevyP/U
    69ChevyP/U Member
    Oct 6, 2013
    78
    36
    Thanks for the input-
    Obi Plexi-nobi likes this.
  13. Obi Plexi-nobi
    Nov 22, 2016
    258
    305
    I'd order one of those replica 'old-style' Marshall handles, maybe 'pre-age' the gold chrome it a tad if you are wanting to make it look stock... Of course the one on there is fine. :dude:
  14. Trapland
    Trapland Well-Known Member
    Dec 5, 2013
    1,175
    1,007
    Minneapolis
    The inside grill overlap looks too neat for Marshall.
  15. jcm800gridlock
    jcm800gridlock Well-Known Member
    May 16, 2010
    1,592
    1,177
    Tampa, Fl. USA
    I believe that the OP’s cab is a mid to late 70’s JMP combo cab.
    I’ve owned mid ‘70’s to early 80’s (‘76, ‘77, ‘79, and ‘81) Marshall JMP combos and the OP’s cab looks very similar.
    My early 70’s Marshall combo cab is entirely different.
    My early 70’s Combo.
    My 1976 Marshall model 2100 Lead/Bass
  16. MonstersOfTheMidway
    May 1, 2008
    4,894
    2,405
    Pointers for dating a combo:
    *When dating a combo, create a relaxing environment. Remember what Bill M said: for relaxing times, make it Suntory time!
    *When "dating" a "combo" (hopefully twins but best friends works too), ya gotta check the "outputs" for cleanliness (unless you like it a little dirty/rust for texture).
    *When you're playing with the "combo," I think its advantageous to turn yourself into an ABY box and play through both at the same time: the versatility will keep everyone happy though make you a little tired.
    *Try to keep the lights on because all the switching, tweaking/adjusting, and maneuvering it easier to do when you can actually see.
