Help determine which lamps are in the 6100.
Discussion in 'Marshall Amps' started by Pavel125DV, Feb 19, 2020.
  1. ampmadscientist
    17,852
    11,888
    Are you talking about the lighted power switch?
    Or are you talking about the LED panel lamps?
    Or are you talking about the vacuum tubes which light up?
    I think you are calling the vacuum tubes "lamps," and that makes it sort of confusing?
    If you need to identify which vacuum tubes belong in which version:
    A. You check the value of the screen grid resistors for the output tubes.
    B. You check the bias adjustment circuit resistors.
    C. You check the bias split resistors.
    After you know which resistors are installed: then you will know which output tube belongs in the amplifier.
  2. Pavel125DV
    Pavel125DV Member
    Feb 19, 2020
    41
    24
    I meant EL34 and 5881. Power amplifier tubes.
  3. Jethro Rocker
    7,905
    9,032
    6100 uses multiple 12AX7 in preamp. Has a different arrangement for each channel. It is NOT a solid state amp. Good grief.
    Kinkless Tetrode likes this.
  4. ampmadscientist
    17,852
    11,888
    You check the resistors (output tube) as above.
    The resistors tell you which tubes belong in the amp.
    If you have 470 ohm 5 watt screen grid resistors, the amp was built for 5881.
    The 5881 version has 2X 150K bias split resistors.
    In the 5881 version you will find a 51 volt zener diode in the bias adjust circuit.
    "These amps use 7x ECC83 and 4x EL34 tubes. Originally these amps were fitted with Tesla EL34's, but late 1993 Marshall switched to 5881 tubes. The ECC83's were Chinese."
  5. Nik Henville
    Jul 18, 2018
    1,499
    2,617
  6. Ken Underwood
    Oct 16, 2013
    551
    1,381
    Annesley North Notts UK
    Good to be here mate, but lamps or Pipes yes it does matter when we are talking technical
    Sir Don likes this.
  7. Ken Underwood
    Oct 16, 2013
    551
    1,381
    Thats all very well if you know the resistor color code. lol
    marshalltsl and scozz like this.
  8. scozz
    scozz Well-Known Member
    Jul 20, 2008
    3,229
    7,330
    Let me say Mr. Underwood, it is an honor and a privilege to have you as a member of this forum!
    Nik Henville likes this.
  9. Ken Underwood
    Oct 16, 2013
    551
    1,381
    Scoz, and every one else for that matter, please please please call me Ken, not Mr Underwood, thats far to formal.
    I only get called Mr Underwood when i am in trouble lol
  10. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    1,010
    711
    Ok, Ken, I definitely hear you and will drop the fawning attitude.
    FracStrat and Ken Underwood like this.
  11. Sir Don
    Sir Don Well-Known Member
    Aug 9, 2009
    1,374
    914
    Adelaide, South Australia
    Good to see you back here Ken, your contributions are valuable.
    FracStrat and Nik Henville like this.
