HELP! Amp making no sound + squeal
Discussion in 'The Workbench' started by JM5010, Nov 25, 2019.
  1. neikeel
    3,650
    2,074
    Depends on your plate voltage and current draw.
    Remember that pin 5 voltage is negative. The less negative the hotter it is.
    If your plate voltage is 450v and they are EL34s then -45 is a ball park figure.
    JM5010 likes this.
  2. JM5010
    JM5010 Member
    Nov 11, 2017
    135
    22
    Thanks, i’ll rebias to -45V.
