Headshell for DSL40c?
Discussion in 'Marshall Amps' started by ledvedder, Jun 28, 2019.
  1. ledvedder
    ledvedder Active Member
    Jan 13, 2011
    383
    87
    New Jersey
    Does anyone make a headshell for the DSL40c?
  2. Jon C
    Jon C Well-Known Member
    May 29, 2017
    1,092
    1,806
    Wa State
    BftGibson, KraftyBob and BanditPanda like this.
  3. KraftyBob
    KraftyBob Well-Known Member
    Sep 5, 2017
    925
    981
    Chicago Suburbs - USA
    Anyone know if you can buy a faceplate for the DSL100 (H/HR depending if you have the C/CR)? It looks like they are exact opposites - aside from maybe needing to trim the length of the 100.
    Then you could flip the 40 chassis and put on the 100 faceplate. And maybe do something with the wattage on the label.
  4. BftGibson
    BftGibson Well-Known Member
    May 28, 2018
    1,108
    2,673
    KraftyBob and Mitchell Pearrow like this.
  5. Mitchell Pearrow
    6,924
    9,457
    Excellent idea, the 40c will also fit in the lead 100 mosfet head shell, but inverted.
    Cheers Mitch
    KraftyBob likes this.
  6. Dogs of Doom
    18,620
    17,893
    if you took in your original faceplate, & explain what it is you want done, any trophy/plaque/engraving shop should be able to make you a flipped plate, w/ the correct labeling...
    Mitchell Pearrow and KraftyBob like this.
  7. KraftyBob
    Sep 5, 2017
    925
    981
    You did nice work - looks great. I’d have no problem doing that to mine, but thought if we could invert it, it would follow same orientation as other Marshall heads with the controls on the bottom.
    Just a thought
    CraigP and BftGibson like this.
  8. KraftyBob
    Sep 5, 2017
    925
    981
    Hewat
    Great idea! Something to check into if/when I decide to do this.
  9. Dogs of Doom
    18,620
    17,893
    yeah, then you can just have Sourmash make you a box.
    I'm a firm believer in keeping the original box, incase you want to sell it as original, you still have that option. Just wrap the cabinet in plastic/cellophane, box it up & store it in a dry place...
  10. Mitchell Pearrow
    6,924
    9,457
    And with that you could also have them make it go to 11 :agreed:
  11. Len
    Len Well-Known Member
    Sep 13, 2009
    985
    748
    Stage Craft. After they made mine they started offering it as a regular catalog item.
  12. Dogs of Doom
    18,620
    17,893
  13. ampmadscientist
    12,705
    6,585
    Left Coast
  14. ampmadscientist
    12,705
    6,585
    Left Coast
    That's what I was thinking just now...
  15. Dogs of Doom
    18,620
    17,893
    or, you could use my photoshopped version, to illustrate the dial by time. I turned it to the 11 o'clock position... :)...
  16. Mitchell Pearrow
    6,924
    9,457
    That’s cool Dogs, but my old eyes would stare to long at it.
    Cheers Mitch
    Dogs of Doom likes this.
  17. Dogs of Doom
    18,620
    17,893
    I made that because someone was ranting about people using the clock system for telling you their settings...
    The 900 series had 1-20 on their pre-amp, & there's always the Spinal Tap joke (11). So, on the 900, 10 would be at the 12 o'clock position, not 4 o' clock, or cranked up all the way. Dimed doesn't have the same meaning when the amp goes to 20...
    The problem comes though, when someone uses the clock, but just says "3", as most would take that as 3 on the dial, not o' clock...
    so, that was my joke response...
  18. Mitchell Pearrow
    6,924
    9,457
    I got it bro and was just trying to extend it, I always try and say by the dial.
    :cheers:
  19. Jon C
    May 29, 2017
    1,092
    1,806
    Wa State
    That’s the 401 …… And yes …… Micro Venturi Nitrogen Injector Arrays
  20. recto-robbie
    recto-robbie Member
    Jul 19, 2007
    53
    15
    Chicago
    Thanks guys, headshell sold.
