Haze 40 Bias Voltage Issue
Discussion in 'The Workbench' started by PapaJ, Jan 11, 2018.
  1. PapaJ
    PapaJ New Member
    Jan 11, 2018
    7
    Hi everyone, hoping to get some help here. Recently acquired this Haze 40, had a bad power tube so I ordered a matched pair of EH EL34s to pop in. Go to set the bias and I get no voltage between pins 1 & 2 of con3, and about 40mv between 2 & 3. No amount of fiddling with the bias pots changes the reading between 1 & 2. Any ideas where to start? Nothing obviously burnt on the board, plate voltage measures about 460V. If I measure resistance between the pins I get 1.3 ohms between pins 1 & 2 and 2 & 3, and double that between pins 1 & 3. Thanks in advance for any help.
  2. Micky
    Apr 29, 2010
    18,658
    14,476
    Vermont
    Swap the power tubes and measure again.
    If it follows the tube it may be bad.
  3. PapaJ
    PapaJ New Member
    Jan 11, 2018
    7
    I will try that and report back. Would be unfortunate as they are new tubes.
  4. PapaJ
    PapaJ New Member
    Jan 11, 2018
    7
    Ok, switched tubes around. No change in readings.
  5. thanasisg6
    thanasisg6 New Member
    Jun 21, 2017
    17
  6. thanasisg6
    Jun 21, 2017
    17
    if is this the correct schematic you can not mesure on pin 1&3 negative dc voltage ,you should mesure only dc ma between 1&2 and 3&2 with the negative probe on pin 2.In this case you should read 39ma wich means 0.039V (V=R*I)on R26,R42 and your EL34s will have the correct bias voltage.Be careful the 39ma is the appropriate reading for the AB CLASS FIXED BIAS and for 70% max safe dissipation ,for 460V anode and 25w EL34 anode dissipation.You can mesure the negative bias voltage if can varying ,in the front end of R39,R50.If there is not varying negative voltage ,you have problem on bias power supply.BE CAREFUL THE HIGH VOLTAGES THEY ARE LETHAL!!!!! good luck
    https://robrobinette.com/Tube_Bias_Calculator.htm
  7. thanasisg6
    Jun 21, 2017
    17
    check also the D9,D13 .If you can unsolder each one end ,and check for sort circuit
  8. PapaJ
    PapaJ New Member
    Jan 11, 2018
    7
    Thanks for the reply. Everything I've read about biasing these amps says to read the mv across the pins, which will equal the mA due to the 1 ohm resistor, and Ohm's law of course. I will check those diodes if possible.
  9. Micky
    Apr 29, 2010
    18,658
    14,476
    Vermont
    Correct you should read no voltage between pins 1&3.
    You should read mv (millivolts DC, not ma...) between 1&2 and 2&3.
  10. PapaJ
    PapaJ New Member
    Jan 11, 2018
    7
    I do get voltage between pins 1&3, about 35mV with the negative lead on 1 and positive on 3.
  11. Micky
    Apr 29, 2010
    18,658
    14,476
    Vermont
    Check the diodes previously mentioned, as well as the big 5W resistors R56 & R58.
  12. PapaJ
    PapaJ New Member
    Jan 11, 2018
    7
    R58 is open, guess that's a good place to start. Unfortunately don't have a stash of 5W resistors sitting around. Will have to wait until I get a replacement. Thanks for the guidance.
  13. PapaJ
    PapaJ New Member
    Jan 11, 2018
    7
    I lied, just found a couple of 5W 500ohm resistors in my parts drawer. Can put them in series to replace the 1K in R58, if they will fit.
  14. thanasisg6
    Jun 21, 2017
    17
    of course!!!!!!!!!!!!
