Having an issue with 2203x effects loop
Discussion in 'The Workbench' started by loneguitar, Apr 2, 2015.
  1. loneguitar
    loneguitar New Member
    Apr 2, 2015
    8
    New to the forum and just recently back into the Marshall realm after being Marshall-Less for several years. I recently traded for a JCM 800 2203 Reissue and have run into a problem. I the past two times I have played it, it has been fine for a little while then all output cuts. No sound at all. It is getting power just no sound. I have narrowed it down to the effects loop. Since I have unplugged the cables from the jacks it has been running fine. Has anyone heard of this?
  2. Micky
    Apr 29, 2010
    20,106
    16,130
    Vermont
    Could possibly be what you have plugged into the loop.
    Why do you think it is a problem with the amp?
    mickeydg5 likes this.
  3. loneguitar
    Apr 2, 2015
    8
    The only thing that was plugged in was my MXR Carbon Copy. I had it in the loop of my Mesa before with no issues. So I am just assuming it's the amp.
  4. mickeydg5
    21,219
    8,902
    If you place a patch cable from SEND to RETURN does it cut out the same way?
  5. loneguitar
    Apr 2, 2015
    8
    I didn't think to try that. I will try that Saturday and report back.
  6. mickeydg5
    21,219
    8,902
    Make sure to test with good patch cables.
  7. loneguitar
    Apr 2, 2015
    8
    Played with a patch cable today for a short period of time and all was fine. I will try again tomorrow. If it is fine with the patch I guess that narrows it down to the Carbon Copy. Any ideas what could be happening there?
  8. mickeydg5
    21,219
    8,902
    It could be a pedal innards, the jack connections or whatever cable you had been using. Check and clean everything.
  9. loneguitar
    Apr 2, 2015
    8
    Played for 2 hours today with patch cable in the fx loops. No issues. The carbon copy worked fine in front of the amp though not my favorite way. I guess I will check cables next. Unless for some reason this pedal just doesn't like the loop, which I dont know if that's possible. We shall see. At least it's not the amp
  10. dptone5
    dptone5 Well-Known Member
    Jan 31, 2010
    5,113
    3,658
    Pennsylvania
    I run the following in the loop of my 2203X with absolutely no issue:
    Boss Chorus --> MXR Carbon Copy --> Lee Jackson Mr. Springgy Reverb --> Monte Allums Modded Boss GE-7 EQ
    What level setting do you have your loop on? +4 dB or -10db
    From what I understand, +4dB is best for pedals and -10dB for rack mounted FX units.
    Hope this helps.
    DP
  11. loneguitar
    Apr 2, 2015
    8
    That actually does help. I have been running it at -10db (button in). I will try it the other way.
    dptone5 likes this.
  12. dptone5
    Jan 31, 2010
    5,113
    3,658
    Pennsylvania
    Please let us know if this helps the situation.
    DP
  13. dptone5
    Jan 31, 2010
    5,113
    3,658
    Pennsylvania
    I have to apologize my friend, I had the answer backwards. Please see the link below. Apparently it is -10dB for pedals. I've been running mine at +4dB with no issues. It does state that one should experiment to see what gives the best tone.
    DP
    Marshall FX Pedals | FAQ | Marshall Amps
