Grounding Shield Of Coaxial Wire Shorts Input
Discussion in 'Building the Classics' started by mAx___, Mar 4, 2019.
  1. mAx___
    mAx___ Active Member
    Apr 3, 2012
    403
    142
    Hi,
    I was installing a shielded wire from Hi Input I to the 68K resistor in the board on a 100w Major build. I did the pigtail ground thing -on one side only- and wired it to ground on the input jack. The central wire goes from the input jack to the 68K resistor. No sound. If I disconnect the shield from ground, sound is back. I don't get it, I did the exact same thing on another build and it works fine. What am I missing?
    Thanks.
  2. mickeydg5
    20,048
    7,921
    The core wire is probably shorting to the shield and ground somewhere. Amplifier OFF, check things with resistance measurement of a multimeter.
    Or bad wire or bad connections. Again check with multimeter.
    :photos: please
  3. ampmadscientist
    11,599
    5,651
    Left Coast
    Somewhere the shield is shorted to the center wire.
    mAx___ likes this.
  4. mickeydg5
    20,048
    7,921
    What did you just say?
    I do not understand.
  5. Micky
    Apr 29, 2010
    19,860
    15,794
    Vermont
    He only reads the titles of threads, not the posts after that...
    neikeel likes this.
  6. mAx___
    Apr 3, 2012
    403
    142
    Thanks so much guys. I tried using 3 different wires and the problem was still there. It baffles me. But the amp is so silent as is that I ended up not grounding that short wire.
  7. mickeydg5
    20,048
    7,921
    :squint: :scream: :lol:
  8. mickeydg5
    20,048
    7,921
    You have to be careful with the different types of shielded cable. Depending on the handling and dressing some can short the shield to core if not handled or truncated properly.
    I do not know what type of cable you have used or how you dressed it.
  9. mAx___
    Apr 3, 2012
    403
    142
    I think you found the reason. I just checked and two of the cables had a shorted shield to core! I guess I was bending them too much because of the short distance between the jack and the turret board?
    I had no idea this could happen, I guess I was lucky with my other build...
    Removing the unshielded wire from the amp and trying to fit a new one in that tiny space would be a real pain...is it too bad if I leave it as is?
  10. Timbo
    Timbo Member
    Oct 29, 2009
    95
    95
    How long is the length of cable?
  11. mAx___
    Apr 3, 2012
    403
    142
    Around 6cm or 2”, more or less.
  12. ampmadscientist
    11,599
    5,651
    Left Coast
    Soldering can melt the plastic inside the shielded wire.
    This can short the center to the outside shield.
    mAx___ likes this.
  13. mickeydg5
    20,048
    7,921
    You know when I read the first post I almost asked "Why a shielded cable there?"
  14. mAx___
    Apr 3, 2012
    403
    142
    The amp has an extra gain stage, I saw some layouts for this mod used a shielded cable so I went for it.
  15. neikeel
    3,047
    1,501
    - for long runs on the grids it is useful, particularly if running from sockets to front switches or pots, it can dull the sound (cheap high capacitance wires), equally can tame some icepick frequencies too.
    - use it sparingly tho'
    mAx___ likes this.
  16. Timbo
    Timbo Member
    Oct 29, 2009
    95
    95
    I would use a standard wire and see if that works.
  17. mickeydg5
    20,048
    7,921
    How about a picture and make of the wire used?
  18. mAx___
    Apr 3, 2012
    403
    142
    I posted a pict of the wires yesterday, look up my post up in the thread. I couldn't see the make but it's the one that Valvestorm sells.
  19. mickeydg5
    20,048
    7,921
    Ah, haa! I past over that little picture because I though it was just something in your signature.
    I see you pulled back the outer cover and shield on that side but cannot get a good view of the other ends or tell what is under the shrink. That is the ticket with those to separate the core/core jacket from the shield/outer jackets. If you cut or even puncture the core jacket --- start all over.
    I usually prep both ends and then put a multimeter on it to test before installation. Then I test after installation.
    mAx___ likes this.
  20. ampmadscientist
    11,599
    5,651
    Left Coast
    High gain extra input stage. The shielded wire keeps the spurious noise lower.
