Greenback Question ?
Discussion in 'Cabinets & Speakers' started by Peter Pav, Feb 24, 2020.
  1. Peter Pav
    Peter Pav New Member
    Sep 2, 2013
    26
    23
    I'm modifying my Origin 20c by putting a 12" speaker in place of the stock 10" v-type junior. The V-type Junior is rated at 50watts but only weighs 3.5lbs. A 12" Greenback is 7.9lbs but is rated at only 25watts. Will a Greenback be able to handle the volume of the Origin 20c ?
  2. RatDaddy
    RatDaddy Active Member
    Feb 21, 2020
    113
    202
    Is the 20C ..20 watts? Sure. The 50 watt was just extra the way I see it.
  3. Scumback Speakers
    Sep 16, 2016
    753
    1,023
    Los Angeles, Ca
    If you crank that Origin or hit it with a boost or a fuzz pedal, I'd bet your G12M 25w won't last very long.
  4. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    5,499
    5,982
    Montreal
    Should be ok if you don't crank it. The amp may easily crank more than 20W.
    bp
    scozz likes this.
  5. Matthews Guitars
    1,389
    1,754
    All amps are rated for clean power. In heavy overdrive they can deliver about twice that power rating, if not more.
    A healthy "100 watt" Marshall Plexi spec super lead can put out 220 watts of electrical energy to the speakers when absolutely dimed out.
    A "20 watt" amp can put out over 40 in distortion.
    scozz, Metroman and Scumback Speakers like this.
  6. mickeydg5
    mickeydg5 Well-Known Member
    24,016
    11,010
    Yes.
  7. Peter Pav
    Sep 2, 2013
    26
    23
    The G12H Anniversary is 30watts I'll probably go for that just for the extra 5 watts. Obviously there are 12's that are rated for more power but I don't like any of them.
  8. mickeydg5
    24,016
    11,010
    Did you try a Marshall type Vintage G12V type? They are the best among ceramic unless you would consider spending the $$$ for real AlNiCo.
  9. Scumback Speakers
    Sep 16, 2016
    753
    1,023
    Los Angeles, Ca
    This amp is a dual EL34 power tube amp with three 12AX7's, plus a boost mode. I find it very hard to believe that it's so crippled through the circuit that it is only 20w max. Does anyone in Los Angeles have one of these? I'd be curious to test one out against some 30w amps and see how much it compares.
    The Marshall site is not giving up any wattage measurements with the boost engaged, from what I can see.
    https://marshall.com/marshall-amps/products/amps/origin/origin20c
    scozz likes this.
  10. stickyfinger
    Nov 11, 2010
    626
    256
    Just use the lower wattage mode?
    I be skeptical with dual el34s.
    scozz likes this.
  11. Peter Pav
    Sep 2, 2013
    26
    23
  12. Peter Pav
    Sep 2, 2013
    26
    23
    Yes didn't like it. Alnico Cream is a definite possibility. The Neo 250 is nice because it's light and sounds good.
  13. GIBSON67
    GIBSON67 Well-Known Member
    Sep 8, 2008
    8,806
    4,572
    Lakeland, TN
    A vintage G12-65 would be a great fit and is the best 1x12 combo speaker, imo.
    Valvelust and Musicmaniac like this.
  14. pedecamp
    14,094
    10,713
    Creamback! :yesway:
    scozz and tce63 like this.
  15. Metroman
    Metroman Well-Known Member
    Apr 29, 2014
    756
    442
    Scumback H75 PVC 100w. I hate speaker funny business, and like all the extra thermal protection I can get.
    Scumback H55 PVC 65w
    Scumback 65w S75 PVC
    150w Celestion G12H Redback.
    90w Celestion Cream/Alnico
    Rawson Sparfield Starfinder 100w
  16. Dogs of Doom
    20,585
    21,329
    there was a thread here somewhere, where it was disclosed, during testing (pre-production) the studio series were pumping out, like 22 watts +/-. I'd be willing to bet that the same method of power was used...
    The SL5 uses a single EL34 & puts out 5 watts...
  17. scozz
    scozz Well-Known Member
    Jul 20, 2008
    2,695
    6,141
    Once again I'm with @pedecamp,...Creamback 65. I'm not a fan of a Greenback as a single speaker, yeah they sound great in a 2-12 or a 4-12, but NOT as a stand alone speaker imo.
    proxy and pedecamp like this.
