Going to see if I can run EL34s in my 6550 JMP50
Discussion in 'The Workbench' started by The Grim Peeper, Jan 15, 2020.
  1. The Grim Peeper
    The Grim Peeper Active Member
    Jul 11, 2010
    763
    164
    I got my volt meter and bias probe ready. I just need a little refreshing. I’m about to test plate voltage. I have the EL34s in place. So I just let it warm up under speaker load for 5 minutes and test the pin with the white square cap across it with black lead on chassis for grounding right?
  2. ampmadscientist
    14,866
    8,725
    It won't work until you change the bias range resistor, the current will be too low.
  3. The Grim Peeper
    Jul 11, 2010
    763
    164
    But I’ve heard that sometimes there is enough range for both tube types without modifying. Just rebiasing
  4. ampmadscientist
    14,866
    8,725
    The worst that will happen is the tube will be too cold.
    DonP likes this.
  5. The Grim Peeper
    Jul 11, 2010
    763
    164
    Ok I’ll try it then. I’ll let you know what the PV is and what the bias probe says
  6. The Grim Peeper
    Jul 11, 2010
    763
    164
    Tubes are glowing and it is reading zero.
  7. The Grim Peeper
    Jul 11, 2010
    763
    164
    I put the 6550s back in and still 0 DC
  8. The Grim Peeper
    Jul 11, 2010
    763
    164
    Only one 6550 is glowing. There’s a slight glow in the dead one near the base.
  9. scott-colorado2016
    scott-colorado2016 Active Member
    Jan 7, 2017
    189
    221
    Colorado, USA
  10. The Grim Peeper
    Jul 11, 2010
    763
    164
    Ok Scott givit to me strait.
  11. The Grim Peeper
    Jul 11, 2010
    763
    164
    Something is not feeding the amp voltage.
  12. The Grim Peeper
    Jul 11, 2010
    763
    164
    But the tubes are glowing.
  13. junk notes
    junk notes Active Member
    Dec 10, 2018
    207
    192
    Bias selector
  14. The Grim Peeper
    Jul 11, 2010
    763
    164
  15. The Grim Peeper
    Jul 11, 2010
    763
    164
    That’s the 120k I see close to the trim pot.
  16. The Grim Peeper
    Jul 11, 2010
    763
    164
    The amp turns on and the tubes light up.
  17. The Grim Peeper
    Jul 11, 2010
    763
    164
    But there’s got be another reason I’m not getting any voltage. I had the best tech in the world but ge retired. I think I’ll leave it alone till I find a new one.
  18. scott-colorado2016
    Jan 7, 2017
    189
    221
    Colorado, USA
    Sorry, I'm not the one to ask, I'm a troubleshooter, but I've never seen a JMP50 in person.
    The amp was working before you did something, then you did something, and the amp stopped working, that's a Scooby "rut row" to me... and, one I've done before.
    Patience, there will be someone to come around to help. Ampmadscientist already offered some advise earlier.
    What is the bias selector for? Hard to tell from the picture. Did you have the bias probe in correctly? Maybe blew the HT fuse. Do you have a meter to check the fuse?
  19. The Grim Peeper
    Jul 11, 2010
    763
    164
    Arg I’m too damn stupid. I changed the fuses. I had a 6550 blow. Now it won’t work. I got zero on plate voltage trying old 6550s and EL34s I’m still reading 0 on plate volts. I can’t get it working. It’s going on the shelf till I figure it out. My tech retired so I’m Out of luck.
  20. The Grim Peeper
    Jul 11, 2010
    763
    164
    I always have my traynor YBA1. It has never let me down. I have a show tomorrow
