Going To See A 1959 Reissue Tomorrow... Snagged!
Discussion in 'Let's Talk Vintage' started by Geeze, May 11, 2018.
  1. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    941
    1,333
    Floating above Dallas in Marshall Heaven
    Yes, I know it's loud. I want it so. I have a 1987 and I want its big brother - yes it's a compensation thing...
    It has a loop so it's one of the later series reissues. Are there any gotchas to look for? Other than it's not an original gotchas that is. No extra knobs or holes from the pics. Shell not too beat up - I'll build one.
    Thanks for the input.
    Russ
    jmp45, liontato and GuitarIV like this.
  2. GuitarIV
    GuitarIV Well-Known Member
    Apr 26, 2017
    426
    496
    Get earplugs. Be prepared to talk to cops. Buy a sixpack for every neighbour. And last but not least: rock.
    ADZG, liontato and Geeze like this.
  3. Geeze
    Jul 25, 2015
    941
    1,333
    Thanks @GuitarIV . Have ear plugs, will travel. The guy has a rockcrusher into a 1960A with 75's. So I can push it to hear some grind. Other than checking the noise floor this is a done deal unless it smokes...
    I have an 18,000 sqft shop for after hours blasting. I need more greenbacks!
    Russ
    jmp45, GuitarIV and liontato like this.
  4. liontato
    liontato Well-Known Member
    Sep 24, 2012
    690
    540
    Russ, if you buy it we need a clip eventually....preferably in the 18,000 sqft rock cave.
  5. Geeze
    Jul 25, 2015
    941
    1,333
    @liontato that's a whole 'nuther can o' worms. I have zero recording gear and spent some time talking to the Universal Audio rep at the last show regarding their OX system. Me so horny. Not exactly a live room recording setup but one I could use at home and keep the townhouse neighbors blissfully ignorant of the 600 watts worth of sonic destruction lurking in their midst.
    I have to dump a couple of amps and empty speaker cabs to acquire that bit of kit.
    Russ
  6. liontato
    Sep 24, 2012
    690
    540
    Well just your summary will do for now once you get it. I’m sure it’s a beast.
  7. GuitarIV
    Apr 26, 2017
    426
    496
    Jesus man, enjoy! I remember the feel of the endorphines rushing through my body the day I cranked my 2203... better than sex.
  8. ampmadscientist
    8,945
    3,617
    You need to upgrade the "humdinger..." that's the pot that fails. This was the only bad thing about reissues.
    grainman likes this.
  9. ampmadscientist
    8,945
    3,617
    Actually:
    it triggers the same chemical in the brain as sex does. (this has been studied by scientists).
    Now you understand...
    GuitarIV likes this.
  10. jmp45
    jmp45 Well-Known Member
    May 5, 2016
    1,085
    1,043
    I have a 96 SLP, no loop. That and my 69 1987 tie for first. You won't be sorry if it's anything like my SLP. I removed c17 & c18. Didn't snip in case I want to restore. I have no idea what the humdinger mod is, if it's a pot issue, mine doesn't suffer from it.
  11. Geeze
    Jul 25, 2015
    941
    1,333
    Unfortunately the test run has been put on hold for a few days. I'm already contemplating the next cab build madness.
    Russ
  12. grainman
    grainman Active Member
    Feb 10, 2017
    377
    181
    my head
    its the humbalance pot on the circuit board wich is sensitive to power surges or shorted tubes...one may bypass it with 2x resistors ( values?? )...
  13. grainman
    Feb 10, 2017
    377
    181
    my head
    PS.. this trouble happened to me twice in all...even once repaired and modded, it striked me once again!! ...you have to put strong tubes in these amps....shorted tubes did damage these 2x resistors...since then, i use jj el34 only (as suggested by a tech...jjs or n.o.s el34 are tough enough for the high voltage of the 1959) no more problems occured even if played/abused on a regular basis since...its a great amplifier with tons of power !!
    liontato likes this.
  14. jmp45
    May 5, 2016
    1,085
    1,043
    K, makes sense. There is only one trim pot on my SLP board. VR1 used for bias adjust, no others. Board is tagged 1959SLP-60-00 2345. I'm running 6CA7s, EH most likely IIRC.
  15. ampmadscientist
    8,945
    3,617
    I actually think there is a bad circuit track, or a bad component which causes this.
    Which circuit track we do not know yet.
    I think high voltage is leaking into the filament circuit.
  16. ampmadscientist
    8,945
    3,617
    Yes
  17. ampmadscientist
    8,945
    3,617
    The humdinger is the filament hum balance pot.
    The pot is replaced with fixed resistors.
    However, there seems to be an underlying cause, which has not been addressed or identified.
    (the exploding pot is the symptom)
    (replacing the pot with resistors is the band aid)
    It actually seems like somewhere the high voltage is arcing into the filament...
    jmp45 likes this.
  18. jmp45
    May 5, 2016
    1,085
    1,043
    Make sense. I'm good, my early version slp only has one trim pot for bias.
  19. GuitarIV
    Apr 26, 2017
    426
    496
    It certainly did feel like I had an orgasm hahaha
    It's amazing what a roaring amplifier, playing an instrument and music in general do to people. I think it's truly a gift from god.
    Geeze likes this.
  20. Yugedrums
    Yugedrums Active Member
    May 7, 2015
    315
    237
    Florence, South Carolina
    Mine too (a 2000 model).
    I have two schematics for the 1959 reissues... one dated 1992 and the other dated 2002. My 2000 model follows the 1992 version, which has only the bias trim pot at V1 and has no V2. The 2002 schematic shows the V1 pot (bias) and V2 pot ("exploding" hum balance). It also includes the effects loop schematic, that the 1992 version doesn't have (like my 2000).
    I'm glad mine doesn't have the V2 pot, but if it did I'd be doing the resistor replacement AMS recommends.
    jmp45 likes this.
