Gettin The Tone .....Anywhere
Discussion in 'The Tone Zone' started by AlvisX, Mar 24, 2020.
  1. Frodebro
    Frodebro Well-Known Member
    May 14, 2014
    4,254
    5,094
    Seattle
    After years of your really cool "pawn shop find" threads, in addition to all of the stuff you've brought back from the dead, it would be a pretty traumatic shock to the system if you started posting about new profiles you downloaded... :p
    AlvisX and netlocal like this.
  2. mirrorman
    mirrorman Well-Known Member
    Mar 30, 2014
    797
    1,056
    Canada
    I use a JH-1 Jackhammer to "Marshallize" my Blues Jr. and Hot Rod Deluxe.
    I have the amp set clean and kick on the JH-1 for overdrive.
    The OD channel with the Gain set to about 9 o'clock is pretty sweet, IMO.
    In front of my Hot Rod Deluxe I like to use a Bad Monkey to push the clean amp into breakup. Don't like the Drive channels on this amp and never did.
  3. netlocal
    netlocal Well-Known Member
    Jan 16, 2012
    409
    898
    California
    I just watched your video for "Where The Fun Is".
    In a word- no... I need two words- f--ken badass:agreed:
    AlvisX likes this.
  4. AlvisX
    AlvisX Well-Known Member
    May 31, 2011
    4,221
    7,751
    I-55 Corridor
    Yeah, there ya go. That's one of the amps I end up with sometimes. Last tour I did in Spain ,that's what I had . You're right ,the drive channel on this amp ,and most 2 channel configurations like that. I ended up using the clean channel and my friend's Pro Analog Manticore. It did very well ,although ,it may be a little gainey for me .
    Bad Monkey's got a good TS flavor IMO
    mirrorman likes this.
  5. AlvisX
    May 31, 2011
    4,221
    7,751
    I-55 Corridor
    Thanks for tuning in. IIRC that was an Orange Tiny Terror combo with a greenback . I think a DOD 250 for a solo boost
    netlocal likes this.
  6. Wildeman
    Wildeman Well-Known Member
    Oct 2, 2016
    1,445
    1,700
    I sing these things praises every chance i get, so damn good and tweakable i don't see how someone could not get a sound they like outta one. Maybe not what your lookin for as they're not made anymore so not readily available anywhere but i see them for sale used all the time. They really are killer man and do a pretty convincing Bassman, Marshall and AC30. Get you one and give it a try, you might be surprised. Screenshot_2020-03-25-16-35-07-1.png analog and it can run off a 9v battery.
    AlvisX and Nik Henville like this.
  7. Nik Henville
    Jul 18, 2018
    1,340
    2,261
    Stewart Ward's finest.
    The Award-Session JD10 MKI is exactly the same as the Morley JD10 apart from the silk screen details on the case. Either is excellent... Personally, the later Mk.II models soound just a little better, but either will do the job very well. There's a JD20 which apparently if more usable but sounds just as good.
    :hippie::pirate::uk:
  8. El Gringo
    El Gringo Well-Known Member
    Jul 24, 2015
    1,684
    1,612
    Shakedown Street
    Reminds me of way back in the early to mid 90's using a Mesa V Twin preamp powered by either 2 12AX7's or a more useable method was using 2 12AT7's which worked better as the volume ,feedback, and gain were unmanageable .
