Fs: Splawn Supersport Amplifier In Mini Headbox
Discussion in 'Member Classifieds' started by Rob Bernstein, Jan 12, 2019.
  1. Rob Bernstein
    Rob Bernstein New Member
    Jan 12, 2019
    Splawn Amplification SuperSport Amplifier in Mini Headbox
    2-Channel 22-Watt 6V6 head, has custom Solo Boost option (variable level). Very compact, is mounted in a "mini" head box cabinet. Great cleans, and the OD channel can get very chunky, overdriven, and loud. Very usable Master Volume to control overall level and not affect tone.
    4 x 12AX7 preamp tubes and 2 x 6V6 power amp tubes.
    Not interested in any trades.
    $1000.00 shipped in the CONUS
    Includes foot switch, 25' cable, padded cover, power cable. In excellent condition, never gigged. Built by Scott Splawn in North Carolina.
    • 22 watts - w/ 2 6V6 power Tubes
    • Channel 1 (clean) - Master Volume, Gain Control, Shared EQ
    • Channel 2 (overdrive) - Master Volume, Gain Control, Shared EQ
    • 4 Button Footswitch - #1 Clean/Overdrive - #2 Mode 1st Gear/2nd gear- #3 OD1/OD2 - #4 Boost
    • Series Effects Loop - w/ true-bypass and adjustable +4db/-10db switch
    • Loop Volume Control for low volume playing.
    • Impedance Selector - 8/16 ohms
    • Mini Headbox Weight 35lbs Dim W 20-3/8" H 10" D 8.5"
    [​IMG] [​IMG] [​IMG] [​IMG]
  2. royslead
    royslead Well-Known Member
    Jan 19, 2011
    1,565
    872
    Wisconsin
    Nice amp
