FS: Marshall AVT275 2x12 150W Guitar Combo Amp (w/footswitch and cover) $380
Discussion in 'Member Classifieds' started by slowcorrado, May 5, 2015.
  1. slowcorrado
    slowcorrado New Member
    Mar 19, 2015
    19
    2
    Central PA
    I have a used Marshall Valvestate 2000 AVT275 amp for sale. Its in excellent condition with only a few minor marks from use/transport, etc.. This is a stereo 150W hybrid amp with a real tube in the preamp (12AX7). It is a UK-built Marshall and has a great quality feel. All functions work perfectly, it is LOUD, and includes the power cable and the correct Marshall 6 button footswitch in excellent condition. (The Footswitch and cable alone sell for $130 on eBay!) Also included is a MINT official Marshall vinyl custom cover. I just installed/upgraded the internal cooling fans to a pair of ball-bearing ones. Since this amp has a master volume, you can easily play at bedroom levels. It also has enough headroom to play gigs and cut through the noise and be heard. The pictures don't really do this amp justice; its large, like a quarter stack and has TONS of features. Warning: Also its heavy!
    Here are the official specs:
    This stereo, 75-watt per side, 2x12 in. combo is the bigger brother of the AVT150 combo. It boasts the same 4 channels and 2 DFX Sections of the AVT150, but the stereo 2x12 in. format allows the onboard DFX to add an incredibly rich, stereo dimension to your sound.
    Additionally, the left and right speaker outputs could be used to drive extension cabinets. Also Headphones (where turning the Master Volume right down will provide silent practice), Left and Right Speaker Emulated outputs (where turning the Master Volume off provides silent recording), and stereo returns for the Effects Loop complete the line up for this incredibly flexible AVT combo. The AVT275 features Stereo Digital FX.
    What is AVT
    In Marshall's quest to give players the ultimate tone at a realistic price, they have combined the latest innovations in valve, solid state, and digital technologies to achieve optimum sonic performance. AVT has evolved from their original, critically acclaimed Marshall Valvestate technology, but is vastly improved so it emulates the tone, feel, and response of their world-renowned, all-valve amplifiers with unerring accuracy without using valves in the power stage.
    Marshall's long history and experience in the field of valve amplification was utilized in the development of the new AVT power amp. This extremely responsive and warm sounding circuitry was then coupled with the specially voiced, ECC83 (a.k.a 12AX7) valve-driven pre-amp section, to provide 100% valve/analog warmth from input to output. Combined with numerous user-friendly features, they believe we've created the best value-for-money range of Marshall amplifiers ever!
    Valve Drive Pre-Amp
    From the compact AVT20, right up to the thunderous roar of the feature packed, 4-channel AVT150H, each model in their brand new AVT line boasts a pre-amp stage that is driven by an ECC83 Dual Triode valve. Unlike certain other hybrid amps out there, this valve isn't merely acting as a pilot light. Instead, it is playing the central role in the gain, distortion and tone generating circuitry. They have gone to great lengths to ensure that this precious device delivers maximum sonic benefit at all settings and volume levels. The resulting clean sounds ring with the bell-like harmonics that only a valve pre-amp can deliver and the break-up is never harsh or unnatural sounding. Whenever you select an AVT Overdrive channel, the ECC83 is saturated to its limit, providing dynamics and feel worthy of a place in the Marshall hall of fame.
    Power Amp Delivery
    The same, unrivalled design expertise that went into the pre-amp was also channeled into the design of the AVT power stage. Using frequency dependent power amp damping and their proprietary, dynamic clip level technology (which emulates the HT supply of a valve power amp), each AVT power stage creates the warm, musical feel and 3-dimensional sounds that made Marshall's all-valve power amps world-renowned. Also, all AVT products will deliver the goods in the often hostile and unpredictable environment of the live performance stage - which is why the AVT power amps of 50 watts and up are fan cooled for optimum reliability.
    DFX Onboard
    The AVT100, AVT150, AVT150H, and AVT275 all have onboard DFX (Digital Effects). Here the greatest care was taken to ensure that the highest level of signal integrity was maintained at all times. They achieved this by successfully integrating DFX into the tonal topology of AVT without adding any of the nasty-sounding, artificial "grain" often associated with DFX. To make the 16 custom-voiced DFX as controllable and user-friendly as possible the relevant models are all supplied with an LED equipped foot controller which allows you to switch the amp's DFX on and off, as well as change channels.
    The flexibility of the AVT150, AVT150H, and AVT275 is further enhanced by having 2 DFX sections, 1 for the Clean and Acoustic Simulator channels, and the other for the 2 Overdrive channels.
    Extended Response Loudspeakers
    Knowing the importance of the relationship between power amplifiers and loudspeakers, Marshall have worked extremely closely with Celestion to develop a range of speakers that will re-define the cutting edge in rock guitar reproduction. These speakers allow the compact, closed back cabinets used in the Valvestate 2000 AVT range to maintain the bottom end delivery normally associated only with a full 4x12 extension cabinet set-up.
    This amp has real Marshall sound and is excellent for bedroom practice, recording or playing gigs. Asking $380. If you're in the central PA area, you're welcome to bring your guitar to test it out, feel free to message with any questions. Shipping quotes given on request.
