FS JCM900 4500 1991-1992 $600
Discussion in 'Member Classifieds' started by LesBalls, Jul 25, 2019.
  1. LesBalls
    LesBalls Member
    Dec 31, 2008
    99
    4
    USA
    1991-1992 JCM 900 4500. This is the 50 watt Dual Reverb. A couple cuts in the tolex on the bottom. Other than that looks and functions like new. No mods. Bone stock. Purchased in Nashville for a session and has been in storage ever since. $600 + shipping.
    Headache likes this.
  2. Bloodrock
    Bloodrock Well-Known Member
    Aug 12, 2010
    2,521
    2,595
    Ft.WorthTX
    El34 or 5881?
  3. the riffer
    the riffer New Member
    Jan 23, 2015
    25
    5
    The 5881 have the tube that says 5881 on the faceplate. This should definitely be an EL34.
  4. mk2 steve
    mk2 steve Well-Known Member
    May 21, 2012
    1,029
    634
    Not all of them. Only sure way is to check the wiring and components.
    The switch to 5881 happened around mid 93 though, so assuming it hasn’t been converted at some point, a 1990-91-92 should be EL34.
  5. ampmadscientist
    14,042
    7,858
    Yes if you look at the screen resistors you can see which tubes the amp is set up for.
    (or if somebody changed it)
    EL 34 should have 2.2K 5 watt resistors for the screens.
    If the amp is set for 5881, the screen resistors should be 470 ohm 5 watt.
    Gutch220 and mk2 steve like this.
  6. Gutch220
    Gutch220 Well-Known Member
    Feb 19, 2018
    670
    462
    NJ
    What state are you in?
    ......or 2.2k 4w resistor?
  7. ampmadscientist
    14,042
    7,858
    The state of inebriation :drunk:.
    Headache, mcblink and K2JLX like this.
  8. ampmadscientist
    14,042
    7,858
    The schematic I have says 5 watt, but apparently 4 watt was enough?
  9. Gutch220
    Feb 19, 2018
    670
    462
    NJ
    I guess
