FS: 2019 MusicMan Ball Family Reserve JP6
Discussion in 'Member Classifieds' started by Exojam, Jan 26, 2020.
  1. Exojam
    Exojam Well-Known Member
    May 31, 2017
    635
    403
    Selling MINT condition 2019 MusicMan JPXI 6 Oynx
    Purchase comes with the guitar, MusicMan hardshell case, very new Ernie Ball M-Steel Regular Slinky .010-.46 strings and I put in 4-5 9 volt batteries.I have included a only a few pictures here but have over 20 more at the link to Dropbox below.
    Model JPXI 6
    Size 12-3/8" wide, 1-3/4" thick, 37" long (31.4 cm wide, 4.5 cm thick, 94.0 cm long)
    Body Wood Alder with maple top and mahogany Tone Block
    Body Finish High gloss polyester
    Body Colors Onyx
    Bridge Custom John Petrucci Music Man® Piezo floating tremolo, made of chrome plated, hardened steel with solid steel saddles.
    Scale Length 25-1/2" (64.8 cm)
    Neck Radius 20" (50.8 cm)
    Headstock Size Only 5-7/8" (14.9 cm) long
    Frets 24 - Medium Jumbo profile, Stainless Steel
    Neck Width 1-11/16" (43.0 mm) at nut, 2-1/4" (57.2 mm) at last fret
    Neck Wood Select mahogany
    Fingerboard Ebony
    Fret Markers Custom JPXI Inlays
    Neck Finish High gloss polyester
    Neck Colors Color matches body
    Tuning Machines Schaller M6-IND locking with pearl buttons
    Truss Rod Adjustable - no component or string removal
    Neck Attachment 5 bolts - Sculpted neck joint allows smooth access to higher frets
    Electronic Shielding Graphite acrylic resin coated body cavity and aluminum control cover
    Controls 500kohm volume, 500kohm push/pull tone for custom 2 pickup configurations - .022µF tone capacitor
    Switching 3-way toggle pickup selector, with custom center position configuration; 3-way toggle piezo/magnetic selector
    Pickups HH - 1 DiMarzio Liquifire - neck; 1 DiMarzio Crunch Lab – bridge; Piezo bridge pickup
    Left Handed No
    https://www.dropbox.com/sh/jv2qz4vsweuy5up/AADNAKMB_ywy64GakNpz8GXwa?dl=0
    C81400F7-D92A-41D1-A29F-E95DA199F5D8.jpeg DD8F5132-9D66-426F-9835-AE24E9EE10F5.jpeg 65090FA4-E91E-4CBA-B0AB-6FB59E229EBD.jpeg
  2. Exojam
    May 31, 2017
    635
    403
