Framus Cobra FX Loop
Discussion in 'Other Amps' started by Shae201, Sep 13, 2019.
  1. Shae201
    Shae201 Well-Known Member
    Dec 20, 2015
    601
    645
    In the manual for this amp, it says it cannot accept stompboxes in the FX Loop. Its a parallel loop and only works with rackmount units. I plugged in my EQ pedal anyway and it doesnt work much at all. Does anyone have a mod to turn it into series or do I need to use rackmount units?
  2. ampmadscientist
    15,601
    9,520
    If you have the schematic you might be able to.
  3. ampmadscientist
    15,601
    9,520
    It looks like if you take out the 100n cap, or the 100K resistor (either one), the loop will be series only. There will no longer be parallel.
    (schematic here)
    http://www.chasingtone.com/schematics/PPO25/Cobra_V1-2.pdf
    However there is an effects mix control which will no longer function if you change the loop to series.
  4. Shae201
    Dec 20, 2015
    601
    645
    Wow, I appreciate it. I just don't understand why Framus made the call to make this amp only for Rackmount.:facepalm:
  5. ampmadscientist
    15,601
    9,520
    Some builders are just into racks.
    There is a control that can be built with a 1 meg dual pot.
    It allows bypass, parallel adjustable mix and series all in the same control.
    I used that because I could get a lot more options out of the effects loop.
