Finally ordered the SV20h + SV212 cab!
Discussion in 'Marshall Amps' started by Shane Stevenson, Dec 11, 2019.
  1. Shane Stevenson
    Shane Stevenson Well-Known Member
    Oct 17, 2019
    119
    337
    Guess I’ll have to wait till about Friday to find out how it compares to my SC20H. I know this probably belongs in the official SV20 thread.
    My goal with the SV will be running it at the edge of breakup and push it further for leads with a Tubescreamer. I like to keep things simple.
    I hope it won’t be too loud being used this way. For reference, I’m comfortable playing my SC20 volume at around 9:30 to 10 o’clock and pre-amp at 2 o’clock (I think that’s 3 and 7 on the volume dial).
  2. tce63
    Aug 6, 2018
    1,101
    2,714
    Sweden
    Congrats, you are going to love it !
    Mitchell Pearrow and MarshallDog like this.
  3. Sustainium
    Sustainium Well-Known Member
    Oct 4, 2019
    224
    430
    Lapeer, Michigan
    Looking forward to your review, I’m picturing a SV20 stacked on my SC20H also.
  4. MarshallDog
    Nov 28, 2010
    12,527
    12,164
    Taintville
    Congrats, hope you love it!
    Jon C, Mitchell Pearrow and tce63 like this.
  5. Mitchell Pearrow
    8,728
    13,300
    Congratulations you’re going to be in another world, give us the full rundown and the, complimentary pics as well please.
    Cheers Mitch
  6. pedecamp
    13,600
    9,874
    Congrats man! To get edge of breakup you will have to crank it to ear splitting levels, I highly recommend you get a JHS little black box master volume to run in your loop ($38 with discounts, is well worth it), this is what I'm doing and you can dial in whatever you want at any volume. I'm also using a ts9 with it and it provides a really nice crunch. :yesway:
  7. LCW
    LCW Well-Known Member
    Jan 18, 2017
    303
    336
    The vertical cab is awesome! I have the SC212 and love it.
  8. scozz
    scozz Well-Known Member
    Jul 20, 2008
    2,157
    4,693
  9. Shane Stevenson
    Oct 17, 2019
    119
    337
    This is very interesting. So...what’s the difference between the jhs and an attenuator? Does the jhs color tone?
    I have to be honest, I have never used an effects loop. Not even with my SC20. I’m just using different overdrive pedals in front of the SC. So it’s as simple as pushing the effects loop button down and plugging the jhs into each jack of the loop on the amp? Are you just placing the jhs on top of the amp?
    One more dumb question, do you use two instrument cables or two speaker cables for the jhs? My guess would be instrument cables but I’d like to be sure.
  10. Shane Stevenson
    Oct 17, 2019
    119
    337
    I have that cab too, that’s the reason I’m buying it again but with differant cosmetics. Great cab after the speakers get broke in!
  11. tce63
    Aug 6, 2018
    1,101
    2,714
    Sweden
    Yes the Cab sounds great, but it took +50 hours before it opened up and starting to sound great
    MarshallDog and Mitchell Pearrow like this.
  12. Kim Lucky Day
    Kim Lucky Day Well-Known Member
    Aug 22, 2018
    150
    319
    Instrument cables will do the trick.
    Congrats on the new head/cab! 'Tis a great amp for sure, sounds like you have a solid game plan for where you want to dial it in.
    Also, it's relatively more expensive but a lot of guys on the forum (including me) are very high on the Weber Mini Mass attenuator. It has a 3db and 6db treble boost built in. I have mine set to 3db, which is about the perfect tone for me.
  13. pedecamp
    13,600
    9,874
    It works well without coloring the tone, with this JHS in the loop it operates as a master volume for the amp, its a small box about half the size of a pedal and I sit it right on top of the amp, I use a couple patch cables just as you would to patch pedals on a pedalboard. An attenuator would allow you to crank the amp up to get heavier gain out of it and control the volume, the JHS will get you edge of breakup and at most low gain like Zep and ACDC while controlling your volume. They both will get you what you need its a matter of what you want to spend, JHS is about $38 and the Weber attenuator about $136, both are passive but operate totally different from one another.
  14. MarshallDog
    Nov 28, 2010
    12,527
    12,164
    Taintville
    Does that JHS little black box work that good? Where do you buy them? I spill more than 38 bucks on a good weekend so I may try one?!
    pedecamp, Mitchell Pearrow and tce63 like this.
  15. scozz
    Jul 20, 2008
    2,157
    4,693
    Consider this @Shane Stevenson, Weber Minimass 50 attenuator, works great, hand made in the US one by one as the orders come in,...and it get's 5 stars everywhere it's reviewed!
    Best part,...only $136.
    Do yourself a favor and check it out before you make any moves.
    https://tedweber.com/minimass
  16. WellBurnTheSky
    Mar 23, 2019
    481
    1,122
    Depends. If you're looking for the "dimed Plexi" tone with lot of power amp saturation and basically everything on 10 or close to it, an attenuator is better.
    If you prefer (or can get along with) less drastic settings, the volume box will work very well. Also note that if you use effects in the FX loop, you'll get more clarity using the volume box first.
    It works very well for me (i built a couple volume boxes for myself), and doubles as a master volume. But I also tend to start from a mild crunch and use pedals to boost the amp. Might or might not work for you. But definitely worth a try.
  17. Shane Stevenson
    Oct 17, 2019
    119
    337
    I was also thinking about the Weber Mass Lite 100. Is that too much of an attenuator to use with my 20 watt SV? Also, I’m assuming that I would need to buy two speaker cables? Not instrument cables...right?
  18. tce63
    Aug 6, 2018
    1,101
    2,714
    Sweden
    Mini mass works great, I have one an use it on stage an at home with my SV20H and SV212C :)
  19. Sustainium
    Oct 4, 2019
    224
    430
    Lapeer, Michigan
    Yes, speaker cables only for attenuator connections between amp and cab.
  20. G the wildman
    G the wildman Well-Known Member
    Feb 7, 2016
    498
    521
    London UK
    Congratulations it is a fabulous amp. I have the SV1x12 and that is nice, so the 2x12 will be super.
    I have the Weber mini mass. I could not play it at home without it. Not because of neighbours but it would seriously damage my hearing.
    G
