EQ in a Vintage Modern effect loop !
Discussion in 'Marshall Amps' started by Kelia, Jun 26, 2019.
  1. Kelia
    Kelia Active Member
    Feb 26, 2018
    245
    141
    Hi guy's , yesterday for the first time , I tried a Boss GE-7 in my VM effect loop while on the HDR mode and I was very pleased on how it tamed some of the shrill frequencies for heavy Rock !
    Anyone tried this and could you share your experience ?
    Even the boost mode sounds better with the eq in !
    Tx
  2. herbvis
    herbvis Active Member
    Jul 8, 2010
    103
    81
    Eq pedals are amazeballs in a loop. Noisegates as well
  3. Kelia
    Kelia Active Member
    Feb 26, 2018
    245
    141
    Amazeballs is a first for me but spot on what I'm hearing !!
    I'll try the noise gate as well when I get a chance to get one and also a BBE that someone mentioned on a JCM900 thread but can't remember !
    I might take a picture of my settings tomorrow if I get a chance .
    Thanks for sharing !
  4. ricksconnected
    Sep 29, 2015
    13,152
    6,321
    everywhere you wanna be.
    ive been preaching EQ pedals for yrs on here.
    a must have for any loop. if you dont have one your
    only getting a % of the possible tones you could be getting.
  5. Kelia
    Kelia Active Member
    Feb 26, 2018
    245
    141
    Yes !!.......I'm late to the Party but never thought this would make such a big difference !
    Never liked the VM crunch ,or was trying to find it but now with the eq in loop , it has JCM800 KT66's crunch qualities which is great !
  6. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    4,528
    2,454
    I didn't think the VM did a good high gain sound. Maybe because it needed an EQ? i couldn't get a decent bottom end that wasn't loose and vintage sounding. Now the classic tone i loved it. The 900DR is a better clean and high gain amp for me.
    Now on the BBE thing, what ever you do don't get the red stop pedal BBE it is a mid scooper BBE you need the larger better units to keep the middle. I have a rack unit (462) that sounds good and a little half rack 262 but the sonic stop robs all the Marshall mid goodness imo. If you like that mid scoop then that pedal is a good one but compared to the other 2 units i have that one isn't one i would recommend
    Michael Roe likes this.
  7. mickeydg5
    20,671
    8,422
    I say EQ in every loop, not just Vintage Modern.
  8. ricksconnected
    Sep 29, 2015
    13,152
    6,321
    the tone shaping you can get is crazy isnt it? if one doesnt need it just switch it off.
    its kinda sorta like adding a whole other channel to your amp. or can be if thats how one chooses to use it.
    you can find these things used for like $65. best upgrade one can get for that kind of cash.
    ok its not really an upgrade but damn.
    love to read testimonies like this when the light bulb come on for somebody. its so easy and so many refuse
    to at least try it. when i go try out amps i always bring my GE7. impossible to run a amp through its paces w/o it.
    well as long at there is a loop to run it through.
    LPMarshall hack and Kelia like this.
  9. Kelia
    Kelia Active Member
    Feb 26, 2018
    245
    141
    Thanks for the input !
  10. Michael Roe
    Michael Roe Well-Known Member
    Mar 25, 2017
    936
    2,055
    Springfield, Ohio
    I would agree. Get the rackmount version of the BBE. Set the knobs around the 12-1 O'clock area. The odd thing with the BBE is, that you just have to try it and see if it works on your particular amp. It can make some amps really come alive and others not so much. It works great for a JCM 2K DSL, JMP-1 preamp, and a 900. I have found it not very good with the newer DSL, Jubilee and the new SV.
    Mitchell Pearrow and Kelia like this.
  11. Kelia
    Kelia Active Member
    Feb 26, 2018
    245
    141
    Happy my light bulb went on !!..haha!
    I've heard about GE7 modded , what is it ?.......and there's a guy near my area who's selling a mint GE-10 , is it worthed !.....ever tried one ,?.....think this is what VH was using .
    ricksconnected likes this.
  12. Mitchell Pearrow
    6,574
    8,790
    My mxr 10 band eq, took the SD1 out of the equation, and I am running straight into the front of the amp, always on and always going to be into any amp I use,
    The amps I am using are,
    Dsl40c’s, origin 50H, and if I ever use my grandsons rig , an orange TH30, with another dsl40c, Hell I like it so much I may have to get a spare, all of this was learned off of reading on this forum.
    Cheers Mitch
    T.J. and ricksconnected like this.
  13. ricksconnected
    Sep 29, 2015
    13,152
    6,321
    the GE 10 takes up a lot of room on a board. if i were to go 10 it would have to be the MXR personally.
    ive never used a modded GE 7. i cant imagine what they would or could do to it.
    im very happy with the stock version. should something happen to it i can get another and be back in business quickly
    with stock.
    Kelia and Mitchell Pearrow like this.
  14. MonstersOfTheMidway
    May 1, 2008
    4,680
    2,045
    Vintage Modern amps have a pretty good effects loop. I've used multi-effects (Line 6 HD500 and Boss GT10 if I remember correctly) in the 2466 with good results. The Vintage Modern also sounds great with most pedals and rack effects (rack effects I've used are Alesis Quadraverb and MidiVerb as well as Eventide H3000).
    I, too, agree with placing an EQ in the effects loop. I mostly used the built-in EQ of the multi-effects and rack effects systems because they were very powerful, offered a variety of EQ designs, and built-in was one less device to put in the signal chain. I typically favored parametric EQ over graphic EQ, but graphic EQ sounded good, too. Bottom line try out different designs and use whatever works best for your needs.
    Kelia likes this.
  15. LPMarshall hack
    Nov 18, 2009
    9,659
    7,562
    San Diego, CA
    Speaking of FX loops...some FX loops have that button that has two db modes. Which one are you "suppose" to use?
  16. Kelia
    Kelia Active Member
    Feb 26, 2018
    245
    141
    Plus 4db suits rack and minus 10 is for floor pedals.
  17. Kelia
    Kelia Active Member
    Feb 26, 2018
    245
    141
    Great info !........thanks !
  18. Kelia
    Kelia Active Member
    Feb 26, 2018
    245
    141
    Is the Mxr as good as the older GE7?
    And what does the BBE do exactly , is it like a enhancer or something ?
  19. LPMarshall hack
    Nov 18, 2009
    9,659
    7,562
    San Diego, CA
    Holy Jesus...so simple! Thank you
    Kelia likes this.
  20. ricksconnected
    Sep 29, 2015
    13,152
    6,321
    the mxr has 3 more bands of course. the GE 7 and the MXR are the most popular
    and use the most by far. either one will get the job done for you very nicely.
    the GE 7 can be found on the used market much cheaper though. personally ive used
    the GE 7 for decades with favorable results. never had the need or desire to look into
    any other brand. it just works. if i were to find a ok deal on a MXR 10 i might try it
    on my own stuff but have used them playing other folks rigs with equal success to my
    GE 7. you just cant go wrong with either one.
    where are you located if i may ask?
