EMG81 is squealing and microphonic as hell
Discussion in 'The Tone Zone' started by Solid State, May 26, 2019.
  1. Solid State
    Solid State Well-Known Member
    Jan 2, 2016
    253
    356
    I recently bought a second guitar with the EMG81/85 combo and the EMG81 in this one really doesn't sound like the first one I bought. It also gets microphonic as hell at any volume above a whisper. Feedback is non-existent with the other guitar so something is wrong. This newer guitar was bought used and it's such a bizarre phenomenon I'm wondering if the guy that traded it in ripped out the original pickup and replaced it with a chinese copy.
    Anyone ever heard of an EMG81 feeding back a lot?
  2. Robert Herndon Project
    Robert Herndon Project Well-Known Member
    Apr 28, 2011
    557
    302
    Los Angeles, California
  3. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    800
    768
    What make and model guitar? Anything commonly counterfeited, like Zack Wylde Epi or Kirk Hammett LTD?
    Supposedly originally came with EMG, or supposedly upgraded? Does the EMG look identical to your other EMG from first glance?
    Look for a battery box or clip, see if it exists and actually does anything, if it's a lowend fake it won't exist or won't do anything
    If 9V exists and checks out, unscrew pickup ring, pull up and take a picture of the bottom
    There HAS been a recent trend for at-a-glance lookalike knockoffs, but generally they don't sweat the details
  4. Solid State
    Jan 2, 2016
    253
    356
    This is a very new model Wylde Audio rawtop vortex - not even 6 months old. It showed up used at Guitar Center and I bought it. I opened it up and it was either a bad job from the factory and that's why the guy got rid of it, or the original owner didn't care for the guitar but did some surgery to steal the pickups. Check out the cut wire on the pot. Someone cut it and resoldered it
  5. Adieu
    Jan 12, 2013
    800
    768
    Seriously? I guessed the Wylde thing?
    ....Any reason to believe it's real to begin with?
    Used Zakk Wylde stuff should be assumed fake unless/until proven otherwise, he's Chibson LLC's fave celebrity
  6. ampmadscientist
    12,041
    5,990
    Left Coast
    Take the pickup out and send it to EMG for testing.
    No, the PU should not squeal unless it's wired wrong.
    The PU contains a preamplifier, which could be defective. Maybe somebody hooked up the DC power to the PU backwards, and shorted the internal circuit.
    So if you looked on the EMG website, and confirmed that the wiring is correct, and the PU still squeals, then send it to EMG or buy another PU.
    https://www.emgpickups.com/skin/frontend/emg-interface/emg/pdfs/zw-set.pdf
    Note: it might be wired wrong.
  7. ampmadscientist
    12,041
    5,990
    Left Coast
    The volume and tone controls are supposed to be 25 K ohms.
    What controls are installed in your guitar? are these 250K or 500K controls?
    If so, this would explain why the pickup squeals.
    What wiring diagram are you using?
  8. fifteenohms
    fifteenohms Active Member
    Sep 30, 2010
    454
    226
    Los Angeles, CA
    One way to resolve squealing EMG’s is repotting in Acetone using a double-boiler setup on a gas stove.
    (I have an 81/85 setup. Not too keen on it obv)
  9. Adieu
    Jan 12, 2013
    800
    768
    No if it has 250 or 500k and it squeals, it's a fake, or more accurately, a fake EMG-logo cover over a noname passive pickup
    A real EMG with a 250/500/1000k pot would just react to the thing like an on-off switch
  10. ampmadscientist
    12,041
    5,990
    Left Coast
    It could be fake.
    I thought that I would point out: EMG says 25K to work correctly.
    But look: EMG is not giving a real wiring diagram either. It's all "pre-built / plug-in" modules.
    That will cause mistakes if you don't buy the EMG pre wired parts / pots.
