ECC823 has arrived
Discussion in 'The Workbench' started by Peter McAteer, Oct 21, 2019.
  1. Peter McAteer
    Peter McAteer Active Member
    Sep 9, 2019
    138
    153
    The North Shore of Lake Ontario
    The ECC823 I ordered from Eurotubes has arrived, soon be slotted into V1 in my DSL15H. Hopefully this tames the insane red channel on this amp! Updates pending.
  2. Jon C
    Jon C Well-Known Member
    May 29, 2017
    1,372
    2,370
    Wa State
    You mean ECC83S ?
  3. Peter McAteer
    Sep 9, 2019
    138
    153
    wakjob likes this.
  4. Jon C
    May 29, 2017
    1,372
    2,370
    Wa State
    Wow …… Darker than an 83 ?
  5. Peter McAteer
    Sep 9, 2019
    138
    153
    Instead of being routed thru a 12AX7, the red channel goes thru a 12AU7. Much less gain...Which in the DSL15, is exactly what is needed. For reasons known to no one but the folks at Marshall, the DSL15 has the Red 2 channel of the DSL40, and not the more useable Red 1. Subbing in an ECC823 is one way of taming the red channel on the DSL15.
    Jon C likes this.
  6. Jon C
    May 29, 2017
    1,372
    2,370
    Wa State
    Dogs of Doom and Peter McAteer like this.
  7. donwagar
    donwagar Member
    Nov 24, 2018
    20
    38
    I bought a DSL15C about 6 months ago, after I'd read up on some of the mods here.
    I thought the ECC823 was a good mod. I also did C76 (150pF), R82 (added 150K), removed C75.
    And I put a Private Jack speaker in it.
    I think it sounds way better than it did. It's my home practice amp now.
  8. Peter McAteer
    Sep 9, 2019
    138
    153
    You added the ECC823 AND did the R82? That must have tamed the red channel a whole lot. I'm going to start with the tube, and if that doesn't do enough, I'll rebuild the red channel to the same spec as red 1 on the DSL40. Like shown in this vid
    wakjob and donwagar like this.
  9. South Park
    1,257
    939
    I think what you are doing is dropping the q point of the preamp tube. You can look it up on the data sheet. Power curve
  10. Peter McAteer
    Sep 9, 2019
    138
    153
    Well, after a few weeks of being busy with other projects, the ECC823 finally went into the V1 slot today. I must say that this one change has really tamed the red channel. If you're looking for a simple, no-solder mod to dial down the insane red channel on the DSL15, this is it. That being said, it's still a bit fizzy. Further mods may be in store if I can't EQ the fizz out of the signal. C76 AND R82 may be next.
    GIBSON67 likes this.
  11. Peter McAteer
    Sep 9, 2019
    138
    153
    I'd add that the JJ EC823 has improved the green channel as well. Apparently the 12AX7 side of the twin triode is an upgrade to the Marshall branded ECC83 that came with the amp.
