Early JMP 50 watt just finished
Discussion in 'Building the Classics' started by william vogel, Mar 25, 2020.
  1. william vogel
    william vogel Member
    Dec 18, 2016
    44
    50
    466A0A7E-54B5-4DFC-8CCA-ED70C88548E6.jpeg 7D494E41-FED9-4726-B8AD-E469AA9680DB.jpeg AFAF5B04-2932-4B53-AA4C-BF39531E9FD4.jpeg 6DA495A0-E260-4B09-9070-F659E45BFF48.jpeg C21251A9-80A4-4DCB-8BA0-5A1EB166192B.jpeg I just finished this one up 2 weeks ago. It really does everything well. Switches let me choose lots of voices. Late 67-early 70’s.
  2. GIBSON67
    GIBSON67 Well-Known Member
    Sep 8, 2008
    8,898
    4,733
    Lakeland, TN
    Good job, I really like where you put the switches.
  3. pedecamp
    14,522
    11,460
  4. neikeel
    4,244
    2,696
    Nice build with some neat extra features. I like the power supply board for the diodes and heater centre tap arrangement.
    What were your filtering choices?
    I presume you do not switch tone stack etc very often.
  5. South Park
    2,231
    1,808
    Nice build any gain mods
  6. StingRay85
    StingRay85 Active Member
    Aug 18, 2019
    363
    153
    Looks awesome
  7. harleytech
    harleytech Well-Known Member
    Dec 24, 2016
    354
    367
    very nice !
  8. Kelia
    Kelia Well-Known Member
    Feb 26, 2018
    882
    824
    `Nice build ,..........Clip would be great ! :thumb:
    proxy likes this.
  9. william vogel
    Dec 18, 2016
    44
    50
    Filtering switches from 50uF to 100uF. I actually swap around a bit. I really prefer input 2 top set like a JTM50.
  10. HOT TUBES 70
    Oct 13, 2008
    11,215
    5,704
    Pro quality work right there ... Looks fantastic.
  11. Exojam
    Exojam Well-Known Member
    May 31, 2017
    668
    415
    Looks very nice.
    Just wondering how you access the switches?
  12. Bruce_W
    Bruce_W New Member
    Oct 5, 2011
    17
    2
    That is a beautiful amp. Real nice job. Would you mind posting the voltages from the preamp tubes ? Pins 1, 3, 6, and 8? Just so I can compare to mine I just finished. It sounds decent but seems to be a little low volume and a little too clean.
    tce63 likes this.
  13. ampmadscientist
    18,126
    12,164
  14. william vogel
    Dec 18, 2016
    44
    50
    If you go to Valvestorm and use the build checklist, you’ll see how it can be ordered. I build amps often and have many of the small parts on hand, resistors, caps, pots, etc. I buy the chassis and sometimes the board, they have really nice stuff and it works great and sounds REAL. Give them a try. Oh, I just finished a jtm45 this morning and I’ll post pictures later. I build my own cabinets.
  15. william vogel
    Dec 18, 2016
    44
    50
    I’ll have to open it back up later but I’ll do it and post voltage.
    Esa Martikainen likes this.
  16. william vogel
    Dec 18, 2016
    44
    50
    It’s really easy for me because I don’t run the amp with the rear panel installed, let’s the heat dissipate better. All you do is reach over the preamp tubes for the tone switches and the filter switch is between the power tube and the cap can. Really easy.
    Exojam likes this.
  17. _Steve
    _Steve New Member
    Apr 29, 2020
    26
    12
    Great work!
    How do the two filter settings sound?
  18. william vogel
    Dec 18, 2016
    44
    50
    The lower filtering is a little bouncier and the heavy filtering works good for tightening the amp up but it’s not a night and day difference. It’s far from jtm45 vs late JMP. It’s just a nice added bonus to the preamp switches.
  19. _Steve
    _Steve New Member
    Apr 29, 2020
    26
    12
    Cool thank you! Im gonna add this switch to my current build to hear how it sounds. I've never thought about making any of the filter caps bypassable.
