Dual Eq 'soldano Slo'
Discussion in 'Building the Classics' started by Thiez, Oct 30, 2017.
  1. Thiez
    Thiez Well-Known Member
    May 9, 2012
    492
    260
    Netherlands
    A question for the power supply part of the LEDS, hope someone can help me out here.
    I've added two LDR's for the dual equaliser (LDR 5 and LDR 6) and two leds for channelindication on the front panel of the amp.
    For one side i think i've got it correct now (18R resistor for the LDR's and a 220R for the channelindication). But now for the other side, if i switch the footswich, the upper 'bar' will become earth and you will get the situation in the lower schematic. So i understand that i can regulate the current with R64. But i cant seem to find the correct way how to calculate correct value of R64. And i think the signal led will need a separate resistor because of an other forward voltage then the LDR's.
    can someone help me out here?
  2. Thiez
    May 9, 2012
    492
    260
    Netherlands
    nobody?
  3. tschrama
    tschrama Well-Known Member
    May 15, 2010
    890
    294
    Netherlands
    I can have a look... need a moment
    Thiez likes this.
  4. RickyLee
    May 22, 2010
    8,674
    2,352
    Riverside CA U.S.A.
    Dam sweet. You are the man!
    You are making me miss my days of working in the machine shop. If only I knew back then what I know now about amps, electronics and amp building . . . .
    Thiez likes this.
  5. tschrama
    May 15, 2010
    890
    294
    Netherlands
    Try 18 Ohm for R63 (!) .. should provide about 9mA to the LDR1,4 and 5
    Thiez likes this.
  6. Thiez
    May 9, 2012
    492
    260
    Netherlands
    Build is going slow but i had some time again to build on it. Installed the 18R resistor and installed a 33R on R64, the LDR's are working, Channel switching leds are working but the green led of the clean is very weak.
    I measure 3,18V on the plus side of the LDR 1, LDR4,...etc. Forward voltage of the green led is 1,77v. So 3,18v-1,77v=1,41v. 1,41*0,02A=70R (68R) resistor in line with the led to get 20mA. But like i said the LED is verry weak. The red led of the lead channel is working fine.
    Am i missing something?
  7. Thiez
    May 9, 2012
    492
    260
    Netherlands
    Been awhile... was busy building a 5e3 for a friend of mine and also building myself an sg guitar at the moment. So have to split my free time haha.
    But slowly the amount of loose wires decreases.
    royslead, DeathAdder and Geeze like this.
  8. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    834
    1,128
    Floating above Dallas in Marshall Heaven
    Looking great - from the viewpoint of a non amp builder!
    Russ
    Thiez likes this.
  9. DeathAdder
    DeathAdder Active Member
    Oct 14, 2013
    137
    40
    Simpsonville, South Carolina
    Looking Great. I've been away for a while. What's the daughter board up on top?
    Thiez likes this.
  10. Thiez
    May 9, 2012
    492
    260
    Netherlands
    I've used the standard SLOclone boards, the board on top is the separate EQ for the clean channel. Put it above the standaard EQ thats on the main board.
  11. royslead
    royslead Well-Known Member
    Jan 19, 2011
    1,448
    778
    Wisconsin
    I am not an amp builder by any measure of the words; but this build has really piqued my interest (the Soldano SLO, in general has always been interesting to me, though I have never played through one).
    Thiez likes this.
