Dual Eq 'soldano Slo'
Discussion in 'Building the Classics' started by Thiez, Oct 30, 2017.
  1. Thiez
    Thiez Well-Known Member
    May 9, 2012
    496
    261
    Netherlands
    Last weekend i've started my build on an dual eq 'soldano SLO'. I will start with building the standard schematic with dual EQ section, if it works i'll maybe start modding it to taste.
    jensvonbustenskjol and The_Nuge like this.
  2. danfrank
    danfrank Well-Known Member
    Mar 5, 2015
    957
    484
    Hi. Interesting project! At the bare minimum, you will need one more 12AX7 and a couple of relays for switching or to do it with completely dedicated circuitry for each channel, you will need 3 extra 12AX7 tubes.
    Or you can take out the effects loop and use that 12AX7 to drive the other EQ section to keep the preamp count to the original 5 12AX7s.
    Please keep us updated with your progress...
  3. Crunchifyable
    Crunchifyable Well-Known Member
    Oct 28, 2011
    662
    337
    Georgialina, USA
    Thank you for posting. I am very interested to see how you handle wiring and use of board space. Do you plan to use some kind of turret board or do you have a PCB in mind?
    Someday I might have to build something like this.
  4. Thiez
    May 9, 2012
    496
    261
    Netherlands
    I've got a PCB bought from SLOCloneforum i'm gonna use. For the second Eq i will add a PCB board i designed myself. For the layout i'm not sure yet... The PCB is designed so it can be put on top of the main PCB (right over the place where the EQ is on the main board), but have to check if is will give me noise problems or not.
    liontato likes this.
  5. liontato
    liontato Well-Known Member
    Sep 24, 2012
    690
    541
    Very interesting! Keep us updated!
  6. jensvonbustenskjol
    Feb 5, 2012
    592
    198
    Norway
    Neat!
    Good luck! Can't wait for the outcome ☺️
    Thiez likes this.
  7. DeathAdder
    DeathAdder Active Member
    Oct 14, 2013
    200
    49
    Simpsonville, South Carolina
    Where did you get the chassis, C3 Amps? Are you going to use his O'netics transformers? I have had good luck but I also did one with Heyboers. (wow I have a lot of questions)....
    Are you going to do the straight wire heater thing or twist them up? I know the straight wire way works fine but it's very hard to get that wire completely straight. I know Mike has some kind of machine that pumps that stuff out. You're obviously an engineer if you're doing the design yourself, or just very good. I would love to see the schematics (after you've tested the amp of course)!
    Very ambitious project. The thing about deciding on an amp to build is the availability of a good chassis. Fender chassis are all over the place, Marshall's too. Rob has some very good stuff over at C3. Did he drill and powder coat it for you or did he just sell you a blank? Man, that guy does some terrific work. I got a custom made head from him that was just beautiful. Put a Soldano logo on the front and you couldn't tell the difference.
    I will definitely keeping a watch on this thread. Good luck! -Dave
  8. Thiez
    May 9, 2012
    496
    261
    Netherlands
    Made the chassis myself, i can use the metal workshop at my work ;-) 3mm aluminium chassis, corners TIG-welded.
    For the transformers i use IG transformers. It was a german transformer builder who made copies of original SLO and classic Marshall transformers. He doesn't make them anymore, he did the work next to his dayjob and the transformers became to popular to keep up with the orders.
    The painting of the chassis was a pain in the ass!! First and last time i'm doing a white painted chassis haha, you can see even the smallest dirt or dust in the paint. Next amp will be black chassis with faceplates again instead of a white painted chassis with waterslide decal.
    Soon will post an update, i'm done with the decal, now busy with the clear coat. After that i can install all chassis components.
    Crunchifyable and liontato like this.
  9. Thiez
    May 9, 2012
    496
    261
    Netherlands
    Like i said last time with paint and waterslide decal. Next time i will be using faceplates again. But the result is quiet okay.
    RickyLee and Ghostman like this.
  10. danfrank
    Mar 5, 2015
    957
    484
    Very nice work!
    Thiez likes this.
  11. Ghostman
    Ghostman Well-Known Member
    Jan 29, 2012
    10,321
    9,978
    Hopehouse, Selkirk, UK
    That looks fantastic!
    Thiez likes this.
  12. Thiez
    May 9, 2012
    496
    261
    Netherlands
    Allright, chassis is allmost done, only some christmas light needed for power indicator and channel indicator lights.
  13. jensvonbustenskjol
    Feb 5, 2012
    592
    198
    Norway
    That's just wicked!! :dude:
    Crunchifyable and Thiez like this.
  14. Crunchifyable
    Oct 28, 2011
    662
    337
    Georgialina, USA
    Just envious of how good it looks. You simply can't buy a chassis that looks that good, and it completely matches those transformers.
    It's like art on display. Imagine a headshell you can look into...and maybe valve covers in black as well.
    Thiez likes this.
  15. m1989jmp
    m1989jmp Active Member
    Apr 24, 2014
    878
    142
    Is Ingo still winding transformers?
    I tried to contact him a year ago and got no response...
  16. Thiez
    May 9, 2012
    496
    261
    Netherlands
    No, he stopt making transformers. To bad, cause they are really good quality. I've ordered these transformers several years ago allready for this build, short after the order he stopt taking orders because he coudn't keep up with deliviry and had a deliverytime of 3 months or so. Then he desided to finish all the orders he had running and stop bussiness.
  17. m1989jmp
    Apr 24, 2014
    878
    142
    Yeah I've heard they're top notch; they look cool too.
  18. Thiez
    May 9, 2012
    496
    261
    Netherlands
    Starting to come together, few more parts and ready to go.
    Geeze likes this.
  19. tschrama
    tschrama Well-Known Member
    May 15, 2010
    1,024
    347
    Netherlands
    Ahhh.... thats a lively sight. Keep posting!
    Thiez likes this.
  20. Thiez
    May 9, 2012
    496
    261
    Netherlands
    Slowly there is some progress
    The_Nuge and jensvonbustenskjol like this.
