DSL5c - The Ultimate Lo-Power Amp
Discussion in 'Marshall Amps' started by Micky, Dec 9, 2013.
  1. riefil
    riefil Active Member
    Mar 14, 2014
    132
    97
    So this is what I've found based on Micky's picture it's V1, V2, V3(power tube) and V4. I hope this helps others as it has helped me
    Micky likes this.
  2. Frankiepags
    Frankiepags Member
    May 5, 2016
    64
    19
    City of Angels
    I know there has been alot of people asking about the similarities and difference between this (5c) and the dsl15c. So a few weeks ago this guy bought a dsl15c for his apartment and is still trying to tweak for his needs..a month later he buys a hot rod deville for his apartment and realizes its way to loud, returns that and I point him to my favorite low watt marshall dsl5c and he mentions he has the dsl15c , I ask him how he likes it and he tells me , he is having problems dialing it in and that he really doesn't like it , I tell him the difference between the 2 amps , tubes , loop ,etc..he plugs it in and plays it for 20 mins and he absolutely loves it and this was what he thought his 15 would be..says the 5c just sounds way better than the 15c, warmer ,less shrill, and better distortion tones...for what this is worth this is the 3rd time in around 2 months that I have heard this and experienced it for myself...if ur in the market for 1 of these ,please play them first ..they are the same models but sound way different ..
    Ozark likes this.
  3. Ozark
    Ozark Member
    Feb 14, 2016
    38
    13
    Singapore
    Hi Frankipags, you are absolutely right about playing all the amps first and make the right choice. I was lucky to have the honest sales guy in the shoppe to give me his personal opinion on the DSL5C (instead of the DSL15C or BlackStar HT5RH) as he himself owned one and he's darn happy with it. I played it, love it and bought it home and am very happy with it. If most of the time you are playing your rig in your bedroom (just like me), then DSL5C is the them amp for you. The clean channel is great too with a Strat! The FX Loop is great! I use my digital Zoom MS50 (Analog Delay/Reverb/Chorus) in it. The ability to use a headphone and MP3 input is a plus too (you can rock away without disturbing others). Marshall got it right for this little Amp! GREAT AMP for bedroom Rockers!
  4. Duffy49
    Duffy49 Active Member
    Dec 1, 2012
    238
    82
    N. Central Pa. on S. bank of Susquehanna River
    12 inch speaker upgrade?
    When you guys install the 12" speaker in the DSL5C do you just use the front of cab hole for the 10" speaker or do you make that hole on the front a larger radius to allow the 12" speaker to project the sound better.
    If so, how did you cut the larger hole? Rough cut it with a saber saw or what?
    Or, can you effectively use just the existing factory hole for the 10" stock speaker? That would make it a lot easier, of course.
    Thanks. I'm considering one of these.
    The Dsl15c has a reverb; is it especially weak like some DSL40'S? The general opinion seems to be that the 5c is the better sounding amp. What is your opinion?
    Note, I notice pags just posted regarding some of my questions. Thanks pags.
  5. Micky
    Apr 29, 2010
    20,379
    16,555
    Vermont
    I used the existing hole, and it is not a problem.
    To try and enlarge the existing hole would require trimming away quite a bit of the baffle, and might not leave enough surface to reliably mount the 12" speaker.
    It would also require removing the grill cloth in order to do it correctly.
    So what if it blocks a little sound. The little thing is too loud anyway...
    All the DSL's use the same reverb board (daughtercard) and while I wouldn't say it is weak, it certainly is subtle.
  6. Duffy49
    Dec 1, 2012
    238
    82
    Thanks. I would probably try using the existing hole and appreciate your reinforcement of that idea. I may get one of these to replace my Blackstar ht5-rt head that smoked up on me this week and has bent back to Sweetwater for repair or replacement. Blackstar has a weak warranty. I plan to get a Marshall or Fender Bassbreaker 15 head. That little Marshall would fit right in with my DSL40C and a Swamp Thang 12" speaker mod. I like that the 5c is a small form factor amp. I can get it to sit right where the ht5rh sat, right by my side lounging on the bed in my den.
  7. Jello
    Jello New Member
    May 27, 2016
    10
    2
    Hello everyone. This is my first post.
    I bought a DSL5C a few months ago and I love it but I kind of thought the sound was not as robust as I would like.
    I have a Peavey Valveking upgraded with a Celestion Vintage 30 that I use for jamming around town.
    It doesn't quite have a Marshall sound but it isn't bad. I would have preferred a DSL40c for that kind of thing but I got
    the Peavey for free. And, you can't beat free.
    So, this DSL5c is strictly for a living room kind of thing.
    I upgraded the DSL5c with a Celestion Greenback, I believe, and it sounded much better.
    I've read how others have modified the cabinet to install a 12" inch speaker but I don't really want to do that.
    It makes resale hard to do after that kind of modification.
    How about a 1x12 extension cab? Wouldn't a cab with the proper dimensions produce a bigger sound?
    I guess I could use the Peavey as a cab. I should try that. But, what a hassle.
    A 1x12 extension cab wouldn't be that much extra to transport if that was something needed.
    Plus, you could easily switch between 10 and 12 inch speakers.
    Also, has anyone tried a decent EQ in the send/receive loop?
    I want to try a BOSS or MXR. I've got TC Reverb pedal. It is tiny but I haven't used it, yet.
    I apologize if this has been asked before. This is a very long thread. Lots of great information.
    Duffy49 likes this.
  8. Duffy49
    Dec 1, 2012
    238
    82
    Jello, hello, welcome. I'm seriously thinking of buying a dsl5c and definitely putting in a twelve inch Eminence Swamp Thang speaker or such in it. The amp is for me, not the next guy, but to each their own.
    The cabinet sounds like a great idea. I have an Epiphone one by twelve cab that could use a good speaker. But I want to keep it eight ohms, so the speaker upgrade to the new amp will probably be what I'll do.
    Then again I might just get that new Peavey Classic 20 watt small head that has power variables and it can use any of my eight ohm cabinets. Still thinking it thru.
    What guitar are you using? I have several, which is par for this forum and I'm deciding on my next one, ha, ha.
    Are you starting to bond with the amp yet?. Good luck.
  9. Jello
    Jello New Member
    May 27, 2016
    10
    2
    I have a few guitars; a couple SGs, Fender Strat, and a Warmoth mess I recently built that still needs a tweak or two.
    I haven't been in a band for more time than I liked so the DSL5c is essential for me. I've got tons of backing tracks I've found online here and there.
    They keep the chops going.
    I just thought of something. Most guitar companies have custom shops where you can call up and order a guitar to your specs to some degree.
    I don't know of many, if any, amp shop that will do the same. Can you imagine? Contacting Fender or Marshall and ordering an amp to your spec?
  10. Duffy49
    Dec 1, 2012
    238
    82
    Thanks.
  11. Duffy49
    Dec 1, 2012
    238
    82
    I know an amp man here locally that will do that. You can tell him what you want and he will build it, within reason.
  12. Frankiepags
    Frankiepags Member
    May 5, 2016
    64
    19
    City of Angels
    Has anyone used a boost pedal like a spark booster , rc booster or ep booster with this amp ? If so let me know what ya think...I am all ears fellas ..thanks in advance..
  13. JAC
    JAC Well-Known Member
    May 31, 2009
    1,874
    962
    South Orange County, Ca.
    The La Grange OD/Boost by Bogner sounds incredible with the boost on the green channel with my Strat Special. It is a sweet singing sustained tone that brings out a very fine tone in the DSL5C.
  14. Ozark
    Ozark Member
    Feb 14, 2016
    38
    13
    Singapore
    Hi Guys, need end-users advise or recommendation as to which is the better application or Mac OS software for the followings?;
    Sound Surgeon
    Capo
    RiffMaster Pro
    RiffStation
    Am looking for guitar isolation, EQ able, slow-downer, pitch-change and saving/exporting edited files as backup track for jamming.
    Have done some findings and in my opinion, it looks like Sound Surgeon 4 tops the list.
    All recommendation and comments are welcome.
    Thanks in advance.
  15. Micky
    Apr 29, 2010
    20,379
    16,555
    Vermont
    I have used both an Overdrive as well as a Distortion pedal. both 'boost' the signal quite a bit.
    The BOSS OD-1x is very versatile, as a clean boost it can deliver quite a bit of 'volume' before it starts to distort, making this little beast even louder than it already is.
    I also have a modded BOSS DS-1 that can pack quite a punch, but it is all distortion and no clean whatsoever.
    Both of them reise the db level quite a bit, depending on settings...
    Frankiepags likes this.
  16. Frankiepags
    Frankiepags Member
    May 5, 2016
    64
    19
    City of Angels
    Thanks Micky tried out a modded sd1 in front sounded pretty good, got a cusak more louder in a trade and that sounds really good in front..great lil booster pedal with over 25 db boost...also tried the cusak boosting the sd1 but decided on the cusak by it self..if u guys don't know about the more louder it's a great boost definitely recommend it..also the ep booster ,rc booster and the ac booster get rave reviews. That's all for now keep posting guys ..
  17. Unoriginal
    Unoriginal New Member
    Jun 22, 2016
    *Removed*
  18. xStonr
    xStonr New Member
    Jul 19, 2014
    8
    6
    After having this amp for some time, I really started to dislike the stock speaker. I was tempted to replace it with a better 10" but I didn't have one that was 16 ohm. I almost purchased one but decided to see what I had here. Turn out I had a Celestion V30 that was 16 ohm in a 2x12 cab I wasn't using. After taking another look at this thread I decided to make a cutout to accommodate the larger speaker. My work is a little sloppy, but the job did get done and that's the bottom line. If and when I change some tubes, I'll paint inside and maybe rotate the speaker. This is a great thread.[​IMG] [​IMG]
    jchrisf likes this.
  19. jamesm
    jamesm Active Member
    Jun 4, 2009
    114
    35
    3rd rock from the Sun
    If you are interested in changing the speaker, but don't want to effect the second hand value, then why not remove the whole baffle and fit a new one. If you measure the old baffle (allowing for the thickness of the grille cloth) then a timber yard will usually cut this for you, guaranteeing accuracy. You can then cut a hole with a jigsaw yourself, paint it with blackboard paint or similar (I have used water based children's paint mixed 1:1 with PVA glue with good results) and test your practical skills stretching a bit of cloth across it. Then when you sell, pop the original one back in.
    As regards differences between the 15 and the 5, the only change I can remember that is not obvious from the outside is a change of a coupling capacitor in the OD circuit. It controlled the amount of bass frequencies that get distorted and tightens it up a bit. Not pure DSL, but I think it suits this amp's format better.
  20. pedecamp
    13,337
    9,393
    Sheesh you newbs, I have a good mind to send dreyn to your house and kick you square in the nuts for asking a question like that!
    Surely I jest LOL, and welcome! A cab would sound super as apposed to a mini open backed combo that it is. Make or buy a 2x12 and thank me later.
