Dsl5c Sudden Death - Power Issue
Discussion in 'The Workbench' started by myonlybliss, Oct 10, 2017.
  1. Jr Deluxe
    Jr Deluxe Well-Known Member
    Sep 12, 2017
    274
    265
    These little buzz machine amps that get driven hard all the time are going to go through power tubes at least once or twice a year. Get the right fuse and get a new ecc99. Dont even try to power on again without a new power tube. If im right you saved a fuse . If im wrong you got a much needed and soon to be used power tube.
  2. Gunner64
    Nov 16, 2013
    5,779
    7,133
    Midwest, USA
    This...
  3. Richard Martin
    Richard Martin Member
    Oct 17, 2017
    71
    21
    Seen a video on utube on this modle, guy's Marshall gave out at venue, latter found bad fuses and when he checked his power tubes we're not what they should be. He said when he changed his EL34 tubes and re-biased, changed bad fuses, it was fine!
  4. myonlybliss
    myonlybliss New Member
    Jan 20, 2016
    12
    So, I took your advice:
    Replaced the fuse, took out the power tubes and powered the unit. MAGICALLY, the Channel LED came on!!
    Next, with new fuse in I put the tubes BACK IN, then powered up. Amp turned on, Channel LED STILL LIT!
    ALL FIXED, RIGHT!??? All was good until I plugged the guitar cable in from the guitar, then suddenly the amp CRAPPED OUT completely. No power light now......
    Guess I'm going to take it to amp repair shop (since it's still under warranty). Unless you guys have any other suggestions at this point.
  5. Micky
    Apr 29, 2010
    20,626
    16,947
    Vermont
    Have you put a new power tube in it?
  6. myonlybliss
    Jan 20, 2016
    12
    No, I haven't replaced any tubes. Should I try that before dropping off?
    Now, after taking them out and back in and powering up - I'm not even getting the red power light anymore though......
  7. Micky
    Apr 29, 2010
    20,626
    16,947
    Vermont
    If you have a bad tube it could be blowing the fuses.
    Replacing the blown fuses without fixing the problem is wasting time and money.
    mickeydg5 likes this.
