DSL40CR tube location??
Discussion in 'The Workbench' started by FLTWRENCH, Nov 22, 2019.
  1. FLTWRENCH
    FLTWRENCH New Member
    Jul 16, 2009
    11
    I’m trying to figure out V1?? I’ve heard it’s closest to my amp input? But that tube has a metal cover and the power tubes are right behind it, so is this the PI? Man this is frustrating as I can’t find a schematic. Thanks!!
  2. ampmadscientist
    14,256
    8,073
    The V1 preamp tube is the tube closest to the input jack.
    The schematic is a secret, only the authorized service centers will have it.
  3. FLTWRENCH
    Jul 16, 2009
    11
    Hi, thanks for the reply! So it’s the only tube with the metal cover? I just thought it odd to be the tube right next to the EL34’s.
  4. ampmadscientist
    14,256
    8,073
    The tube right next to EL34 is the phase inverter not V1.
    V1 is on the opposite side of the chassis next to the input jack.
  5. FLTWRENCH
    Jul 16, 2009
    11
    My EL34s sit directly behind my input jack
  6. FLTWRENCH
    Jul 16, 2009
    11
    Well actually my power tubes aren’t directly behind my input jack but darn close. Three tube slots have rubber grommets, and the tube slot in front of the power tubes has no rubber grommet but a metal cap that goes over the tube.
  7. ampmadscientist
    14,256
    8,073
    OK then see if you can get the tube location from Kdog.
    I think he will help you find V1 preamp tube on the chassis.
    Kevin (Kdog) Drury
    Marshall USA Service
    1000 Corporate Grove Dr.
    Buffalo Grove, IL 60089
    800-877-6863
    kevin.drury@USMusicCorp.com
    Sorry they are keeping most of the tech info secret right now.
  8. FLTWRENCH
    Jul 16, 2009
    11
    All right. Thanks for the contact info.....I’ve got quite a few amps and finding V1 preamp slot has never been an issue, but this is a crazy layout.
