DSL40CR tube bias - match 'em or not ?
Discussion in 'Marshall Amps' started by Dave J, Nov 26, 2019.
  1. Dave J
    Dave J New Member
    Mar 13, 2019
    16
    21
    So I checked and re-biased my DSL 40CR last weekend. Very easy to do with a simple ohm meter. When I checked bias 1 tube was at 35.1 and one at 31.4mv. Based on posted I have read here I know the range is 28 to 40 with the general guideline around 35- but let your ears decide. I also read on a different forum that not setting both tubes the same ( but within spec) yields more " harmonic content".
    I found around 32mv to be where I liked it, then set one tube to 34mv and left the other at 32. It "seemed" to have more complexity mis-matched , but maybe that is what I wanted to hear.
    Anyway, is a mis-match in bias within specs okay for the amp and tubes? Mine was when I first checked and it has survived but just seeing if there is an opinion. Stock tubes by the way with the exception of the Sovtec LP 12ax7 that went in the PI slot once I settled on bias. It sounds better with it, just a tiny bit smoother and maybe took a tiny bit of the edge that some don't like in the amp away.
    If you have a DSL and have not tried biasing, I recommend it. It's easy and if you stay within the range suggested by Marshall it is another way to find something new in your amp. If nothing else you'll know where the tubes are set now for reference later.
    SkyMonkey and Mitchell Pearrow like this.
  2. Lance Chambers
    Jun 23, 2019
    1,206
    1,819
    The Land That Time Forgot
    I don't think there is much sonic difference in a 2mV variance. The amp itself will fluctuate that much during regular use.:2c:
    :cheers:
  3. Dave J
    Dave J New Member
    Mar 13, 2019
    16
    21
    Makes sense. The process calls for checking, setting, playing it, checking again..... Each tube did fluctuate a small amount during that process. And since even identical tubes are not really I guess the amount each fluctuates changes. So in theory tubes do that mis-match on their own. I am just getting into more tech regarding amps so this was fun to do.
  4. Micky
    Apr 29, 2010
    20,635
    16,972
    Vermont
    It's all about balance. Set them close.
