Dsl40cr Tone Shift
Discussion in 'Marshall Amps' started by lovehifi, May 16, 2018.
  1. lovehifi
    lovehifi Active Member
    Jun 4, 2014
    188
    108
    I tried engaging the tone shift and found I really like it. Especially at lower volumes and with both my Les Paul and Strats. Maybe it has something to do with the pair of Alinco Cream 90s I am running it through but it seems to really tame the highs and bring out some warmth weather using the clean channel or OD channels. Just my opinion and wanted to see if others use it? Also exactly what does the tone shift do as far as adding or cutting frequencies?
    matttornado likes this.
  2. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    8,358
    5,236
    Taintville
    I have had the same experience also when I OWNED one. Sounded much better IMO...its a screatchy amp!!!
    lovehifi likes this.
  3. Jethro Rocker
    5,756
    4,222
    It scoops the mids out for a bit deeper sound. That said, it really prevents the amp from cutting through in a live mix with other guitars. Depending on your style, of course.
  4. LCW
    LCW Active Member
    Jan 18, 2017
    230
    169
    Depending on what pedals you run, I find the Tone Shift gets rid of too much low end. Works in some cases. Not so much in others depending on the sound you're going for.
