Dsl40cr settings
Discussion in 'Marshall Amps' started by Shawnkparsons, Jul 13, 2019.
  1. Shawnkparsons
    Shawnkparsons New Member
    Sep 24, 2018
    4
    5
    So I was In an accident that has landed me at home for years and thought I'd like to learn to play guitar some do i bought a dsl40cr and a PRS s2 standard and a PRS silver sky. Can someone help me with settings for this amp for 70s and 80s rock? Thanks in advance.
  2. Sabbathu
    Sabbathu Active Member
    Apr 2, 2015
    66
    122
    Sorry to hear about your accident, but things happen for a reason, bro. Good luck on your musical journey.
    I have the same amp and I’m still finding new tones. Others here will give you better advise than I can, but in the meantime, enjoy your stay here and enjoy being a musician.
  3. tce63
    tce63 Well-Known Member
    Aug 6, 2018
    632
    1,417
    Sweden
    Sorry about your accident.
    :welcome: to the forum, a great place
  4. Len
    Len Well-Known Member
    Sep 13, 2009
    985
    748
    Start with everything at noon, then tweak to taste (there are no common settings). Keep presence and resonance low at first.
  5. Shawnkparsons
    Sep 24, 2018
    4
    5
  6. Shawnkparsons
    Sep 24, 2018
    4
    5
    Thank you all for the advise and warm welcome to this forum!
    tce63 likes this.
  7. Troy T. Blues
    Troy T. Blues Active Member
    Dec 21, 2010
    283
    177
    Hartford, Connecticut
    Welcome! Yes, good tip is to start with everything at noon as mentioned above. The only things that I do differently are to crank the weak reverb. I also set the master volumes cranked all the way and use the channel volume to taste. It just sounds better to me that way.
  8. Shawnkparsons
    Sep 24, 2018
    4
    5
    Thank you!
  9. BftGibson
    BftGibson Well-Known Member
    May 28, 2018
    1,108
    2,673
    srry for your accident..going thru same thing here for 3 years now...the DSL40cr last year helped pull me thru a dark time. Recorded whole CD on it, capturing how life is when you are stripped of everything in 1 gross negligent act by others..
    I used Classic on red dimed chan & MV like a plexi for tonei & found a whole lotta goodness there using vol & tone knob on guitar.. My gain was never past noon & the pres & res really could dial the amp in
    Ultra chan Red & green..same but gain under noon for most..the heavies came pretty nice & bottom stayed tight. Classic chan run wide open is great for classic hard rock
    Vibes to you recovering.,D
    Sabbathu and Mitchell Pearrow like this.
  10. Mitchell Pearrow
    6,924
    9,457
    :cheers:
    :welcome: To the forum of Marshall
    I see you have got a number of replies, gain under noon is the single best thing to keep in mind, while you are seeking your tone
    These amps have far more gain than you can use.
    Mine are not the cr version, but they are quite similar,
    I am sorry that an accident is what got you started here,
    but kudos to you for having a positive attitude towards it all.
    Excellent first amp to start off on to by the way.
    Don’t get discouraged, this does take time, but as I am sure you have already experienced some tasty things about playing the guitar !
    Enough of my ramblings.
    Cheers Mitch
    CraigP and Sabbathu like this.
  11. Paul H.
    Paul H. Member
    Nov 4, 2018
    35
    42
    Here’s a tip.
    Get yourself a loop pedal. I use a Boss RC 3. It’s a flexible piece of kit and very useful.
    Put something on a loop; a couple of chords, a short lick, maybe a riff or just a sustained power chord.
    Once you’re done play the loop into the front of the amp and twiddle, fiddle, tweak and tune to your hearts content.
    This way you can try all sorts of settings using a consistent, repeatable passage.
    Clean or crunch, OD1/OD2. Gain up, gain down. MV high or low, channel volume....
    The permutations are endless....
    Man, there’s some fun to be had and you’ll definitely find a tone that suits your own unique style.
    This is also an excellent way of hearing your amp at maximum volume outside your house/apartment/dwelling/soon to be former residence!
    So sorry an accident brought you here.
    Super pleased you’re here with us......
    Cheers, Paul H.
  12. Mitchell Pearrow
    6,924
    9,457
    That has been on my mind for a bit now.
    Excellent way to dial in your tone, break in new speakers, put pieces together and be able to solo over your own playing.
    Definitely need to grab one!
    Cheers Mitch
    Troy T. Blues likes this.
  13. SlapHand
    SlapHand Active Member
    Jun 3, 2013
    93
    101
    Norway
    + 100
    I run 2 looper pedals on my board. One first in the chain and one as the last pedal. The first is only used for tweaking tone.
