DSL40c Ultra Gain to Classic Gain
Discussion in 'Marshall Amps' started by Hudge, Dec 27, 2015.
  1. John BNY
    John BNY Well-Known Member
    Jul 13, 2013
    1,776
    2,384
    New York
    I don't know if this will work on the 40C, but on my DSL15C, I replaced the phase inverter tube with an ECC823 tube, and that made the ultra gain channel functional.
  2. ken361
    ken361 Well-Known Member
    Aug 30, 2009
    3,297
    2,126
    detroit rock city
    Check the bias? Set to 60% Creamback speaker works great
  3. Dmann
    Dmann Well-Known Member
    Dec 28, 2008
    1,835
    1,632
    Calgary, Canada
    Well sorry to be the cold slap of reality in the face but the truth is no amount of mods or speaker swap is going to give you what you want.
    Your best bet is to use a overdrive or treble booster pedal into the amp IMHO, or get a different amp.
    The ultra channel is what it is. The sooner you accept that, the better you'll get on with the DSL.
  4. Mitchell Pearrow
    6,931
    9,493
    I like ultra 2 with gain 2.5 volume 4 treb 4.5 mids 6 bass 4 renosence 5 presence 5 tone shift out and I keep the reverb at 3 ymmv:agreed: and yes your guitar volume and tone pots play a big role
    solarburnDSL50 likes this.
  5. Mitchell Pearrow
    6,931
    9,493
    And read the big dsl40c information thread. Your answer’s are in there:2c:
  6. Angus Rhoads
    Angus Rhoads Well-Known Member
    May 10, 2017
    638
    929
    SF Bay Area, California
    If you're running the stock speaker, try a speaker change. The Ultra Lead channel is very responsive to speaker changes. One of the many Greenback variants would probably help you get to the sound you're looking for (especially if you keep the gain around 4-5). Speaker swaps are really easy with this amp, so it's worth trying that before doing circuit mods.
  7. coyote
    coyote Active Member
    Sep 20, 2015
    79
    105
    Thanx 4 the replies folks.
    My amp has a Creamback, but that’s not the issue.
    My fave amp setting is Classic gain, clean mode, gain at around 4. Sounds terrific; nice full response across the board. Exactly how a Marshall should normally sound!
    But it can’t bridge the gap to either Lead1 or Lead2. Too much off the rest of the signal is lost.
    So my compromise has been to run Classic, Crunch - and then footswitch to Lead1. For that to work, the bass has to be turned up a bit... and it gets a tad mushy.
    I listened to a couple of the vids comparing the C19 mod to stock. Not bad, but not sure it does what I want. I might try an EQ in the effects loop. Or I might try leaving the amp on Clean all the time, and put a treble booster in the effects loop to kick it when I want it.
  8. coyote
    Sep 20, 2015
    79
    105
    EDIT: this post is no longer relevant, except as history. My settings are no longer like this.
    I found a sweet spot. Here are the settings:
    The Classic channel is in Crunch mode, and the Ultra channel is on Lead 1. Tone Shift is off, of course.
  9. solarburnDSL50
    Aug 8, 2008
    15,449
    8,632
    Wetville
    Put the gain lower...play with higher volume. Adjust guitar volume too.
    L2 gain low...stock and changing pups only. No channel changing.
  10. Mitchell Pearrow
    6,931
    9,493
    Hell yes bro, Solar knows what he is doing! The settings I posted, came from a tone wise pro :cheers:
  11. coyote
    Sep 20, 2015
    79
    105
    Update: funny how playing with the band, rather than on you own, changes your perspective.
    Amp is unplugged and discharging its capacitors.
    C19 will be taken out of the circuit this weekend.
  12. ken361
    Aug 30, 2009
    3,297
    2,126
    detroit rock city
    your gain is set way low! thinner tone! 5 to 7 is the sweet spot for most and check bias!~
  13. coyote
    Sep 20, 2015
    79
    105
    The amp was re-tubed and biased just a year ago. And I find that, at playable levels, increased gain on the Ultra channel just makes it ever more brittle. I have to turn down the Volume to compensate, and it doesn’t work.
    I was somewhat surprised by all this, as the ‘formula’ generally says to decrease bass frequency on guitars to keep them out of the way of other instruments. It’s just overdone on the Ultra channel on this amp.
    The happy result will be that I get the ‘clean’ sound plus a useful equivalent of the ‘crunch’ at the tap of a footswitch.
  14. jericbrazier
    jericbrazier Well-Known Member
    Nov 12, 2016
    552
    466
    I found Ultra 2 unusable with my hss Strat, but with my high output pup equipped Lester it sounds killer, no pedal required. I can get a convincing Cantrell, Adam Jones type tone. For Adam Jones; just a touch of chorus, and a lot of cocked wah.
  15. oldmanrockin
    oldmanrockin Member
    Feb 22, 2017
    78
    39
    I use the crunch channel with an OCD in front going through a G12H-30 on half power mode for rhythm and fill leads. For full leads i use the od1 with c-19 clipped and leave the ocd on, just change channels. I can get the boost i want for leads through the od1 and it sounds like a hotter crunch channel. I mostly play classic rock 70's - 80's.
    Mitchell Pearrow and Yamariv like this.
  16. ken361
    Aug 30, 2009
    3,297
    2,126
    detroit rock city
    what was the bias at ?? only need like 32 most set it way too high if its brittle and and not very clear at 4 on the volume its probably too hot.
  17. coyote
    Sep 20, 2015
    79
    105
    I don’t know, I did not bias it myself.
  18. solarburnDSL50
    Aug 8, 2008
    15,449
    8,632
    Wetville
    you're doing good. Asking good questions.
    learn to bias yourself and experiment. It will pay off. If I can do it you can. No BS!
  19. coyote
    Sep 20, 2015
    79
    105
    Final installment in the saga: C19 removed, owner much happier. :eddie:
    I can now dial down the bass on the amp while retaining the fullness, AND get the top end boost if I want it. And the amp noise has dropped considerably.
    I would consider adding a switch to put C19 back inline on demand as a useful and valid modification. A micro SPST directly above the Channel Select pushbutton would work, so that should the need ever arise you can simply throw the switch and have the ‘stock’ configuration. Perhaps even an on-off-on DPDT, with the 470 cap on one side and a different value (perhaps 100, some have reported good results with this) on the other....
    EDIT: I will be adding LEDs to the Marshall channel/reverb selector footswitch. There’s a YouTube vid on how to do it:
  20. jericbrazier
    Nov 12, 2016
    552
    466
    Couldn’t this be accomplished with a clean boost? Not buying a 2 channel amp with 4 modes, and only wanting a variation of one tone.
