Dsl100hr Bad Volume Drop Off
Discussion in 'Introduce Yourself' started by Slim007, Apr 26, 2019.
  1. Slim007
    Slim007 New Member
    Nov 3, 2017
    2
    Hi Marshall family,I got a DSL100HR 10 months ago and now I got a problem, while jamming the other day I had a bad volume drop off called Sweetwater tech he said a preamp tube went out and sent me one.I went through all 4 changing them out one by one and it didn’t fix the problem any thoughts on what it could be before I send it back?
    Wooferhead1 and Mitchell Pearrow like this.
  2. Mitchell Pearrow
    5,706
    7,156
    :welcome: To the forum, only time this has happened to me (dsl40c’s) it was a preamp tube, are you able to test the tube, that was sent to you? It might also be a dud, the reason I say this is I purchased 4 current production mullards and 1 was DOA! If you have any other spares to check? Cheers Mitch
  3. sjruvolo
    sjruvolo Member
    Aug 7, 2015
    59
    33
    Maybe you swapped out the wrong "bad" tube. Try another preamp tube position.
  4. Trident
    Trident Well-Known Member
    Mar 8, 2018
    793
    883
    Paradise in FLORIDA
  5. Kutt
    Kutt Well-Known Member
    May 27, 2010
    767
    767
    Massachusetts, USA
    You'd really need additional preamp tubes to rule out if that's the issue or not. Hard to say for sure what's going on otherwise. Sorry to hear about your troubles. We all go through them unfortunately!
  6. Slim007
    Slim007 New Member
    Nov 3, 2017
    2
    I appreciate the feedback and so I took the one new one and replaced it with the first in line and let it warm up,turned it on and still the same volume problem I swapped it back out with the original and Just tried to eliminate one at a time I’m hoping maybe it could be two out I purchased 4 new ones they will arrive in a couple of days,let me ask y’all this the pre amp tubes still burn (glow) I assume one could still be bad even if it’s glowing?
  7. Micky
    Apr 29, 2010
    19,856
    15,792
    Vermont
    Greetings!
  8. Dogs of Doom
    17,921
    16,578
    :welcome:to the forum...
    :cheers:
  9. Mitchell Pearrow
    5,706
    7,156
    Yes the one that went bad on me was still glowing, and the pencil eraser method still didn’t show anything! Cheers to getting it going! Mitch
  10. pedecamp
    12,170
    7,378
    If you plug your guitar into the effects loop return and the problem goes away I believe this will confirm the problem is in your preamp, most likely a bad preamp tube.
    If you need to check your power section pull the 2 inner or outer power tubes (I would try both ways to isolate) to see if the problem goes away, you may have a bad power tube possibly.
    Did you check all the obvious like your cables, guitar, etc.
    BftGibson likes this.
  11. ampmadscientist
    11,614
    5,658
    Left Coast
    Plug a guitar cable from efx send to efx return.
    Now play the amp and test.
    Did the problem go away?
    And welcome to the forum :cheers:.
