Dsl100 Ht Fuse Continuously Blowing
Discussion in 'The Workbench' started by rawker999, Apr 7, 2019.
  1. ampmadscientist
    12,794
    6,683
    Left Coast
    Was the output transformer disconnected when you tested it?
    If so, pin 5 on the output socket would be shorting to pin 4 on the board, which means the board is bad.
    This was the 7th board we tested, and the only one that was (seems to be) shorted.
    The clue was that when you replaced the bias pots, the bias was reading -27 volts (was it really reading that?) I believe you, I'm just trying to confirm this.
    The bias should read about -45 to -47 DC on pin 5.
    If it really was -27, that means that the bias voltage is shorted on the board and the voltage is being loaded down by that short circuit.
    (that's what we didn't expect) Shorted to pin 4 I'm expecting.
    Was the bias reading -27 volts on pin 5 "before" you turned the standby to operate position? Very important need to know this.
    This is important because it gives a way to judge if a board is bad or not. It's going to help trouble shoot a lot of other DSLs.
    And unfortunately, it will also mean that the board you have was actually bad.
    But it didn't show any sign of being bad until the bias pots were in place / working. (the - 27 was the signal that the board was bad / bias was loaded down.)
  2. rawker999
    rawker999 Member
    Jan 3, 2014
    56
    North , New Jersey
    Yes. W3-W5 disconnected. Speaker cable going to a cab. Not a single tube in the amp. Power on and standby in operate. Pin 5 on all power tubes read approx -27 to -28. I just turned it all back on for the hell of it. V5-V6 still read -28 and V7-V8 smell like burning and read “OL”. Same with standby off or in operate mode. The fuse has not blown.
  3. ampmadscientist
    12,794
    6,683
    Left Coast
    OK so the board was bad. Pin 5 is probably shorted (arced / burned) to pin 4 on the board.
    That is extremely useful information which can help a lot of others.
    The only thing that you can do is replace the board or install the Dr tube bias board modification.
    The OT is shorted, as we already knew.
    And therefore the amp is probably not worth fixing, compared to buying another working amp.
    It's going to cost at least $350 in parts to replace the OT and the board.
    But do us a favor
    Unplug power from amp.
    Set meter to ohms.
    Measure between pin 5 and pin 4 of all output sockets on the board.
    How many ohms does it read between pin 5 and 4 of the output tube sockets?
    Please pass those readings on to the forum?
  4. rawker999
    rawker999 Member
    Jan 3, 2014
    56
    North , New Jersey
    The Dr Tube kit is only 45EUR and a new output transfer is $80 so I may give that a shot before buying a new head. Not sure.
    From pin 4 to 5 with no power on, multimeter set to ohms reads OL across the board.
  5. ampmadscientist
    12,794
    6,683
    Left Coast
    What ohm meter are you using?
    Is the range of ohms adjustable or is it auto-range?
  6. rawker999
    rawker999 Member
    Jan 3, 2014
    56
    North , New Jersey
    I tried again at the 600k range and this is what I get.
    V5-V6 read about 235 and continue to increase over 300.
    V6 reads a steady 0.8
    V7 reads a steady 14.8
  7. ampmadscientist
    12,794
    6,683
    Left Coast
    And V7 is the one that arced?
    And all the tubes are out of the amp? (measure it that way?)
    "V5-V6 read about 235 and continue to increase over 300."
    That reading would be normal, you are reading / seeing capacitors charging up.
    "V6 reads a steady 0.8
    V7 reads a steady 14.8"
    That reading would be a short circuit between screen grid pin 4 and control grid pin 5.
    The short circuit is reading 800 ohms between the 2 pins at V6 socket.
  8. rawker999
    rawker999 Member
    Jan 3, 2014
    56
    North , New Jersey
    No tubes anywhere near this amp.
    V7 is the one that lit on fire, yes.
  9. ampmadscientist
    12,794
    6,683
    Left Coast
    Apparently there is a carbon spot burned on the board, under the tube socket.
    That's why Dr Tube cuts pin 5 off the circuit track / board with a hollow point drill.
    Sapphire Sounds likes this.
  10. rawker999
    rawker999 Member
    Jan 3, 2014
    56
    North , New Jersey
    Sounds about right there is indeed a burnt circle that I can kinda see through the tube socket opening. This is all way more of an adventure than I thought i would be going on when I opened up my amp haha.
  11. ampmadscientist
    12,794
    6,683
    Left Coast
    Damn.
  12. rawker999
    rawker999 Member
    Jan 3, 2014
    56
    North , New Jersey
    I’ll see if can get a picture
  13. rawker999
    rawker999 Member
    Jan 3, 2014
    56
    North , New Jersey
    Decided to give dr tube a try. Are they still in business? The website won’t let you add anything to your cart. It just jumps you back to the home page if you click add to cart.
  14. ampmadscientist
    12,794
    6,683
    Left Coast
    Dr. tube is a forum member. You can send a PM to him.
    rawker999 likes this.
  15. Gunner64
    Gunner64 Well-Known Member
    Nov 16, 2013
    4,659
    5,045
    Midwest, USA
    I found ordering on the website difficult. I ordered from valvetubeguitaramps.com.
  16. Sapphire Sounds
    Sapphire Sounds Member
    Apr 1, 2019
    43
    21
    https://valvetubeguitaramps.com/product/marshall-jcm2000-bias-mod-kit-tsl-series/
    Good luck with your DSL I am going to be taking my amp apart to see the board name/revision number my TSL 122 has. The combo amps using the old boards have them upside down so all the heat goes up to it from the tubes underneath with no top vents....
  17. Adrian R
    Adrian R Well-Known Member
    Jan 28, 2009
    6,154
    4,168
    Far North Chicago Burbs'
    I forgot to mention... It is very important you replace the fuse not only with the correct current rating, but also whether or not it's a slo-blow or quick acting fuse! 'T' stands for timed blow....and is totally required in this position. If you put in a quick acting fuse it will always blow instantly regardless of the amp.
  18. Fender
    Fender Active Member
    Nov 14, 2017
    251
    184
    I sometimes think that marshall should do once and for all a recall of every JCM2000 DSL with the faulty PCB and replace them with a new DSL HR. Those conductive PCBs are nothing other than a disgrace :/ and responsible for 90% of the bad reliability reputation attached to modern marshalls...
    Mitchell Pearrow and Gunner64 like this.
  19. ampmadscientist
    12,794
    6,683
    Left Coast
    It was a very embarrassing streak of design mistakes...from exploding hum balance controls, to circuit boards with defective insulation, defect bias adjust design, to programmable controller chips that crapped out, etc.
  20. Gunner64
    Nov 16, 2013
    4,659
    5,045
    Midwest, USA
    I agree..but doing so probably would have doomed the company.
