DSL parts sourcing
Discussion in 'The Workbench' started by Buggs.Crosby, Jun 15, 2011.
  1. Kunnz
    Kunnz Active Member
    Mar 6, 2009
    846
    145
    No Fixed Abode
    I hope this list is of some help for Ireland/UK/Europe, from Farnell UK
    The parts are for a total recap and mods.
    Order Code Mftr. & Part No. Qty Ordered Qty Delivered Date Shipped Tracking Number Line Status Unit Price Line Price
    1165420
    VISHAY BC COMPONENTS
    MAL203036229E3 5 5 03 Mar 2012 Tracking number not available Complete
    £0.36 £1.80
    Description: CAPACITOR, 22UF, 25V; Capacitance:22µF; Capacitance Tolerance:-10%, +50%; Voltage Rating:25V; ESR:10.2ohm; Life Time @ Temperature:3000 hours @ 85°C; Height:10.5mm; Diameter:5mm; Capacitor Mounting:Through Hole; Capacito
    9693130
    PANASONIC
    ECA2AHG100 5 5 03 Mar 2012 Tracking number not available Complete
    £0.125 £0.62
    Description: CAPACITOR, 10UF, 100V; Capacitance:10µF; Capacitance Tolerance:± 20%; Voltage Rating:100V; Life Time @ Temperature:2000 hours @ 85°C; Height:11.2mm; Diameter:6.3mm; Capacitor Mounting:Through Hole; Capacitor Terminals:Ra
    9693122
    PANASONIC
    ECA2AHG4R7 5 5 03 Mar 2012 Tracking number not available Complete
    £0.098 £0.49
    Description: CAPACITOR, 4.7UF, 100V; Capacitance:4.7µF; Capacitance Tolerance:± 20%; Voltage Rating:100V; Life Time @ Temperature:2000 hours @ 85°C; Height:11mm; Diameter:5mm; Capacitor Mounting:Through Hole; Capacitor Terminals:Radi
    1673499
    PANASONIC
    EEUEE2W100U 5 5 03 Mar 2012 Tracking number not available Complete
    £0.41 £2.05
    Description: CAPACITOR, 10UF, 450V, 10X20MM; Capacitance:10µF; Capacitance Tolerance:± 20%; Voltage Rating:450V; Life Time @ Temperature:8000 hours @ 105°C; Height:20mm; Diameter:10mm; Capacitor Mounting:Through Hole; Capacitor Termi
    9692932
    PANASONIC
    ECA1HHG220 5 5 03 Mar 2012 Tracking number not available Complete
    £0.099 £0.50
    Description: CAPACITOR, 22UF, 50V; Capacitance:22µF; Capacitance Tolerance:± 20%; Voltage Rating:50V; Life Time @ Temperature:2000 hours @ 85°C; Height:11mm; Diameter:5mm; Capacitor Mounting:Through Hole; Capacitor Terminals:Radial L
    9693033
    PANASONIC
    ECA1JHG470 5 5 03 Mar 2012 Tracking number not available Complete
    £0.142 £0.71
    Description: CAPACITOR, 47UF, 63V; Capacitance:47µF; Capacitance Tolerance:± 20%; Voltage Rating:63V; Life Time @ Temperature:2000 hours @ 85°C; Height:11.2mm; Diameter:6.3mm; Capacitor Mounting:Through Hole; Capacitor Terminals:Radi
    1165467
    MAL202136101E3 2 2 03 Mar 2012 Tracking number not available Complete
    £0.34 £0.68
    Description: CAPACITOR, 100UF, 25V; Capacitance:100µF; Capacitance Tolerance:± 20%; Voltage Rating:25V; ESR:2.3ohm; Life Time @ Temperature:500 hours @ 85°C; Height:10mm; Diameter:6mm; Capacitor Mounting:Through Hole; Capacitor Termi
    1165465
    MAL215267229E3 3 3 03 Mar 2012 Tracking number not available Complete
    £1.20 £3.60
    Description: CAPACITOR, 22UF, 450V; Capacitance:22µF; Capacitance Tolerance:± 20%; Voltage Rating:450V; ESR:14.5ohm; Life Time @ Temperature:3000 hours @ 105°C; Height:25mm; Diameter:16mm; Capacitor Mounting:Through Hole; Capacitor T
    1673486
    PANASONIC
    EEUEE2V101 2 2 03 Mar 2012 Tracking number not available Complete
    £2.63 £5.26
    Description: CAPACITOR, 100UF, 350V, 18X31.5MM; Capacitance:100µF; Capacitance Tolerance:± 20%; Voltage Rating:350V; Life Time @ Temperature:10000 hours @ 105°C; Height:31.5mm; Diameter:18mm; Capacitor Mounting:Through Hole; Capacito
    1198680
    PANASONIC
    EETUQ2G331CA 2 2 03 Mar 2012 Tracking number not available Complete
    £3.86 £7.72
    Description: CAPACITOR, 330UF, 400V; Capacitance:330µF; Capacitance Tolerance:± 20%; Voltage Rating:400V; ESR:0.603ohm; Life Time @ Temperature:2000 hours @ 85°C; Height:40mm; Diameter:25mm; Capacitor Mounting:panel; Capacitor Termin
    9693610
    PANASONIC
    ECA1CM102 5 5 03 Mar 2012 Tracking number not available Complete
    £0.31 £1.55
    Description: CAPACITOR, 1000UF, 16V; Capacitance:1000µF; Capacitance Tolerance:± 20%; Voltage Rating:16V; Life Time @ Temperature:2000 hours @ 85°C; Height:16mm; Diameter:10mm; Capacitor Mounting:Through Hole; Capacitor Terminals:Rad
    9693700
    PANASONIC
    ECA1VM471 5 5 03 Mar 2012 Tracking number not available Complete
    £0.23 £1.15
    Description: ALUM ELECT CAP, 470UF, 35V, RADIAL; Capacitance:470µF; Capacitance Tolerance:± 20%; Voltage Rating:35V; Life Time @ Temperature:2000 hours @ 85°C; Height:16mm; Diameter:10mm; Capacitor Mounting:Through Hole; Capacitor Te
    9692746
    PANASONIC
    ECA1AHG332 5 5 03 Mar 2012 Tracking number not available Complete
    £0.40 £2.00
    Description: CAPACITOR, 3300UF, 10V; Capacitance:3300µF; Capacitance Tolerance:± 20%; Voltage Rating:10V; Life Time @ Temperature:2000 hours @ 85°C; Height:20mm; Diameter:12.5mm; Capacitor Mounting:Through Hole; Capacitor Terminals:R
    1141766
    VISHAY
    K151J15C0GF53L2 5 5 03 Mar 2012 Tracking number not available Complete
    £0.128 £0.64
    Description: CAPACITOR, 150PF, 50V; Dielectric Characteristic:C0G / NP0; Capacitance:150pF; Capacitance Tolerance:± 5%; Voltage Rating:50V; Capacitor Mounting:Through Hole; Capacitor Terminals:Radial Leaded; Lead Spacing:2.5mm; Opera
    9752919
    EPCOS
    B32529C222K 5 5 03 Mar 2012 Tracking number not available Complete
    £0.22 £1.10
    Description: CAPACITOR, 2.2NF, 63V; Capacitor Dielectric Type:polyester (PET); Capacitance:2200pF; Capacitance Tolerance:± 10%; Voltage Rating:63V; Life Time @ Temperature:200000 hours @ 40°C; Capacitor Mounting:Through Hole; Capacit
    1141792
    F102K39Y5RN6UK5R 5 5 03 Mar 2012 Tracking number not available Complete
    £0.121 £0.60
    Description: CAPACITOR, 1NF, 1000V; Dielectric Characteristic:Y5R; Capacitance:1000pF; Capacitance Tolerance:± 10%; Voltage Rating:1kV; Capacitor Mounting:Through Hole; Capacitor Terminals:Radial Leaded; Lead Spacing:5mm; Operating T
    1834164
    MAL203858108E3 10 10 03 Mar 2012 Tracking number not available Complete
    £0.066 £0.66
    Description: CAPACITOR, RADIAL, 63V, 1UF; Capacitance:1µF; Capacitance Tolerance:± 20%; Voltage Rating:63V; Life Time @ Temperature:2500 hours @ 85°C; Height:11mm; Diameter:5mm; Capacitor Mounting:Through Hole; Capacitor Terminals:Ra
    9340734
    MULTICOMP
    MF50 5K6 50 50 03 Mar 2012 Tracking number not available Complete
    £0.027 £1.35
    Description: RESISTOR, 0.5W 1% 5K6; Resistance:5.6kohm; Resistance Tolerance:± 1%; Power Rating:500mW; Voltage Rating:350V; Temperature Coefficient:± 50ppm/°C; Resistor Element Material:Metal Film; Resistor Terminals:Axial Leaded; Re
    1565363
    WELWYN
    MFP1-220K JI 10 10 03 Mar 2012 Tracking number not available Complete
    £0.181 £1.81
    Description: RESISTOR, 1W 5% 220K; Resistance:220kohm; Resistance Tolerance:± 5%; Power Rating:1W; Voltage Rating:350V; Temperature Coefficient:± 50ppm/°C; Resistor Element Material:Metal Film; Resistor Terminals:Axial Leaded; Resist
    9693106
    PANASONIC
    ECA2AHG2R2 5 5 05 Mar 2012 Tracking number not available Complete
    £0.10 £0.50
    Description: CAPACITOR, 2.2UF, 100V; Capacitance:2.2µF; Capacitance Tolerance:± 20%; Voltage Rating:100V; Life Time @ Temperature:2000 hours @ 85°C; Height:11mm; Diameter:5mm; Capacitor Mounting:Through Hole; Capacitor Terminals:Radi
    9340173
    MULTICOMP
    MF50 200K 50 50 03 Mar 2012 Tracking number not available Complete
    £0.027 £1.35
    Description: RESISTOR, 0.5W 1% 200K; Resistance:200kohm; Resistance Tolerance:± 1%; Power Rating:500mW; Voltage Rating:350V; Temperature Coefficient:± 50ppm/°C; Resistor Element Material:Metal Film; Resistor Terminals:Axial Leaded; R
  2. strohm
    strohm New Member
    Apr 16, 2012
    By guys, new to the blog. Im looking for info on selector switch on a 1960a 4x12 cab? Can't seem to find it without having to buy the whole panel for $99. Anyone?
  3. Beefy 800
    Beefy 800 New Member
    Mar 1, 2014
    2
  4. instinctfx
    instinctfx Active Member
    Jun 14, 2010
    115
    45
    Brisbane, QLD Australia
    {EDIT} ALL SORTED.
    Lads and ladies! I need to get 2 new jacks for my send and return loop for a DSL 100 head. Im in Australia and does anyone know of a place that stocks the correct ones ? or a decent substitute ??? Jaycar perhaps ? Element14 ?
    Its rather urgent too, i have a festival gig coming up in a couple of weeks
  5. Grogshla
    Grogshla Active Member
    Jul 9, 2012
    780
    175
    what transformers does a stock jcm2000 dsl use. No1 can tell me. I need them asap
  6. Grogshla
    Jul 9, 2012
    780
    175
    Hit up Elfa in melbourne who supply marshall gear.
    Personally though just take it to any amp tech he will fix it up in 2 seconds
  7. andywragg
    andywragg Member
    Oct 9, 2015
    41
    Sheffield - UK
    Anyone else in the UK.
    HotRoxUK.com has the pots/switches/jacks and other cabinetry. New boards can be got from Marshall themselves.
  8. therealjoeblow
    therealjoeblow New Member
    Mar 18, 2015
    22
    Does anyone know who makes the multi-conductor board connectors for these amps (model no/brand)? IE CON3/CON10, the 6-pin multi connector on the front and rear board?
    thanks
    TRJB
  9. therealjoeblow
    Mar 18, 2015
    22
    Nevermind, answering my own question here. ALL of the small white board connectors on the JCM 2000, Vintage Modern, MG series and most other modern amps are "JST EH" series connectors, available from Digikey and various eBay sellers.
    Cheers
    TRJB
  10. cudbucket
    cudbucket Active Member
    May 21, 2016
    120
    31
  11. Copperheadroads
    Copperheadroads Member
    Oct 6, 2012
    99
    26
    On a Rock in the North Atlantic
  12. Copperheadroads
    Oct 6, 2012
    99
    26
  13. cudbucket
    May 21, 2016
    120
    31
  14. cudbucket
    May 21, 2016
    120
    31
    So much great info here. I have my DSL on the bench right now and have done the speaker jack mod as well as replacing C46 with a 1kV cap. Tomorrow, C12 comes out. Can anyone help me with spec'ing the 7 "big" caps on the tube board. This is what I'm planning to order from Mouser.
    330uF 315v: http://www.mouser.com/Search/Produc...RDvirtualkey64700000virtualkey647-UVZ2F331MRD
    100uF 350v: http://www.mouser.com/Search/Produc...HDvirtualkey64700000virtualkey647-UCY2V101MHD
    22pF 450v: http://www.mouser.com/Search/Produc...Svirtualkey66720000virtualkey667-EEU-EE2W220S
    Also, I want to get turrets for the Choke install. What size mounting hole do I need when ordering the turrets? Thanks so much!
    Dave
  15. RickyLee
    May 22, 2010
    8,253
    2,145
    Riverside CA U.S.A.
    Just checking to see if you found those DSL/TSL PCB cables on Digikey? I have been searching there and Mouser and not finding them. I mainly need a few of the 2 conductor type but could use a assortment of them.
  16. thebowl
    thebowl Member
    Jun 29, 2014
    41
    24
    I have a burned Resistor on my DSL40c. it is connected to a power tube socket (both ends). It is brown and labeled "RW5W" 1K (ohm)-J". I found two 5 watt, 1K resistors that look like it on DigiKey. Can anyone help me nail down exactly what I need? Thanks.
  17. Neil Skene
    Neil Skene Active Member
    Oct 3, 2011
    235
    141
    Australia
  18. BadgerO
    BadgerO Active Member
    May 27, 2016
    185
    63
    Tehran- Iran
    Here's a nice ma and pa operation in Canada, justradio.com. competitive prices, all the strange values with good variety, they have new stock and it's cheaper when you order from outside Canada.
