DSL CR1 needs help
Discussion in 'Marshall Amps' started by jerkface, Jan 24, 2020.
  1. jerkface
    jerkface Member
    Jan 24, 2020
    29
    31
    I am thinking of buying a real tube distortion pedal as the amp needs a little more something!! I want to keep it to real tubes as the amp is tube. Any ideas???
    tce63 likes this.
  2. Dogs of Doom
    20,631
    21,435
    you don't need a distortion pedal, get an overdrive, that will push the 1st tube on the DSL...
    daiku, jerkface, scozz and 1 other person like this.
  3. tce63
    Aug 6, 2018
    1,339
    3,382
    Sweden
    TC-E Spark Boost or Boss SD-1
    And :welcome: to the forum
    jerkface, SkyMonkey and scozz like this.
  4. jerkface
    jerkface Member
    Jan 24, 2020
    29
    31
    thank you. Good advice.
    tce63 likes this.
  5. jerkface
    jerkface Member
    Jan 24, 2020
    29
    31
    Was thinking pedal with real tube in it. ty for advice.
    tce63 likes this.
  6. Gunner64
    Nov 16, 2013
    5,782
    7,140
    Midwest, USA
    Clean boost the front end with a ts9 or sd1,..all level, no drive ..tone to taste..or an eq pedal.. No need for another tube. trust us. We've been through a million of these things.:)
    jerkface and tce63 like this.
  7. RCM 800
    RCM 800 Active Member
    Dec 20, 2019
    127
    216
    Overdrive or EQ will get you there. Tube pedals are a gimmick IMO.
  8. Gunner64
    Nov 16, 2013
    5,782
    7,140
    Midwest, USA
    Boosting the front end tightens things up..and pushes the preamp into a tad more natural overdrive. However, I have the DSL1HR, and have more speaker options at my disposal, my favorite with this amp is a jensen falcon 40 10". Fwiw Most low watt combos that I have come into contact with suffered from the size/ choice of the speaker, and there's not much you can do about that really, except use a different speaker. I think they should have put a bit more thought into the speakers in these little combos.
  9. FracStrat
    FracStrat Well-Known Member
    Jan 22, 2020
    257
    648
    Water Side of WA State
    Well put Gunner !!!
    Gunner64 and tce63 like this.
  10. jerkface
    jerkface Member
    Jan 24, 2020
    29
    31
    ok ty i love channel 9 on my CODE amp. I was hoping for a little more with dsl.
    tce63 likes this.
  11. jerkface
    jerkface Member
    Jan 24, 2020
    29
    31
    spark says add after distortion??
    tce63 likes this.
  12. jerkface
    jerkface Member
    Jan 24, 2020
    29
    31
    I adjusted the eq and gain on amp. wow! Its my first tube amp and just adjusting eq does alot to change sound! I ordered spark boost. Thanks for advice on forums Im a newbie tube amp owner.
    tce63 likes this.
  13. jerkface
    jerkface Member
    Jan 24, 2020
    29
    31
    I ordered spark ty for advice.
    tce63 likes this.
  14. jerkface
    jerkface Member
    Jan 24, 2020
    29
    31
    I ordered spark. how plug in??
    tce63 likes this.
  15. Gunner64
    Nov 16, 2013
    5,782
    7,140
    Midwest, USA
    Between your guitar and amp. I have not used the spark. I use a TS9 tubescreamer.
    tce63 and jerkface like this.
  16. tce63
    Aug 6, 2018
    1,339
    3,382
    Sweden
    I think DSL1 CR has a loop.
    Try it there first :agreed:
