DSL 15C, what did I do?
Discussion in 'The Workbench' started by Krauthammer, Oct 23, 2015.
  1. Krauthammer
    Krauthammer Active Member
    Dec 31, 2013
    158
    37
    Hey guys,
    Need help figuring out what I did wrong, so that I don't do it again and ruin my amp.
    I have a DSL 15C, and was playing in a small room with a drummer. Had plenty of volume on the OD channel. Went to do a song on the clean channel, and after about 30 seconds, the amp just went quiet. No loud "pop" or anything like that, just faded quickly to zero volume.
    I was running through my pedal board. On the board, I had a Boss tuner, an MXR micro amp, and a Boss Chorus. The board has your standard 9V supply.
    I think I may have the wrong power supply for the Boss Chorus, because I had to hold the switch down to get the light to come on steady. Doesn't come on like most pedals where you just "stomp" and it's on.
    The volume on the clean channel was up around 9. The Chorus was on.
    I was able to get the amp back, by switching the Pentode/Triode switch from Pentode (Full power) to Triode (half power). However, when I went back to Pentode, the amp was still quiet.
    Drove home, and about an hour later, powered it up in the Pentode mode and it worked again.
    Any ideas what may have happened, what I did wrong, and how to keep it from happening again? Also, do you think I did any permanent damage? Just wondering if I need to take it in and have someone look at it. Don't want it blowing out at a gig, need to know I can rely on it.
    Thanks from the Hammer
  2. EndGame00
    EndGame00 Well-Known Member
    Mar 4, 2013
    4,842
    2,897
    Bay Area, CA
    One of the preamp tubes failed...
  3. Krauthammer
    Dec 31, 2013
    158
    37
    Sounds reasonable. Would that still allow it to work in the Pentode (Full Power) mode?
  4. Micky
    Apr 29, 2010
    20,376
    16,552
    Vermont
    One of the power tubes probably went bad...
    Or has an intermittent failure.
  5. mott555
    mott555 Well-Known Member
    Mar 25, 2013
    3,466
    2,639
    Omaha
    Bad tube and/or blown fuse. Your chorus pedal probably has some dirty contacts and doesn't realize everything's plugged into it but that wouldn't cause your amp to fail.
  6. Krauthammer
    Dec 31, 2013
    158
    37
    Thanks, I figured as much, but wanted to list all the possible suspects.
    Anyone know where I can get info on how to trouble shoot the basic stuff myself? The Marshall owner's manual leaves a lot to be desired...
  7. EndGame00
    Mar 4, 2013
    4,842
    2,897
    Bay Area, CA
    Start with tubes first as process of elimination.
  8. Krauthammer
    Dec 31, 2013
    158
    37
    Will do.
  9. Krauthammer
    Dec 31, 2013
    158
    37
  10. Micky
    Apr 29, 2010
    20,376
    16,552
    Vermont
    Tubes can 'look' OK, but be bad.
    There is a main power fuse in the AC Power socket.
    The other fuses are accessible when you take out the chassis.
  11. Krauthammer
    Dec 31, 2013
    158
    37
    Thanks, I was afraid of that.
  12. mickeydg5
    22,630
    9,945
    No, start with everything out of the effects loop and then figure out if the Pentode/Triode modes are working.
