Discount for a vintage 8 hole PA vs 4 hole
Discussion in 'Let's Talk Vintage' started by Pageburst, May 19, 2019.
  1. Pageburst
    Pageburst Member
    Jun 26, 2017
    54
    51
    I wonder if any of the knowledgeable folks here could let me know as the 8 hole long box PA versions I’ve seen seem to be priced at about 1/2 of the 4 hole counterparts.
    I don’t know if I’d want one as they are a bit ungainly aesthetically but it might be a more reasonable way into a nice original vintage piece.
  2. pulsonicsound
    pulsonicsound Active Member
    Apr 6, 2019
    79
    103
    I have a few Marshall PA’s, sound wise their isn’t much difference between a PA and a superbass
    It’s not very hard to mod a few of the channels to lead specs.
    You’d be in good company!
  3. Pageburst
    Pageburst Member
    Jun 26, 2017
    54
    51
    Thanks Pulsonic, I agree with you regarding to the standard PA spec but I'm speaking about the long 8 hole version which is completely different head box.
  4. D-Max
    D-Max Member
    Jun 28, 2009
    94
    35
    Somewhere in the old world...
    PA or Super PA, same amp with just more channels.
    If the aestethics of an 8-holer is an issue, why not look for a 4-holer?
  5. kuli
    kuli Active Member
    May 10, 2011
    123
    32
    There is a BIG difference soundwise between a 4 holer PA and an 8 holer PA! But you can easily disconnect the 4 extra holes/channels (2 wires to be unsoldered) and remove the extra pre-amp tube and the amp will be like a 4 holer PA.
    The 8 holer PAs lack a lot of gain compared to a 4 holer PA in stock condition.
  6. pleximaster
    pleximaster Well-Known Member
    Feb 6, 2012
    1,450
    1,443
    It use to be like this (very simplified) But PAs have gained popularity
    Metal panel 4 holes = 1/2 the price of a Metal panel 8 holes
    Plexi panel 4 holes = 1/3the price of plexi panel 4 holes
    Plexi panel 45/100 4 holes= 1/4 the price of Plexi panel 45/100 8 holes
    Observe that the Jtm45/100 are more expensive than the plexis and plexis more expensive than metal panels
    Jtm45/100
    4 holes ~ 12000 pounds
    8 holes ~ 3000 pounds
    JMP plexi
    4 holes ~ 6000 pounds
    8 holes ~ 2000 pounds
    JMP metal
    4 holes ~ 3000 pounds
    8 holes ~ 1500 pounds
    Very rough price estimates and note that prices are different on different local markets. Very few amps in Sweden are sold for very high prices and amps in the 10000 range and above always go international while a metal panel 8 hole just might fetch 1000 pounds here but 3000 in the UK or at least the US
    Plexi
    PS it usually enough to remove the extra valve and disconnect the power supply to the small component board to make an 8 into a 4 holes if adding caps in the tonstack you can turn it into a Lead, not necessary if you run it flat out
    HaenC likes this.
  7. Pageburst
    Pageburst Member
    Jun 26, 2017
    54
    51
    Pleximaster.
    Thank you very kindly. This was exactly the kind of info I was looking for.
  8. shakti
    shakti Member
    Jul 14, 2016
    39
    19
    I'll add that if you are not looking at a rare PA amp, it's very easy to mod it to have full Super Lead (4 hole) specs, *plus* a 2203 side. I did this on a 1970 Super PA and it sounds terrific. 100% reversible and no holes drilled. Vintage transformer, parts and sound, but budget price.
    Trapland likes this.
  9. Trapland
    Trapland Well-Known Member
    Dec 5, 2013
    1,073
    851
    Minneapolis
    Where are you located? Maybe a 4 holder is less than you think. I have one and it was/is quite affordable.
  10. Pageburst
    Pageburst Member
    Jun 26, 2017
    54
    51
    Hey Trapland,
    What four holer do you have ?
    I’m in NY
  11. Trapland
    Dec 5, 2013
    1,073
    851
    Minneapolis
    Sorry I missed this. I have a 1971 model 1985 ENG PA. It screams with a 69 basketweave.
  12. Pageburst
    Pageburst Member
    Jun 26, 2017
    54
    51
    That sounds pretty awesome particularly matched with the basketweave
  13. CptZar
    CptZar Member
    Mar 30, 2019
    30
    7
    You can jump all channels...
  14. RevJamie
    RevJamie Active Member
    Mar 13, 2011
    151
    71
    Portland Oregon
    I have a 69 Super PA and a 1970 Super PA and this is what I do. One set of 4 holes is 2203 Spec, the other is Super Lead Spec!
    I LOVE the Super PAs!
