Disconnecting The Polarity Switch On A '73 Marshall
Discussion in 'The Workbench' started by buddy7168, Jan 7, 2017.
  1. buddy7168
    buddy7168 Member
    Sep 22, 2014
    47
    39
    I’d like to disconnect the Polarity Switch and Death Cap from my ’73 Marshall. I’ve read a few threads that say as long as you have a three prong power cable (which I do) you can simply disconnect the Polarity Switch from the Power Switch. I noticed however that I have a light blue wire (from PT) as well as a yellow wire (from fuse) connected to the Polarity Switch. Do these need to be relocated and if so, where? Thanks in advance for your help!
    Polarity Switch Close Up
    In Context
  2. ampmadscientist
    6,077
    2,306
    What model is that, 1959?
  3. buddy7168
    buddy7168 Member
    Sep 22, 2014
    47
    39
    It's a 1987.
  4. ampmadscientist
    6,077
    2,306
    It's hard to see because the photo is so dark, but...
    There is no polarity sw on the schematic...but,
    clip both (far) ends of the capacitor leads, at the very end of the lead. Then pull the cap out (it's glued in...)
    Then at least the death cap is disconnected from the chassis, and disarmed permanently.
    Hard to tell how they wired the switch, but the switch won't do anything when the cap is removed.
  5. buddy7168
    buddy7168 Member
    Sep 22, 2014
    47
    39
    I did this and it worked out fine. Thanks for your help!
  6. ampmadscientist
    6,077
    2,306
    Now you are ready to modify it, into 2204.
