DiMarzio 36th Anniversary pups?
Discussion in 'The Tone Zone' started by Adrian R, Nov 18, 2019.
  1. AlvisX
    AlvisX Well-Known Member
    May 31, 2011
    4,227
    7,776
    I-55 Corridor
    I think for a lot of us , in the late 70s, these were our first reference to / experience with GOOD replacement pickups .
    They certainly made a difference in our Asian copies
    I feel like the reissue is right up there with the originals
    MarshallDog and johnfv like this.
  2. johnfv
    johnfv Well-Known Member
    Sep 29, 2010
    5,633
    4,193
    Austin TX
    I'm another fan of the 36th Anniversary PAF, I have them in several guitars. I'm having a hard time thinking of any full size humbucker I like better and the one I can think of (I'm a big fan of Lollar Imperials) costs a LOT more. IMO, it's hard to go wrong with the DiMarzio PAF.
    MarshallDog likes this.
  3. pedecamp
    14,133
    10,783
    Is every room in your house loaded with guitars and amps and you just walk room to room and jam on something different all day?
  4. rafalynch
    rafalynch Active Member
    Sep 4, 2014
    238
    122
    I was always from Seymour duncan and Gibson TTop pickup, but the 36th bridge I put it on a Fliying V Gibson and it sounds incredible in my Plexis ... very Judas Priest of the 80 '... AC / DC ... etc. Low-cost pickup is the best, I like it better than the 59 'of Seymour Duncan. Great pickup for little money.
    MarshallDog and AlvisX like this.
  5. AlvisX
    May 31, 2011
    4,227
    7,776
    I-55 Corridor
    Those clips are in 3 different locations , on two different continents
    But yeah ,after 40 years of playing ,repairing,wheelin n dealin ,travelin' ...stuff piles up
    Like I said ,that IS my actual 10th grade guitar
    pedecamp likes this.
  6. HOT TUBES 70
    Oct 13, 2008
    11,185
    5,656
    A set of pick ups that i took a chance on and ended up loving them !!!!
    Will not ever sell , trade or part with for any reason .
    Suhr Doug Aldrich
    [​IMG]fullsizeoutput_3
    [​IMG]20171123_070851
    Adrian R likes this.
  7. Adrian R
    Adrian R Well-Known Member
    Jan 28, 2009
    6,484
    4,835
    Far North Chicago Burbs'
    I pulled the trigger on a set of 36s. Cream bobbins with black pole pieces. Taking a chance with lower output pups. Got the set for under $150.00. Should sound cool with a high gain amp. In the end I wanted bright and clear. Looking for a sorta unique sound for the original music we're writing. F spaced bridge and regular spaced neck pup. Found out my newer Gibsons need F spaced pickups in the bridge!
    HOT TUBES 70 and pedecamp like this.
  8. ampmadscientist
    16,588
    10,492
    That's cause the sound comes from the guitar not the pickups. (mainly the wood)
    If you have a guitar that never sounds right (no matter what pickups) then get a different guitar.
    You need to start with a better sounding guitar.
    If the guitar does not sound great to start, then pickups won't ever fix that problem. Never has.
  9. Adrian R
    Jan 28, 2009
    6,484
    4,835
    Totally agree! Learned that awhile ago between an 06' Gibby V and a 2012 SG Standard. Both guitars are gone. Pickups give you variations of that same sound.
  10. ampmadscientist
    16,588
    10,492
    I bought this L-6S and no matter what PUs it sounded as dead as a stump. There was no way to make it sound good. Lesson learned the PUs don't make the sound.
    You can put $10,000 PUs on a crap guitar and it will still sound like crap. :lol:
  11. Adrian R
    Jan 28, 2009
    6,484
    4,835
    P
    Differing pickups do sound different though. Big difference in magnets, especially comparing ceramic to alnico.....Never yet have I been able to warm up to a ceramic magnet. They always have a synthetic nature to me.
  12. Matt_Krush
    Matt_Krush Well-Known Member
    Dec 14, 2015
    1,183
    931
    Saginaw MI
    Pickups to a guitar is what a EQ pedal is to an amplifier.
    Neither by themselves can polish a turd, but they can take.."that's pretty good...I like it" to "oh yeah...now that's what I'm talking about"
  13. MarshallDog
    Nov 28, 2010
    13,465
    13,476
    Taintville
    Congrats, I think you will love them!! They may be classified as lower output but they still have balls and with the tone knob at 10 they should be as bright as you need.
  14. KelvinS1965
    KelvinS1965 Well-Known Member
    Nov 22, 2015
    253
    538
    I'm a big fan of the 36th Anniversarys: I had previously fitted a set of quite expensive Bareknuckle 'Mules' in my Epiphone Les Paul (and completely re-wired it with CTS pots, metal braided wiring, etc). I liked them, but a few years later decided to modify a Telecaster and put a 36th Anniversary in the neck positon...this gave a fantastic result and for quite a lot less than the BK ones.
    Fast forward to now, the Tele got sold (I put it back to standard first) and I've decided to put that 36th Annivesary neck and a freshly bought bridge version in my Gibson SG Standard. I want to replace the PCB/pots and 61T/61R pick ups, so they will all be removed (and stored away, just in case) and replaced with the 36ths and proper wiring.
    Delivery received today, to go with the parts I already have:
  15. Adrian R
    Jan 28, 2009
    6,484
    4,835
    I hope their thick enough.... I figured if the output was not enough I can always boost with a SD pickup booster pedal. I do play allot of like older school classic metal...even the original stuff is sort of in the same vein. Lots of pinch harmonics too...
  16. pedecamp
    14,133
    10,783
    You'll be fine, all my guitars have paf pickups and I can get gobs of gain and clear tone. Looking forward to hearing your review! :yesway:
  17. MarshallDog
    Nov 28, 2010
    13,465
    13,476
    Taintville
    I find mine plenty thick with all my amps. Sometimes I turn the volume down and the tone up a bit to get a slightly thinner sound...I really think you will be impressed or at least I hope so!
    Guitar Dave T and Adrian R like this.
  18. MarshallDog
    Nov 28, 2010
    13,465
    13,476
    Taintville
    Nice...please report back after you put her through her tests!
    KelvinS1965 likes this.
  19. Kinkless Tetrode
    Aug 17, 2017
    1,110
    1,375
    Too bad you still don't have the Jube. Vintage output pickups and Jubilees get along. But congrats on the JVM.
    I think you will like them. And among PAFs the 36th have good out put. In a LP they should be thick enough.
  20. MarshallDog
    Nov 28, 2010
    13,465
    13,476
    Taintville
    What he said!
