Difference in sound between EL34, E34L and KT77’s
Discussion in 'The Workbench' started by Rod, Apr 1, 2020.
  1. Rod
    Rod Active Member
    Aug 22, 2012
    100
    114
    Just curious of the tonal differences between EL34s, the JJ E34L and the JJ KT77’s... it’s all a bit confusing... I sold all my old Marshall’s years ago because of volume issues with band performances..(bluesrock genre).....unfortunately.. but I have some amazing overdrive pedals from Lovepedal that I’ve been using with my Marshall Origin 50 head run clean that I’ve been using with a Scumback M75 or a Tone Tubby alnico red....but I’m trying to tweak the power section some... any suggestions are welcome
  2. Kelia
    Kelia Well-Known Member
    Feb 26, 2018
    851
    799
    The KT77's will have a little more headroom and thighter bottom end will less compression ,
    they are awesome tubes ,....here's a guy who plays some Bluesy riffs through his KT77 MKIII
    and there is only one speaker in the cab IIRC
  3. pedecamp
    14,499
    11,417
    Read some good descriptions here:
    https://www.eurotubes.com/store/pc/viewCategories.asp?idCategory=3
